v6.34.1 [current] is released!
What’s new in 6.34.1 (2016-Feb-02 14:08):
*) interface - fixed stats that were 8x smaller;
*) traffic-monitor - fixed stats that were 8x smaller;
*) smips - properly detect smips boards for winbox & webfig.
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
Thanks Strods…will test it out!
Hardware: RB951Ui-2HnD
Problem: Web Proxy with External Storage
Tried using USB Flash Disk and USB External HDD, result the same. After formatting, select cache path, tick cache on disk, enable, Apply, message below written building cache. After message turns Running, enable transparent proxy, these problem occured:
  • web pages super slow to open (with 50mbps connection)
  • cache contents only contain few files
  • can’t clear cache
    The funny is, when I untick cache on disk, everything works correctly. Web pages opened super fast, cache containts full of files, and really can do clear cache.
The new Dude v6 looks promising.
Just playing with 6.34 when 6.34.1 came out.
I take it that the only way to upgrade an installed Dude package is to update the whole ROS.
My one issue is backward compatibilityt.
I have a few sub Agents, and upgrading all at once is going to be hard.
Keep up the good work !!
Using RB951G-2HnD with 6.34.1 makes my bonding interface with 2 ethernet interfaces stop working.
Using now the 6.35rc4 its working again.
Joao Eduardo
RB2011UiAS-2HnD is reporting Voltage as 0.0 V and no temperature too.
I on the other hand have the opposite problem with RB2011UAS-RM. It reports ~285 volts (!!) instread of ~23
No temperature too.
Numbers from SNMP
And winbox
But with the exact same configuration on a RB2011UiAS-RM there are no problems with voltage numbers or temperature.
495g reporting no voltage as well.
Wysłane z mojego HTC One przy użyciu Tapatalka
After update to this version, and some changing of wifi channels for testing, my mobile phone and tablet cannot connect automatically to wireless.
Hardware rb2011uias-2hnd-in.
Ros problem or something else?
IP----> Web Proxy---------> General-------> Port show : 0 from ROS 6.34, x86, (not solve this problem)
Intel Pro/1000 MT Duel Port Server Adapter do not work properly with ROS v6.x (x86)
Problem is : When I changed Interface ARP enable/reply only then ROS hang
General bug, I see it in every platforms that we have.
Is anyone able to change timezone with this version? I can’t seem to be able to do so. I hangs and I have to press ctrl+c.
Also, NTP is not updating the time on the router.
I have upgraded a router CCR, and today the CPU went 98 - 100% and when looking at profile it was caused by L7 rule. its a very simple rule to block website. Anybody else with same issue ?
thanks.
I wonder if you are using Apple devices and have not dealt much with WPA setups??
No issues here. Also tested on SXT G-5HnD.
No issues here, I verify on RB2011UiAS-2HnD, RB2011UiAS, RB3011UiAS
there is no such thing as simple L7 rule, all is same complexity for computing. Only question is how much traffic get to this rule - your task is to make it as few packets as possible. and WHY use L7 for website block - it is like killing flies with shotgun (overkill), yes, it works, but why use it? you need to use Static DNS entries or web proxy.
L7 rules should not be used to block websites. This is a very CPU intensive filter system and should be used to catch complex protocols. To block websites use the firewall or proxy access list.
Do you have a non ‘i’ (POE out) RB2011 to check?
I have two 2011 with the exact same configuration but one reports voltage properly (the ‘i’ model) and the other reports 285 volts as shown on my screenshots!
