v6.35rc [release candidate] is released, new wireless package!
nand - implemented once a week nand refresh to improve stored data integrity (will increase sector writes)
Also for USB Flash in x86 ?
uuuu…
*) nand - implemented once a week nand refresh to improve stored data integrity (will increase sector writes);
looks like v6.35 suddenly become my new favorite version.
Hi
I have 3011 and strange issues with port based VLANs [Ticket#2016031766000506] - could someone confirm same problems?
I have separate topic for that problem http://forum.mikrotik.com/t/vlans-on-3011-without-bridge-strange-problems/96537/1
Regards
Slawek
When will this version become release?
What setup you have on the CAPsMAN for the CAP interface?
What is your wireless client and what OS you use?
when upgrading back to v6.35rc42 to try to reproduce, we didnt see the same behavior anymore.
CAPSMAN platform: ccr1009
caps: rb951g/rb951ui/hap ac lite
client: MacOS 10.11.4 - macbookair 7,2 - Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
@strods
And what about the problem with OSPFv3 with EdgeRouter, mikrotik reject EdgeRouter OSPFv3 because of a flag AF which EdgeRouter sends, but in RFC says that unrecognized bits should be ignored.
Was central user control/access point protection/locking from capsman already suggested?
It’s kinda boring to login to 40+ access points to password protect them. :wink:
FastTrack doesn’t work at RB750G.
Version 6.35rc44 has been released.
Changes since previous version:
*) chr - try to renew expired license once a hour instead of 100h;
*) defconf - fixed default configuration for SXT LTE;
*) lte - improve situation when SXT modem never finds operator;
*) lte - supported modems now use unsolicited events for network monitoring;
*) rb3011 - make ether6-ether10 work if SFP module is present on bootup;
*) trafficgen - fixed console arguments;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
There is a serious bug introduced in rc44 for my CCR1036. After upgrade reboot, the L2MTU values for both sfp+ ports changed to 1580 from their original values of 9014. To make matter worse, neither Winbox nor console allows you to change the L2MTU back to their original values.
Version 6.35rc45 has been released.
*) hotspot - make video tag work properly on hotspot login.html page
*) ipsec - fixed crash on policy update;
*) ppp - fixed ppp crash if lcp packets were lost and authentication got delayed;
My two STX 5AC are death after upgrade to this version! No access, so no suppot.rif. Tomorrow netinstall.
Since rc42 our test CCR1036 has stopped on “starting kernel” when rebooting after the update.
same issue, upgraded from 6.35rc44 to 6.35rc45, fails to boot falls back to backup partition
same issue with 91xG 2HPnD
After the update the router is unavailable.
netinstall not help restore operability
reset is also not effective - sound can be heard, blinking LEDS forming, but a router is not available.
On update from 6.35rc43 to 6.35rc45 my RB951G-2HnD got boot-loop :confused:
How i can recover him?
On my CRS too, need to netinstall
Same thing here with RB2011UiAS-2HnD-IN. Tried many times to Netinstall. The router always tries Ethernet boot, fails then says kernel failure before rebooting itself.
same thing on BASEBOX2 and RB450G
on RB450 using serial pot i get the kernel panic information that no system found
so i think that when start the process uninstalling the old one an installing the news on it crash so there is no system at all
via netinstall i was able to put rc45 up with no problem
