Hello!
I have Dude 6.35.4 + RouterOS-x86 on server 4 core CPU, 2Gb RAM, Dude-db have size 350Mb.
When I turn on the server used RAM memory 1,2Gb, after 4 months used RAM volume increases to 1,7Gb.
When i do:
/dude export-db backup-file=backup_db
the amount of used RAM memory consumed is reduced to 1,2Gb
Why is this happening? Why does the consumption of RAM increase?
Thanks for the answer. The problem is that if this is a cache, then it can occupy all the RAM and the server will hang.
Can I somehow control or disable caching?
