v6.0beta3 released!
What’s new in 6.0beta3 (2012-Aug-22 12:12):
*) installation - use much less space in storage (works well with 32MiB flash);
*) routerboard package is now merged with system package;
*) userman - use corresponding time zone data when showing date in console;
*) gps - init-string option;
*) ipsec - kill phase1 if ipsec-sa in responder expires due to system time change;
*) ipsec - rekey phase1 before expiration;
*) ipsec - when last ISAKMP-SA is deleted for the remote host remove related IPSec-SAs;
*) ipsec - send delete IPSec-SAs on shutdown/reboot;
*) user manager - fix user’s active profile end time if it has unlimited validity,
these users now won’t be hidden from reports when date filters are in effect;
*) certificate validity is shown using local timezone offset;
*) fixed queue bit rate reporting;
*) fixed ipv6 firewall;
*) upgraded drivers and kernel (to linux-3.3.5);
*) added priority matcher to firewall;
*) added change-dscp from-priority and from-priority-to-high-3-bits options;
*) fixed router crash or hang when rebooting;
*) add snif-tzsp,snif-pc actions to ip/ipv6 firewall mangle;
*) traffic-generator improvements for multi core;
Download: http://www.mikrotik.com/download (click “View More” to see Beta)
error show “Name”(enable show) package list WinBox
i have rb333 with a damaged one lan port. Any attempt to upgrade ros6b3 the ends failure. I also tried netinsall but the effect is the same. With ros4 and ros5 works well.
ntp client dont work mipsbe
enabled: yes
mode: unicast
primary-ntp: 194.190.168.1
secondary-ntp: 0.0.0.0
dynamic-servers:
status: error
simple queue dont work (dont show traffic) without specifing targed download and upload
true
I wanted to report that NTP client doesn’t work, but I see it has already been done.
I tested it on several products, it doesn’t work on mipsbe (RB750, RB750G) neither on PPC (RB1100, RB1100AH, RB1100AHx2, RB1200).
one of the most important issues with beta 2, all simple queues IP are lost and change to 0.0.0.0. was this fixed??? nothing in release notes…
  • It appears that the UPS driver doesn’t work in 6.0 beta3.
    The USB port doesn’t show up in the UPS port selection.
    It does show up in the resources area though and recognizes the APC UPS RS1500 that I am using.
RB751G-2HnD
simple queues work fine in beta3.
linek1980 and hapi, which port is damaged, and when does the error occur?
all
all have link down
Please clarify the issue a little more. If all ports are damaged, you can’t install RouterOS, that’s normal. Or you have all ports broken after installation? Which RouterBOARD model, which firmware and what was the previous running RouterOS version?
RB333. v5.20 is ok.
upgrade to v6.0beta3… boot is ok… dual beep ok… all ethernet is link down. Sometimes flash Ethernet cable if it is connected. Must be used NetInstall for return to v5.20.
Netinstal from v6.0beta3 for RB333 is does not work. Kernel panic. Must by used from v5.20.
That version was not tested? I do not know that you have an error come.
dude: routerboard package is missing, dude does not do the update.
starting 6.0beta3 routerboard.npk is no more. All the functionality from it is integrated into system package.
It is goog, but DUDE need routerboard package to upgrade. Will be new version of dude? For Compatibility DUDE and V6.
Are there any improvements about the Atheros 8316 switch IC? I mean the switch freeze issue on some gigabit RBs (RB435G, RB493G, RB450G).
We are not aware of any freezing, unless you mean issues with Metarouter and these chips. If you have encountered any such issues, contact support with more info.
RB 439 upgraded from 5.12 to 6.03 beta , router rebooting every 3 to 4 mins , CPU jumping to 100% for sometimes and back normal even with no load .
 #   NAME                    VERSION                    SCHEDULED
 0   system                  6.0beta3
 1   hotspot                 6.0beta3
 2 X ipv6                    6.0beta3
 3   mpls                    6.0beta3
 4   security                6.0beta3
 5   routing                 6.0beta3
 6   advanced-tools          6.0beta3
 7   wireless                6.0beta3
 8   dhcp                    6.0beta3
 9   ppp                     6.0beta3
10   routeros-mipsbe         6.0beta3
11   dude                    4.0beta3
OMG … incredible. We all know that routerboard package is part of the system. But this dude knows. Dude says: missing routerboard package. End of story.
