105547111 - Sorry, but I did not understand your question. Mangle rules are fixed in 6.33rc version. It means that fix will be included in 6.33 full version.
I meant what about version 6.32 is the dropping of mangle rules going to be fixed in the re-release of 6.32 or is a faster track to 6.33 going to happen?
I’ve got devices on 6.32 I don’t want to touch until either a 6.32 re-release with fixed mangle rules, or a 6.33 final. I couldn’t imagine a 6.32 would be re-released with the mangle dropping issue still left, but I’m asking to be sure…
*) ppp - fixed ppp interface stuck in not running state;
*) ipsec - fixed kernel failure when packets were not ordered on first call;
*) upnp - randomize action urls to fix “filet-o-firewall” vulnerability;
I would very much like to see the re-added feature to download the upgrade package manager, and so by default withdrew only stable version of the RC version but as it is now.
In an earlier Verich it was quite good and I do not understand why this is so changed, for us it’s a problem, because we have a lot of scripts that we have to change too.
For example, this is totally dysfunctional in the latest version:
/system package update check-for-updates; /system package update upgrade;
This script in scheduler will update again and again the same version.
During the same version will remain on disk packages and the next update with a different version take full disc.
Why do not you give the option manually selecting your own server. I do not want your last version. On own DNS server changes the DNS record (upgrade.mikrotik.com) on your own web server.
Add the option to enter your own url and show all the system directories on the web server. Each can then choose which version locally will be used depending on what you recorded on your own web server.
Same issue as before, “ether1 excessive broadcast/multicast”.
See attached image below.
Using a CRS112-8G-4S Firmware v3.23
Has this issue been looked at yet?
Back to v6.30.4 yet again..
