v5.18 released
What’s new in 5.18 (2012-Jun-21 17:20):
*) fixed upgrade problem when it failed with error “disk is too small” while
there was plenty of space left;
*) fix health and poe access reliability on OmniTIK UPA and RB750UP boards;
*) sstp - improve initial handshake to better handle many new connections;
*) wireless - do not use bridge and WDS mode on AP-AP links, causes loops;
*) dhcp ipv6 pd client - fixed ipv6 pool creation after reboot;
*) dhcp ipv6 pd client - added option add-default-route;
*) sstp - fixed connection idle time reporting;
*) fix bad block count not to increase on Samsung K9F1208U0C nand;
*) snmp - fix dhcp lease table, snmp reported an incorrect information
when a static lease had configured different address than current active address,
this should also solve problem with dude polling same leases over and over again;
*) fix RB1100 crash on interface disable/l2mtu change/reboot;
*) dns could not resolve some domain names, was ignoring replies with DNAME RRs;
*) fix firewall log action - sometimes was not logging mac addr;
Download: http://www.mikrotik.com/download
Seems to be a bug in IPv6 dhcp PD client.
It was ok immediately after reboot, but shortly after I see:
/ipv6 dhcp-client print detail
Flags: D - dynamic, X - disabled, I - invalid
 0    interface=aaisp pool-name="aapool" pool-prefix-length=64 status=bound prefix=2001:XXX:YYY:1::/64 expires-after=4885w2d21h50m9s
      duid="00030001000c42e18a17" add-default-route=no
The pool has disappeared.
This means my IPv6 address which is assigned from the pool goes invalid.
If I renew the dhcpv6 then the expiry is more usual:
 0    interface=aaisp pool-name="aapool" pool-prefix-length=64 status=bound prefix=2001:XXX:YYY:1::/64 expires-after=59m13s
But still no pool.
If I release the dhcpv6 then the pool appears.
I also notice that winbox is showing a different expires time compared wiith the command line on /ipv6 dhcp-client print detail
Nick.
You are right about winbox not showing correct Expire time. We will fix it in the next version.
I cannot repeat other problem. Can you post /ipv6 pool print poutput?
When it wasn’t working there was no pool at all
/ipv6 pool print detail
Flags: D - dynamic
Currently (after I Released) it shows
Flags: D - dynamic
 0 D name="aapool" prefix=2001:XXX:YYY:1::/64 prefix-length=64 expire-time=48m16s
I’ll reboot it again and see what happens
Nick.
It takes about 20 seconds after boot to go from having a pool to the pool disappearing:
[nicks@rb751.shore.me.uk] > /ipv6 pool print detail
Flags: D - dynamic
 0 D name="aapool" prefix=2001:XXX:YYY:1::/64 prefix-length=64 expire-time=59m51s
Flags: D - dynamic
 0 D name="aapool" prefix=2001:XXX:YYY:1::/64 prefix-length=64 expire-time=0s
Flags: D - dynamic
Flags: D - dynamic
Flags: D - dynamic
I wonder if it happens as the sntp client starts ?
Nick.
I’m a bit confused here…; is this a problem in previous version that now is solved? Or is the bridge and WDS funcion on AP-AP links causing loops and in 5.18 is therefore not recommend to use?
I suppose it is a problem solved. But than again, never knew it had an issue. I use it in same situations in versions up to 5.16 and have seen no problems so far…
And what about the wireless disconnection problems in some units that evolved in 5.17?
I have made some support tickets for these with many examples but still not seeing any solution?
We had this problems on our network. Previous owner of a part of our network was using using it. After upgrading from some 5.0rcXX to 5.7 we foung huge packet rates (like 15000p/s) on some interfaces going from no IP to no IP. Everything was solved just moving from AP-AP WDS mode to AP-client mode. It was impossible for use to fing what is the problem, (switch, RB, rOS or something else) but after changing the topology it was solved, so nevermind what it was.
I do the same. Still disconnect in 5.18
That changelog line means that there were a problem between WDS-WDS link that instead using just wds mode it also used the bridge mode which then created a loop. This problem if fixed now and WDS to WDS links will work fine.
what does it mean “AP-AP links causing loops”???
I can’t find this option…
It is not in winbox yet.
Set it from terminal
/ipv6 dhcp-client set x add-default-route=yes
can you pls post sample of config, i think it will make sense as its bit confused
WebFig: URL direct links to disabled sub-menu pages still works :frowning:
[Ticket#2012061366000346]
Regards,
RB751U-2Hn is still spinning out with 100% flash on wifi => bridge => masq => internet traffic. Rendering DNS and telnet/ssh unusable. Sigh. These models have taken so long and still not working.
This doesn’t happen for me, Have you tried going back to an empty config and starting again ?
Nick.
Was the change meant to fix this?
Flags: X - disabled
NAME VERSION SCHEDULED
0 system 5.18
17:50:57 dhcp,error creating ippool6 failed: prefix of two pools cannot overlap! (6)
Matt.
Yup. Done from a netinstall. Done reset-default on the wireless configuration. Was getting the watchdog reboots before 5.17, and going back and forth on a ticket for that since December, but that, at least, has dropped in frequency to a manageable level. But heavy traffic, particularly upstream, causes the router to just spin out of control. /tool profile stops updating, on an already opened telnet session. Reproducible within about 15 seconds.
When adding DHCPv6 Binding, no matter GUI or command line, it is being marked as dynamic and disappears after router reboot.
[admin@router] /ipv6 dhcp-server binding> add duid=00010001157dbdeadbeefc0de777 iaid=24xxxxx92 address=2001:xxxx:xxxx:xxxx::10 life-time=1:00:00 server=all disabled=no
[admin@router] /ipv6 dhcp-server binding> print
Flags: X - disabled, D - dynamic
 #   ADDRESS                                                DUID                 IAID SERVER           STATUS
 0 D 2001:xxxx:xxxx:xxxx::10/128                            00010001157...  24xxxxx92 dhcp_ipv6        waiting
Notice the “D”. I can make it static with “make-static”, but this needs fixing I think. There are some more problems, like when I do
set [ find ] server=my_server_name
it doesn’t show in GUI.
I cannot make my Windows 7 machine to get this specific binding address… After turning on debug logging, no matter how I set ND or DHCPv6, it displays:
Handling only prefix delegation, discarding..
