v6.14 released
Some good changes here, including the new “ip cloud” menu, and general release of CAPsMAN:
What’s new in 6.14 (2014-Jun-06 15:34):
*) sntp - ‘mode’ now is a read-only property, it is set to broadcast if no
server ip address is specified;
*) smb - fixed some SMB1 errors;
*) wireless-fp package is now included in routeros one (disabled by default);
*) webfig - fixed quickset, it didn’t work with disabled wireless pacakge;
*) sstp - fixed problem where session was closed every 2min;
*) pptp,l2tp,pppoe - fixed problem where some of the static bindings
become dynamic interfaces;
*) eoip - lowered default MTU to avoid IP packet fragmentation;
*) eoip - added clamp-tcp-mss setting with default=yes for new tunnels to avoid
*) fixed - bridge could sometimes get added without ~running~ flag;
*) fixed - simple queues could sometimes crash router;
*) fixed - simple queue stats freeze (empty winbox queue window);
*) ssh server - allow none cipher;
) proxy - added ‘anonymous’ option which will skip adding X- and Via headers;
*) dhcp server - added option use-framed-as-classless and
added support for DHCP-Classless-Static-Route RADIUS attribute;
*) quickset - fixed problem where address mode selection did not work in
bridge mode;
*) ipv6 address - fixed problem where changing advertise lost ipv6 connected route;
If you already run some RouterOS v6.x version, simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu.
Others: http://www.mikrotik.com/download
Does this resolve all the bugs reported with CRS and 6.13?
Missed in WEB config.
no, but you might need to clear browser cache, and then hit refresh
STILL EXIST ON 6.14
http://forum.mikrotik.com/t/v6-11-released/75450/1
BUG SIGNALED FROM 6.10 AND STILL NOT FIXED???
Opened another ticket for that: [Ticket#2014041566000226] 6.12 UNFIXED BUG: user-manager profile limitation
I wait again the fix on 6.15… I’m waiting the fix from 6.10…
Well, nice. But I’d rather wait a bit longer with updating my network to 6.14…
I was just in the process of updating my network to 6.13, that seems to be pretty stable. I have some 85% done.
But now with the new 6.14 I can’t use the winbox
/sys
packages
‘check For Updates’
Download & Upgrade
sequence any more because it would now download 6.14. which I don’t want … yet.
Can there not an option build in winbox so I can actually pick the version from the server to download & upgrade? So I can use the same procedure but than in the last phase select a previous version to download and install? They are all still on MT’s servers I presume. Shouldn’t be hard to do?
For the rest of the network not updated to 6.13 yet I now have to fall back on the manual ftp transfer of upgrade packages, which in my experience takes more time but is also a bit more prone to failures…
http://forum.mikrotik.com/t/v6-13-released/77210/1
Как именно включается данная функция?в WinBOX без изменений в разделе Web-Proxy
As it turns this function? WinBOX in no change in the section Web-Proxy
I do see the changes:
[admin@test] /ip proxy> print
enabled: no
src-address: ::
port: 8080
anonymous: no
parent-proxy: ::
parent-proxy-port: 0
cache-administrator: webmaster
max-cache-size: unlimited
max-cache-object-size: 2048KiB
cache-on-disk: no
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
[admin@Core] /ip proxy>
.. -- go up to ip
access --
cache --
cache-contents --
clear-cache --
connections -- list all connections
direct --
edit --
export -- Print or save an export script that can be used to restore configuration
get -- Gets value of item's property
inserts --
lookups --
monitor --
print -- Print values of item properties
refreshes --
reset-html --
set -- Change item properties
how to turn on?
/ip proxy set anonymous=yes
[admin@Core] > /ip proxy print
                 enabled: yes
             src-address: ::
                    port: 8080
               anonymous: yes
            parent-proxy: 0.0.0.0
          max-cache-size: 256000KiB
   max-cache-object-size: 256KiB
           cache-on-disk: no
  max-server-connections: 800
          max-fresh-time: 3d
   serialize-connections: yes
          cache-hit-dscp: 4
             cache-drive: system
http://2ip.ru
Прокси: Используется
Ваш IP адрес за прокси-сервером: 192.168.100.10
Proxy: Used
Your IP address behind a proxy server: 192.168.100.10
Normis, any chance to have IP Cloud for x86?
Hi
can anyone help om the session time left if this already been fix with this new version ?
JoJo
Why no line in changelog about OpenSSL bugs?
http://forum.mikrotik.com/t/openssl-5-june-bugs/77854/1
because it’s OpenSSL bugs, not RouterOS? :slight_smile:
I really like the wireless-fp package. I had one device that would not even see my AP. Now works fine.
Speeds are much better too.
Anonymous proxy does not work?
Or something I have not tested it properly?
I’ve upgraded two brand new SXT Lite 5 from 5.26 to 6.14. As I reboot the the device, wireless menu item does not appears on menu.
The package is enabled
As I reboot the device, the menu item show up.
Here’s how my USB 3G dongle (Huawei E169) is identified, but it seems to me that it works properly (my backup link does not exceed 512Kbps) - on RB751U-2HnD.
