*) bonding - fixed crash on bonding slave release;
*) bonding - fixed mac-address disappearance after reboot in specific setups;
*) chr - fixed reboots with license and queues;
*) console - allow unknown scan-list names on wireless configuration to fix import;
*) ethernet - fixed Netmetal, QRT, DynaDish, SXT ac linking at 10/100Mbps (introduced in 6.34.x);
*) fastpath - fixed rare kernel failure;
*) ipsec - take into account ip protocol in kernel policy matcher;
*) mac-winbox - try to aggregate packets & resend all pending packets on timeout;
*) ppp - do not crash when received multiple CBCP packets;
*) ppp - fixed crash when ppp interface gets disconnected and user gets authenticated at the same time (most probable with slow RADIUS server);
*) quickset - fixed wan interface selection on devices with SFP interfaces;
*) quickset - use 5GHz interface instead of 2GHz interface on SXT Lite5 ac;
*) rb3011 - fixed high cpu load breaks ethernet stats;
*) rb3011 - fixed link down messages;
*) romon - fixed romon discovery after romon ID change;
*) timezone - fixed reboot by watchdog when selecting timezones from the end of list;
*) userman - fixed www crash;
*) winbox - allow to show revoked & authority flags at the same time;
*) winbox - correctly recognise if there is need to report fan information under system health;
*) winbox - do not use area v2 names instead of ospf v3 area names;
*) winbox - make mac-winbox work with RB850;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
So what happen earlier yesterday is after upgrading one of my test mikrotiks to v6.34.4 and we did some testings for ipv6 and after rebooting router my wireless interface disappeared, did couple of reboots and it was not there, the package was enabled and everything looked fine but after rebooting a router wireless interface disappeared, so i had to downgrade to 34.3
I don’t have support file, neither am able to send it right now, so just describing what happen. Hope it helps.
After upgrading from version 6.34.3 to 6.34.4 within a few hours the device (RB493G) stops responding over an SSTP VPN connection. The connection reports up on the CPE, but down on the VPN concentrator (CCR). The device is monitored over the SSTP connection using PING and SNMP.
Unfortunately after upgrading RB951G-2HnD to 6.34.4 my IPsec/L2TP from Android clients is not working.
Downgrading back to 6.32.4 solves the issue, but even upgrading to the latest 6.35rc45 is not working.
The connection just time-outs and does not give any particular error.
It seems that the router_os struggles to create dynamic policies for the SAs.
Thank you.
