*) l2tp - added support for proxy authentication when receiving forwarded PPPoE sesssions;
*) l2tp - added support for Hidden AVP, it is needed for proxy authentication;
I’m presuming this only means that LNS functionality is working and that I still cannot use Mikrotik as a LAC to do Proxy LCP to a Cisco PPPoE server?
I have two wireless stations where I want to use and share their connection as access point. I am using the first as the main and the second a backup.
I have used as below:
WLAN 1: Station 1
WLAN 2: AP
WLAN 3: Station 2
When routing only WLAN 3 as station to WLAN 2 as access point on high loads over 50kbps I am facing interruptions.
Any idea?
Many many many thanks for implementing fastpath over pppoe. It is a highe improvement to be able to keep using (and recommending) your routers to those people with ISPs using PPPoE.
*) dude - (changes discussed here: http://forum.mikrotik.com/t/the-dude-work-continues-v6-35rc-test-builds/94981/1);
*) pppoe-client - implemented fastpath support;
*) pppoe - added rfc4679 support;
*) pppoe-server - added pado-delay option;
*) ppp - close connection if peer wants to re-authenticate;
*) winbox - added missing modp8192 to /ipsec peer dh-group;
*) winbox - limit ospf key to 16 symbols;
*) snmp - fix cpu load reporting to 1min average and change oid to 1.3.6.1.4.1.2021.11.10.0;
*) mpls - do not reset VPLS on TE tunnel re-optimize;
*) lcd - add flip-screen option;
*) lcd - security screen did not show ip addresses on ccr;
*) interface queue - fixed “no-queue” on upgrade;
*) fastpath - fixed rare kernel failure;
*) lte - fixed bandlux modem dialing;
*) wireless-rep - fixed qos frame-priroty when nv2 protocol used in station-wds mode;
*) wireless - improved 1-chain 802.11ac station campability with other vendor multichain APs.
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
Any of rc versions can be skipped for multiple reasons. It could be bad, it could be waiting for additional fixes/implementation to work properly, next version can be built before we launch previous one. There are multiple possibilities and that do not mean anything at all.
*) l2tp - implemented l2tp (and lns) initial fastpath support;
*) ppp - fixed ppp crash;
*) gre - fixed memory leak;
*) netinstall - fixed link negotiation for different sfp modules;
*) snmp - fixed dhcpv4 lease hwaddr format according to mib;
*) rb3011 - fixed high cpu load breaks ethernet stats.
Same here, since 6.35rc14. PPtP not working either. “Encryption method not supported” even without encryption. Opened a support ticket with supout (Ticket#2016030266000632).
