*) web proxy - speed up startup;
*) metarouter - fixed occasional lockups on mipsbe boards;
*) wireless - update required when using small width channel RB2011 RB9xx
caveat: update remote end/s before updating AP as both side are required to use new/same version for a link
Upgrade autmatically using the “Check for updates” button in System Packages menu.
Hi Normis
Very nice to see the updated ROS 5.
Very interesting bug with Atheros 9344 (the third one in description)
Only one question - and when we can change the DTIM interval for SSID (default is 1 and cannot be changed by software - no option) to 2 or higher?
A lot of client side devices looses the battery power very fast because of Mikrotik DTIM is selected 1.
When does problems with RB1200 will be solved ?
Problems:
High CPU with any type of profile;
Low performance throughput over 25 Mbps
High CPU with throughput over 25 Mbps
Customers are disappointed with Mikrotik RB1200.
And our customers are disappointed with our ISP.
The RB1200 never worked correctly with versions 5.x
After the 5.25 update I got the following message and had to delete/reimport my certificates (and update the sstp server):
15:49:21 sstp,error server certificate change failed: could not load private key (6)
15:49:31 sstp,error server certificate change failed: could not load private key (6)
If one of the devices already supports 10MHz, you can leave it, although we ALWAYS recommend to update to the latest version, even if there is no specific reason.
Edit: Hmm.. I made netinstall to 5.24 and quickly checked that everything is okay and wlan is working etc. Then I upgraded back to 5.25 and this time everything is working correctly.
Team mikrotik does not respond when the problem will be solved.
Because RB1200 problem of architecture.
The throughput is bad because it has a problem of CPU x ETHERNET
The CPU is always high even with simple firewall rules.
Throughput up to 25Mb CPU is High.
The problem has to be resolved quickly, we can not have equipment with this type of problem.
There are still issues with the 2Ghz SXT lites and 10 Mhz channels. Upgraded an AP to 5.25 along with one of the SXT lite units. The SXT will now associate but either has no throughput or just constantly disconnects. The log shows ranging timeout on the SXT, the AP side shows Medium Access timeout. The SXT also shows a negative number for the TDMA Timing offset. I will send in some support files from the AP and Client under a ticket I have open about the SXT lite issues.
