v6.10 IPSec multiple networks including hotspot
So here’s the thing:
1.1.1.0/24 - hotspot LAN with WDS.
2.2.2.0/24 - LAN
I have an IPSec vpn to 2.2.2.0/24 which works just fine. What I need is to access 1.1.1.0/24 via same vpn as well so I can access AP’s and I can’t make it work. Have been bashing my head against it for 6h or so…
> ip ipsec peer print
Flags: X - disabled
 0   address=0.0.0.0/0 passive=yes port=500 auth-method=pre-shared-key-xauth secret="123" xauth-login=""
     xauth-password="" generate-policy=port-strict exchange-mode=main mode-config=vpn send-initial-contact=yes
     nat-traversal=yes proposal-check=obey hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 lifetime=1d
     lifebytes=0 dpd-interval=2m dpd-maximum-failures=5
> ip ipsec mode-config print
Flags: * - default
 1   name="vpn" send-dns=yes address-pool=dhcp_poolINT address-prefix-length=24
     split-include=1.1.1.0/24,2.2.2.0/24
> ip ipsec policy print
Flags: T - template, X - disabled, D - dynamic, I - inactive
 0 T  group=vpn src-address=1.1.1.0/24 dst-address=2.2.2.0/24 protocol=all proposal=default template=yes
 1 T  group=vpn src-address=2.2.2.0/24 dst-address=1.1.1.0/24 protocol=all proposal=default template=yes
 2 T  group=vpn src-address=2.2.2.0/24 dst-address=2.2.2.0/24 protocol=all proposal=default template=yes
> ip ipsec user print
 # NAME                                                    PASSWORD
 0 user                                                      pass
 1 user2                                                    pass
Am I missing something?
If you need additional info just let me know what do you need…
Bump
Sorry for resurrecting this 2014 problem.
Did you find the solution for this? I’m having the same problem on the latest version: 6.34.4
Hi.
I did solve it, but unfortunately i don’t remember exactly how, whether it was a solution or a workaround, and i can’t look at it because since then I’ve completely reworked that clients network.
Somehow I’m thinking that I did add firewall rules that allowed me to “speak” to specific IP’s on the hotspot network, but i’m not sure. If I will remember what I did, I’ll post it, but for now that’s all I can help you.
