please give an example, what is not working with SSH ?
[admin@Branding] /system package update> print
current-version: 6.26rc5
latest-version: 6.26rc11
status: Downloaded 89% (11.7MiB)
Connection to 192.168.88.1 closed by remote host.
Connection to 192.168.88.1 closed.
Normundss-iMac:kanier normis$ ssh 192.168.88.1 -l admin
Branding RouterOS 6.26rc11 (c) 1999-2014 www.branding.com
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[admin@Branding] >
I have a sys-note of 715 bytes. When loggin in this is shown half only. (Every time I tested I had 486 bytes displayed.) After a delay of about 60 seconds the other half is printed and I can access the prompt. ‘/log print’ hangs completly. Possibly this is related to text output.
just installed 6.26rc10 on 951G ..sys reset ..reboot (two or three times): cpu stay at 100% forever
( on tools/pofile I see 75% unassigned and 25% management )
I’ve seen 100% load on 2 RB2011UiAS, both with 6.25.
One of them is doing it right now, spending 75% on ssh. SSH connections cannot be established. The other is doing fine since the last reboot (approx. 2-3 days ago).
I say scrap the whole development done recently and go back to the branch before holidays (6.23)
What about a “login hotspot fixes” in previous rc changelog?
Can be solved the redirection of https when a valid certificate is correctly installed and working, but hotspot not redirect to the https login page automatically. Doing manually all work perfect.
Thanks!
