After upgrad from 5.26 to 6.31 i have a problem with connection from Android and iOS via OpenVPN/TUN
I’m using:
RouterOS v6.31
OpenVPN with TUN
OpenVPN for Android app
The problem is with TLS
When i used v5.26, OpenVPN wit TUN worked fine from Android and iOS
log:
2015-08-21 07:37:20 SIGUSR1[soft,connection-reset] received, process restarting
2015-08-21 07:37:20 MANAGEMENT: >STATE:1440135440,RECONNECTING,connection-reset,,
2015-08-21 07:37:23 MANAGEMENT: CMD 'hold release'
2015-08-21 07:37:23 MANAGEMENT: CMD 'bytecount 2'
2015-08-21 07:37:23 MANAGEMENT: CMD 'state on'
2015-08-21 07:37:23 MANAGEMENT: CMD 'proxy NONE'
2015-08-21 07:37:24 Control Channel MTU parms [ L:1543 D:1210 EF:40 EB:0 ET:0 EL:3 ]
2015-08-21 07:37:24 MANAGEMENT: >STATE:1440135444,RESOLVE,,,
2015-08-21 07:37:24 Data Channel MTU parms [ L:1543 D:1450 EF:43 EB:393 ET:0 EL:3 ]
2015-08-21 07:37:24 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1543,tun-mtu 1500,proto TCPv4_CLIENT,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
2015-08-21 07:37:24 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1543,tun-mtu 1500,proto TCPv4_SERVER,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
2015-08-21 07:37:24 TCP/UDP: Preserving recently used remote address: [AF_INET]22.22.255.32:443
2015-08-21 07:37:24 Socket Buffers: R=[1048576->131072] S=[524288->131072]
2015-08-21 07:37:24 Attempting to establish TCP connection with [AF_INET]22.22.255.32:443 [nonblock]
2015-08-21 07:37:24 MANAGEMENT: >STATE:1440135444,TCP_CONNECT,,,
2015-08-21 07:37:24 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2015-08-21 07:37:25 TCP connection established with [AF_INET]22.22.255.32:443
2015-08-21 07:37:25 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2015-08-21 07:37:25 TCP_CLIENT link local: (not bound)
2015-08-21 07:37:25 TCP_CLIENT link remote: [AF_INET]22.22.255.32:443
2015-08-21 07:37:25 MANAGEMENT: >STATE:1440135445,WAIT,,,
2015-08-21 07:37:25 MANAGEMENT: >STATE:1440135445,AUTH,,,
2015-08-21 07:37:25 TLS: Initial packet from [AF_INET]22.22.255.32:443, sid=6d588482 715603e3
2015-08-21 07:37:25 Connection reset, restarting [0]
2015-08-21 07:37:25 TCP/UDP: Closing socket
2015-08-21 07:37:25 SIGUSR1[soft,connection-reset] received, process restarting
2015-08-21 07:37:25 MANAGEMENT: >STATE:1440135445,RECONNECTING,connection-reset,,
2015-08-21 07:37:28 MANAGEMENT: CMD 'hold release'
2015-08-21 07:37:28 MANAGEMENT: CMD 'bytecount 2'
2015-08-21 07:37:28 MANAGEMENT: CMD 'state on'
2015-08-21 07:37:29 MANAGEMENT: CMD 'proxy NONE'
2015-08-21 07:37:30 Control Channel MTU parms [ L:1543 D:1210 EF:40 EB:0 ET:0 EL:3 ]
2015-08-21 07:37:30 MANAGEMENT: >STATE:1440135450,RESOLVE,,,
2015-08-21 07:37:30 Data Channel MTU parms [ L:1543 D:1450 EF:43 EB:393 ET:0 EL:3 ]
2015-08-21 07:37:30 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1543,tun-mtu 1500,proto TCPv4_CLIENT,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
2015-08-21 07:37:30 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1543,tun-mtu 1500,proto TCPv4_SERVER,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
2015-08-21 07:37:30 TCP/UDP: Preserving recently used remote address: [AF_INET]22.22.255.32:443
2015-08-21 07:37:30 Socket Buffers: R=[1048576->131072] S=[524288->131072]
2015-08-21 07:37:30 Attempting to establish TCP connection with [AF_INET]22.22.255.32:443 [nonblock]
2015-08-21 07:37:30 MANAGEMENT: >STATE:1440135450,TCP_CONNECT,,,
2015-08-21 07:37:30 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2015-08-21 07:37:31 TCP connection established with [AF_INET]22.22.255.32:443
2015-08-21 07:37:31 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2015-08-21 07:37:31 TCP_CLIENT link local: (not bound)
2015-08-21 07:37:31 TCP_CLIENT link remote: [AF_INET]22.22.255.32:443
2015-08-21 07:37:31 MANAGEMENT: >STATE:1440135451,WAIT,,,
2015-08-21 07:37:31 MANAGEMENT: >STATE:1440135451,AUTH,,,
2015-08-21 07:37:31 TLS: Initial packet from [AF_INET]22.22.255.32:443, sid=fdc85a6d ac17d955
2015-08-21 07:37:31 Connection reset, restarting [0]
2015-08-21 07:37:31 TCP/UDP: Closing socket
2015-08-21 07:37:31 SIGUSR1[soft,connection-reset] received, process restarting
2015-08-21 07:37:31 MANAGEMENT: >STATE:1440135451,RECONNECTING,connection-reset,,
2015-08-21 07:37:34 MANAGEMENT: CMD 'hold release'
2015-08-21 07:37:34 MANAGEMENT: CMD 'bytecount 2'
2015-08-21 07:37:34 MANAGEMENT: CMD 'state on'
2015-08-21 07:37:34 MANAGEMENT: CMD 'proxy NONE'
2015-08-21 07:37:35 MGMT: Got unrecognized command>FATAL:All connections have been connect-retry-max (5) times unsuccessful, exiting
2015-08-21 07:37:35 MANAGEMENT: Client disconnected
2015-08-21 07:37:35 All connections have been connect-retry-max (5) times unsuccessful, exiting
2015-08-21 07:37:35 Exiting due to fatal error
2015-08-21 07:37:35 Process exited with exit value 1
Wysłane z mojego HTC
