v6.12 released
What’s new in 6.12
*) l2tp - fixed ~no buffer space available~ problem;
*) ipsec - support IPv4 over IPv6 and vice versa;
*) pppoe - report correctly number of active links;
*) updated timezone information;
*) many fixes for CRS managed switch functionality -
particularly improved VLAN support, port isolation, defaults;
*) added trunk support for CRS switches;
*) added policing support for CRS switches;
*) www - added support for HTTP byte ranges;
*) lte - provide signal strength using snmp and make ‘info once’ work in console;
Simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu. If you run v5 or older, download the newest NPK package from our webpage, upload to your router, and reboot: http://www.mikrotik.com/download
STILL EXIST ON 6.12
http://forum.mikrotik.com/t/v6-11-released/75450/1
BUG SIGNALED FROM 6.10 AND STILL NOT FIXED??? :imp:
Opened another ticket for that: [Ticket#2014041566000226] 6.12 UNFIXED BUG: user-manager profile limitation
:frowning: OK, I UNDERSTAND,
is more important to fix CRS than this “limited” option…
I wait the fix on 6.13… :confused:
-3 is still +3:
[admin@TestPlace] > /system clock print
            time: 15:37:53
            date: apr/15/2014
  time-zone-name: Etc/GMT-3
      gmt-offset: +03:00
this exists even in v5
So far good
Upgraded on RB2011UAS and RB2011L no problems so far.
Packet marks work on RB2011UAS.
Krzysiek
RouterOS upgraded fine from v6.11 to v6.12 on a RB951Ui-2HnD, but upgrading the routerboard firmware from 3.12 to 3.14 caused a series of reboot loops before it settled and started working.
Anyone else seeing this ? Because that was my router at home, so no harm done, but I plan to upgrade a few Metal 2SHPn on towers to see if a problem on them is fixed .
P.S. Hmm actually forget the part about the Metal’s. i just upgraded 1, but their firmware stays at 3.13.
Chupaka, why don’t you just use your city? That one works always
[admin@auto] /system clock> set time-zone-name=Europe/Minsk
[admin@auto] /system clock> print
time: 15:56:32
date: apr/15/2014
time-zone-name: Europe/Minsk
gmt-offset: +03:00
That sounds interesting. Can someone give me a link to the doc’s on that?
THIS KERNEL BUG ARE NOT SOLVED ON 6.12 (final)!!!
http://forum.mikrotik.com/t/problem-with-mount-point/94/1
http://www.cyberciti.biz/cloud-computing/http-status-code-206-commad-line-test/
RFC2616 section 14.35.1 (see here). :slight_smile:
sure, Ticket#2011111666000887. Maris said, “problem will be fixed in one of the next versions”. I’m waiting that version for 2,5 years already :smiley:
UPD: I also mentioned this problem in Ticket#2013121166000256
I know, but there were recent changes in Belarus timezone, and TZ info was not actual in RouterOS until the december, 2013 :slight_smile:
This version has just come out, and for now there are three old ticket still unresolved:
Ticket#2014031766000331 (2014-03-17) Missing parameters on CLI
Ticket#2014032566001217 (2014-03-25) KERNEL CRASH / PANIC
no buffer problem still seems to persist in 6.12.
but this time it’s not related to l2tp. i have a box with GRE over IPSec tunnels
(~80 tunnels) and run BGP over them.
just had to restart the device 4 hours ago because of “no buffer space avail”.
Hm… 6.12 was officially announced less then 4 hours ago…
If you have it running for more than 4 hours, it could mean you are not running the version that was just released now. Upgrade to the one on the webpage please.
rextended, please do NOT re-post all the fixed issues here. Post only NOT fixed issues if you find any. Thanks!
it was the 6.12 from 11th april. Normis posted the url to it in one of the other threads. checked the changelog,
and as it stated the buffer space issue to be fixed, i gave it a try. now i am running the official image
(build date: Apr/14/2014 09:27:45)
When can we expect more complete documentation with examples for the CRS?
What about CAPsMAN (wireless-fp package): is it still beta or production-stable?
SNMP for LTE signal strength, but yet we see nothing for CCQ..
