v5.12 released
What’s new in 5.12 (2012-Jan-19 14:31):
*) console - allow to specify blank interval on x86 screens;
*) console - changed ‘password’ command, now can be used from scripts and api;
*) winbox - reorganized window layout to match console better;
*) ssh - fixed interoperability problem with psftp based clients;
*) implemented simple SMB (windows file sharing) server;
*) fixed ovpn-client - client stopped working if it was enabled/disabled at wrong time;
*) fixed ipv6 - ipv6 neighbor discovery stopped working when
interface arp setting wasn’t set to enabled;
*) console - minor fixes and improvements;
*) console - added support for compact export;
*) hotspot - added login redirect through http status 302;
*) leds - added default configuration for R5SHPn wireless card;
*) ppp - fixed problem were remote-ipv6-prefix was not given to user if remote-ipv6-pool was
provided;
*) winbox, webfig - sort ethernet interfaces properly when more than 10 exist;
*) added QuickSet to RBSXT, RB411, RB711;
*) user manager - command to create and assign user profile from console;
*) added support for LTE modems (cdc ethernet type);
*) fix gre tunnels on x86 and other little endian machines;
How to use?
submenu
/ip/SMB
Just a little bit of thinking…will help You.
Winbox > IP> SMB
I see that now backups have the hostname as prefix, instead of Mikrotik! A lot of hand-renaming saved! Thanks!
anyone tried on x86?
Seems like they have forgotten the interface for “use BFD” in OPSF/BGP when adding a BFD menu.
appreciate the SMB feature but its still needs lot of some improvement.
specially with the dialog box, i hope it not pop out dialogbox for guest user :slight_smile:
woouh…finally thank’s :slight_smile:
We will improve the SMB feature in the next release.
What kind of dialog box you saw?
IPv6 works fine with reply-only on the bridge interface but now IPv4 don’t work. Seems like it does not reply to ARP requests. I have not done a wireshark yet…
does it support sierra wireless mc8801 or novatel expedite e371?
we have only tested Bandrich C501 modem. I think sierra modem uses different driver. Connect the modem to the usb port, make support output file and send it to support@mikrotik.com, we could check if it uses the same driver.
i think cards that connect on pci port…
you ment mini-pci-e interfae cards?
They connect to the USB interface so maybe it is possible to add, but as I told you we would need support output files to check if it is possible.
Hi all,
I am curious about the quickset feature for the SXT, 411 and 711.
Does anyone know where it is hiding?
D2.
there
Hmmmm,
perhaps this is router specific?
I upgraded my 751U with 5.12 and did not see the quickset menu above the interfaces.
I realise it is for the SXT, 411 and 711 but generally all boards have shown the same menus even if they cannot support it.
Thanks for your reply, I will have a look on some of my SXT’s and 711’s.
D2.
I’m not seeing it on 411s.
Is there a field that must be enabled somewhere?
Random changes and other odd stuff that I’ve noticed in 5.12 (some of these maybe from 5.10 or 5.11):
  • The SMB service
  • Lots of export enhancements and changes, including things like ordering changes (“/snmp” and “/system routerboard settings”), and things which no longer export (“/user group” polices, “/system scheduler” and “/system script” policies, “/store”, “/ip ssh”, …)
  • Various tweaks to the WebFig UI. BTW - If you don’t see some change take effect there when you think that it should, you may have to flush your browsers cache.
