*) manual upgrade to NEW beta poe controller firmware v2.0 for RB750UP and OmniTIK UPA;
more info at > http://wiki.mikrotik.com/wiki/Manual:PoE-Out
*) fix RB951-2n wireless issues;
*) ups - fixed resource leak;
What’s new in 5.20 (2012-Aug-15 13:04):
Can’t seem to get the UPS to work from the USB port on a RB751G using 5.20…
Connected ok under 5.19 but would not stay online longer than 5 minutes even if I set it to 60 minutes. UPS was online and ok.
The UPS is a APC RS 1500.
ya, normis
I previously had trouble RB411ah / R52HN hangs after 6-7 hours at ROS v5.19, Downgrade v5.18 running but ccq ccq value is very small 20 % - 40 %, data rate and throuhput not good.
After upgrading to 5:20 RC1 and v5.20 released hotspot connection is stable.
The value of data rate, throughput is very good, it was ccq average 80% -90%.
Nice job
RB411ah / R52HN AP bridge only
I using RB450G router.
Upgrading to the new POE firmware (previous 1.10, and new 2.0) on RB750UP got problemes on ether5 when connecting a Rocket M5 to it.
With PoE firmware 1.10 it works well, but upgrading it to 2.0, it continously reboots de Rocket M5. We try it with two RB750UP units, and does the same.
If set “PoE Out” to auto on ether5 (nothing connected in it) and ether4 (Rocket M5 connected in it), the Rocket M5 reboots faster. And when set “PoE Out” in ether5, Rocket M4 on ether4 works fine.
I seem to be getting better CCQ for NV2 in PtMP configuration. Can Mikrotik confirm that there were changes made to NV2? I’ll not deploy until someone confirms it. Thank you.
