v6.32 released [version temporarily removed]
TEMPORARY DELAY due to Basebox 2 upgrade issue. Version pulled.
What's new in 6.32 (2015-Aug-31 14:47):
*) trafflow - added support for IPv6 targets;
*) switch - fixed port flapping on switch ports of RB750, RB750UP, RB751U-2HnD and RB951-2N (introduced in 6.31)
*) ipsec - added compatibility option skip-peer-id-check;
*) flash - fix kernel failure (exposed by 6.31);
*) bridge firewall - add ipv6 src/dst addr, ip protocol, src/dst port matching to bridge firewall;
*) RB911/RB912 - fix SPI bus lock after fast led blink;
*) ipsec - fix potential memory leak;
*) bridge firewall - vlan matchers support service tag - 0x88a8;
*) ippool6 - try to acquire the same prefix if info matches recently freed;
*) crs switch - allow to unset port learn-limit, new default is unset to allow more than 1023 hosts per port;
*) x86 - fixed 32bit multi-cpu kernel support;
*) chr - add hotspot,btest,traffgen support;
*) revised change that caused reboot by watchdog problems introduced in v6.31;
*) ipsec - use local-address for phase 1 matching and initiation;
*) ipsec - fix transport mode ph2 ID ports when policy selects specific ip protocol on initiator;
*) certificates -fixed bug where crl stopped working after a while;
*) ip accounting - fixed kernel crash;
*) snmp - fix system scripts get;
*) hotspot - ignore PoD remote requests if no HotSpot configured;
*) hotspot - fix kernel failure when www plugin aborts on broken html source;
*) torch - add invert filter for src/dst/src6/dst6 addresses ;
*) bonding - add min_links property for 802.3ad mode;
*) snmp - get vlan speed from master interface;
*) hotspot - fix html-directory path on small flash devices;
*) mipsbe - make system shutdown work again;
*) lcd - fixed parallel port LCD display support on multi-cpu x86;
*) bridge - fixed use-ip-firewall-for-vlan in setups with multiple bridges;
*) ipv6 - fixed DHCP-PD client skips some steps when renewing lease;
*) upnp - fixed protocol port selection for upnp protocol comunications;
*) firewall - fixed limit and dst-limit options.
*) winbox - fixed wireless interface l2mtu (VirtualAP and WDS interface creation in winbox)
*) winbox - fixed multiple firewall rule moving in Winbox 2
*) simple queues - restrict all changes in dynamic simple queues
Thanks for adding the 802.3ad min_links setting, and all the ipsec improvements. :slight_smile:
I don’t see a fix for loosing management access in some rare occasions after few minutes of uptime (ports are open, but can’t login). Is it even reproduced by Mikrotik staff and acknowledged as a bug ?
do you have a ticket number I could check ?
What bug? details? Have you actually written to support? Ticket number?
Over the years i find this type of posts completely useless and annoying in most cases solved by fixing configuration or networking problems
requesting more details on this =)
Nothing learned?
Again a new “current” version that is going to be downloaded by many in thinking that because it is “current” it is stable… A new disaster in the waiting?
6.30.4 is a better candidate for “Current” because it is fixed some times now (4x) without adding new features that might bring new bugs…
This 6.32 should still be a candidate. Only the first weeks will tell its stable…
WirelessRudy, please read the post about how the releases are done. I see you have not understood the terminology or release method.
There were numerous complaints about this in the v6.31 topic. I have not written to support, because I have only 1 affected device. It is not reachable (can’t login to make supout) and I can not powercycle it. I am waiting for some power outage so I can log in and upload older or newer fixed routeros.
Normis, please read all the confusion it has been given to many of us and all the suggestions given to improve the numbering.
The simple fact that a new “current” version is published with many new features that now is going to be ‘test’ by the ignorants or the ‘auto update script’ users is every time again creating a disaster. We’ve just seen it with 3.31…
This version CANNOT be stable only because you guys call it “Current”. This is proven over and over again and I don’t understand nothing is learned… :frowning:
Time will tell but this new 3.32 will probably cause havoc again…
translation of current:
current (adjective; cur·rent \ˈkər-ənt, ˈkə-rənt)
happening or existing now : belonging to or existing in the present time
example: /current month/
It means the one that is released now. It does not mean best or most stable.
use the bugfix branch and just do not open this topic. ignore it. you are not forced to test the new features
Normis: Release candidate (rc6) od web page is now older than current.
Remove RC from webpage until you have 6.33rc. It’s confusing…
And people should not necessarily a expect a 6.31.1 to happen, if 6.31 is so broken.
6.31 should be marked as withdrawn and not be downloadable anymore.
What confuses me is if this version 6.32, has the bug fixes of 6.30.4, or the only way to get that bugs fixed is to stay in 6.30.4 and never ever more update.
you are right
yes
6.32 has all the fixes from 6.30.4 + new features
but as you know, sometimes adding new stuff, can introduce unknown issues. this is why you can stay on 6.30.4 if you don’t need any particular thing from the above changelog
Hi everyone!
Just to report a failure with this version. We had a number of Basebox2 with R11e-5HacD daughterboards just waiting to be installed and we thought we would give it a try.
After upgrade, it would not let Winbox in. Http did not work either. Resetting configuration did not help. So we had to rollback to 6.30.4 via netinstall.
Kind regards,
Michael
Normis, we can’t make the supout file when this happens because the router losts access completely. No ssh, no winbox, telnet, mac-telnet etc. It just responds to pings. I noted that it needs a high usage pattern too. If the router stays on idle most the time this problem could not occur.
Broke 34 basebox2 with r11e too. Netinstall only exit. This can’t happen with a non RC release. please help. Hour of hard work for now because capsman2 auto update!
Which version did you guys upgrade from ?
