v6.2 released
Does any one have any problems with sfp? At this moment im using ether6 as uplink (i use media converter from fibre to copper)and its working fine, but when i change to SFP1 i lose connection. I use mikrotik S-31DLC20D sfp module and CCR recognize it.
Current ROS is 6.2 and firmware version is 3.09.
haha, I can’t see it even in v5.14 - seems like the problem is older than you think…
ROS 6.2
/ip address> add
address: 9.9.9.8/24
interface: ether2
failure: netmask cannot be /0
/ip address> add
address: 192.168.88.55/24
interface: ether2
Script Error: action cancelled
Both Winbox and WebFig are incorrectly reporting IPsec SA expiration time in 6.2.
No problems in console:
[andrew@MikroTik] > /ip ipsec installed-sa print
Flags: A - AH, E - ESP, P - pfs
 0 E  spi=0x30BB8DB src-address=x.x.x.x dst-address=x.x.x.x auth-algorithm=sha1 enc-algorithm=3des replay=4
      state=mature auth-key="d117cc9bab41bcfe966454cc461f0252882c998f" enc-key="38308591a3c5858c90bca35a66ef46a44e8f61347e428413
      addtime=aug/12/2013 19:46:38 expires-in=40m43s add-lifetime=48m/1h current-bytes=253972
and also in V6.1.
Hi rudios
are you sure about this? :slight_smile: if you mind can i have your html already fix so i can upload easily without modifying the page TBH i have no experience on web editing lol
thanks
Both Winbox and WebFig are incorrectly reporting IPsec SA expiration time in 6.2. And also in 6.1 :exclamation:
I did not change the file.
You can change it very easily.
Copy the login.html from the files via winbox onto your PC.
Open it in e.g. notepad and remove the double quote char I marked.
Put a normal double quote char (used anywhere else in the file)
You could also remove the complete line, since the Latvian translated login.html file does not even have that 4th meta line.
Shouldn’t be a problem deleting it completely.
When you have changed the file, copy it back to the mikrotik
Packet sniffer does not seem to work in 6.2. (No packets results show)
6.1 works fine.
(RB433AH)
will be fixed in 6.3
Unfortunatelly it did not help with the graphs. I have not checked the scripts, because when first problem (and I think the easier) is not solved than there is no reason to continue wasting the time by testing on devices that I need to run.
I have installed v6.3rc1 into one of my devices. When it is starting I can see the old graphs as they was lastly recorded by v5.25 with the last time when v5.25 lastly run(yesterday 9:53)
After a few seconds the graphs disappear (probably due to new time setup)
Meanwhile (yesterday 9:53 till today approx 17:00) I run v.6.2. No recordingw were made. After that, today around 17:00 I installed v6.3rc and let it run some time (half an hour) to record the data into graphs. After restart, no recording was done.
Only the way to continue data recording for graphs is to downgrade again back to v5.25…
Hello!
After installing the 6.2 noticed that the total does not exceed the port speed 70Mb/s, using p2p very noticeable restriction, although statistics indicate the port’s current speed as 80-100 Mb/s.
Routerboard RB450G
Discarding packet: locally originated, problem 6.2
tell me how to solve the problem
BUG report
V 6.2 release
editing hotspot user profile, setting incoming-filter and outgoing-filter in winbox does save it correctly.
console ok
let’s try…
i hope no bugs…
hello everyone
I have a problem with user manager 6.2
when I create a profile with 2 limitations in user manager with different time,everything works wrong.
and users can pass my limitations.
(with one limitation everything works fine)
for example with this setting when a user connect in 9 am everything works fine until 10:56am. after 10:56am second limitation not working,and user can pass 2M limitation.unless user disconnect in 10:55 then connect again in 10:56!!
please test.
thanks
It’s fun!
ROS 6.2 shows not the correct values ​​of the traffic.
How is this possible?
Feature Request for 6.3 :slight_smile:
adding the possibility to execute script with parameters
/system script run script1 $1 $2 $3 $4
thanks
Armand
cant confirm that, tested on ccr1016 and rb1100.
Can PPPoE server accept any username and password to accept all pppoe clients?
