*) email - increase server greeting timeout to 60s;
*) lte - ZTE MF823 may loose configuration;
*) userman - update paypal root certificate;
*) timezone - updated timezone information to 2015b release;
*) cm2 - fixed capsman v2 100% CPU and other stability improvements;
*) route - using ldp could cause connected routes with
invalid interface nexthop;
*) added support for SiS 190/191 PCI Ethernet adapter;
*) made metarouter work on boards with 802.11ac support or usb LTE;
*) sstp server - allow ADH only when no certificate set;
*) make fat32 disk formatting support disks bigger than 134GiB;
*) fixed tunnels - could crash when clamp-tcp-mss was enabled;
*) added basic counters for ipv4/bridge fast path, also show status weather fast
path is active at all;
*) trafflow: - fixed crash on disable;
*) pppoe over eoip - fixed crash with large packets;
*) tilegx - fixed memory leak when queue settings are changed;
*) ar9888 - fixed crash when hw reports invalid rate;
*) console - fixed “in” operator in console;
*) console - make “/system package update print” work again.
*) tile - rare situation when CCR devices failed to auto-negotiate ethernet link (introduced in v6.25);
*) dhcpv4 client - it is now possible to unset default clientid and hostname options
*) initial RoMon (Router Management Overlay Network) support added;
(I am posting this here because if it is a valid bug, I do not want it sneaking into 6.28, I would rather it be fixed first)
I have a small bug I encountered with a CCR1036 and I am unsure if this is a config issue.
I replaced a RB-1100AHx2 with a CCR1036.
RB-1100AHx2 was running 5.25 and CCR1036 was running 6.27
(Unfortunately this leaves a huge gap in firmware issues, however I do have other RBs running more recent 6.x firmware that don’t have this problem, so I believe it’s “recent”)
Essentially VOIP/SIP stops working correctly. Registrations to not occur/hold.
There are no SIP/VOIP related firewall rules, and config is export/import identical.
Running the two RBs side by side, RB-1100AHx2, works perfectly. CCR1036, registrations break.
To make matters worse, it only occurs with certain VOIP hardware.
Polycom phones = good.
Cisco phones/ATA = bad
Checking the config on the Cisco, they all work perfectly with other setups and other ISPs, only when passing through the Mikrotik they stop working.
I have tried with SIP ALG enabled, and disabled, no differences.
Are there, or have there been any known issues for SIP/VOIP in recent firmwares?
From my perspective, the development/testing/release process appears to have become more mature over the last couple of months. Releases are not being rushed out as they used to be; intead they seem to be more thoroughly tested. This is the right way to do it, Mikrotik team. I welcome this change and thank you for it!
A) Updated (from 6.19) n°2 RB411 to latest 6.28 (2015-04-13 16:00:53). I’ve experienced long time in ‘export’ function and I’ve tried to export to console screen (and not to file ..see attached image). Export stop at some point and log windows say ‘timeout while waiting for program 24’. Both the RB411 upgraded have the same behaviour. Rebooted two or three times ..no changes. Roterboot firmware is latest, I’ve also tried to re-firmware.
B) Updated (from 6.28rc20) n°1 RB2011 to 6.28 (2015-04-13 16:00:53). System health didn’t show any data and export have the same problem ad RB411. Rebooted two time ..problem disappeared.
C) Updated (from 6.27) n°1 CRS125 to 6.28 (2015-04-13 16:00:53) ..no problems.
I was told by support that the fetch/ssl bug (http://forum.mikrotik.com/t/tool-fetch-always-truncates-files-to-4096-bytes-when-using-https/86841/1) would be fixed in the next release, but the latest version (version: 6.28, build-time: Apr/13/2015 14:10:30) still doesn’t download more than 4096 bytes. I really hope this is fixed before the next release because I have some maintenance to do that would be vastly easier if this would work.
edit: romon is very interesting, i like the proxy winbox functionality with romon + new winbox. I can see how this could be quite powerful, i hope its heavily developed
