v6.34.1 internal server error
I’m attempting to create a bridge across ports 3-5 and assign an IP to it, but after I do, I’m able to login via command line to the new IP/ports, but not the web GUI, which just says internal server error after you enter the username and password and then it dumps you back to the login screen. This is on a 750UPr-2 hEX PoE Lite. I think the same thing worked fine on old 750UP units, but not two of these new ones I’ve tried it on.
Where should I be looking at the command line to see where the issue is? Should I upgrade the OS?
