v6.35rc [release candidate] is released, new wireless package!
Is this config the right way?
first interface wireless - ap-bridge
second inteface wireless (virtual) - station pseudobridge
what is the right setup from wds in station pseudobridge? disabled? or static with wds default bridge set to bridge?
For now I think this Setup is much estable as the old WDS configuration? :laughing:
Iám using 912UAG-2HPnD Basebox with two Antenas Omni 15 dbi !
My Question is why the AP Interface do not show traffic = the station Interface?
PeterDoBrasil, the configuration is ok. there is no need to WDS as this virtual wireless station interface works without WDS.
My Hotspot Stops to work correctly! Is this an Address translation prolem because the new pseudobridge setup?
feb/ 2/2016 11:59:12 by RouterOS 6.34
software id = KPNX-1FGN
11:28:15 system,info router rebooted
11:28:23 script,error Google Down
11:28:23 script,error 5g.net 1 Down
11:28:23 script,error 5g.net 2 Down
11:28:25 hotspot,debug Hotspot: bypassed host 08:2E:5F:75:6C:56/10.63.192.255 added, ip 10.63.192.255
11:28:25 hotspot,debug Hotspot: bypassed host 4C:5E:0C:CA:05:46/10.63.192.3 added, ip 10.63.192.3
11:28:25 hotspot,debug Hotspot: bypassed host 4C:5E:0C:C4:53:F7/10.63.192.4 added, ip 10.63.192.4
11:28:25 hotspot,debug Hotspot: bypassed host 5C:C9:D3:0D:D1:AD/10.63.192.254 added, ip 10.63.192.254
11:28:25 hotspot,debug Hotspot: bypassed host 4C:5E:0C:C4:41:BE/10.63.192.2 added, ip 10.63.192.2
11:28:25 hotspot,debug Hotspot: bypassed host 4C:5E:0C:C4:4D:F9/10.63.192.5 added, ip 10.63.192.5
11:28:26 interface,info eth1 link up (speed 100M, full duplex)
11:28:26 interface,info eth2 link up (speed 1G, full duplex)
11:28:26 interface,info eth9 link up (speed 100M, full duplex)
11:28:26 dhcp,info dhcp-client on eth1 got IP address 192.168.33.2
11:28:27 interface,info eth7 link up
11:28:28 dhcp,info switch2 deassigned 172.16.0.2 from 3C:E5:B4:0D:0D:27
11:28:28 dhcp,info switch2 assigned 172.16.0.2 to 3C:E5:B4:0D:0D:27
11:28:29 hotspot,debug Hotspot: bypassed host 10.63.192.255 moved to bridge port from <>
11:28:30 wireless,info 94:51:03:D3:B6:B8@wlan: connected
11:28:58 dhcp,info Hotspot assigned 10.63.192.253 to 94:51:03:D3:B6:B8
11:28:58 hotspot,debug Hotspot: new host detected 94:51:03:D3:B6:B8/10.63.192.253 by UDP :26098 -> 10.63.192.1:53
11:28:58 hotspot,debug Hotspot: static host 94:51:03:D3:B6:B8/10.63.192.253 added, ip 10.63.192.253
11:28:59 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
11:29:00 script,warning Google Up
11:29:29 system,info device changed by ersitizastes
11:29:31 interface,info eth10 link up (speed 100M, full duplex)
11:29:53 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :53828 -> 10.63.192.1:53
11:29:53 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:29:57 hotspot,debug Hotspot: bypassed host 10.63.192.3 moved to bridge port from <>
11:29:57 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.76 by UDP :11266 -> 10.63.192.1:53
11:29:57 hotspot,debug Hotspot: dynamic host 34:FC:EF:CF:50:24/10.63.193.76 added, ip 10.63.193.76
11:29:59 hotspot,debug Hotspot: bypassed host 10.63.192.2 moved to bridge port from <>
11:30:00 system,info hotspot user profile 00 changed by ersitizastes
11:30:00 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
11:30:25 script,warning 5g.net 1 Up
11:30:35 dhcp,info Hotspot assigned 10.63.193.75 to 60:72:0D:39:1F:9A
11:30:41 dhcp,info Hotspot assigned 10.63.193.74 to F8:95:C7:CF:4F:AF
11:30:44 hotspot,debug Hotspot: new host detected F8:95:C7:CF:4F:AF/10.63.193.74 by UDP :18710 -> 10.63.192.1:53
11:30:44 hotspot,debug Hotspot: dhcp host F8:95:C7:CF:4F:AF/10.63.193.74 added, ip 10.63.193.74
11:30:47 wireless,info 94:51:03:D3:B6:B8@wlan: disconnected, extensive data loss
11:30:58 hotspot,debug Hotspot: static host 10.63.192.253 removed: login timeout
11:31:00 script,warning 5g.net 2 Up
11:31:01 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :14001 -> 10.63.192.1:53
11:31:01 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:31:44 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :18764 -> 10.63.192.1:53
11:31:44 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.46: max addresses per mac is reached
11:31:48 dhcp,info Hotspot assigned 10.63.193.46 to F8:A9:D0:5E:6A:9F
11:31:54 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:31:57 hotspot,debug Hotspot: dynamic host 10.63.193.76 removed: login timeout
11:31:59 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.76 by UDP :41705 -> 10.63.192.1:53
11:31:59 hotspot,debug Hotspot: dynamic host 34:FC:EF:CF:50:24/10.63.193.76 added, ip 10.63.193.76
11:32:01 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:32:04 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:32:06 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:32:07 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:32:08 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:32:10 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:32:10 wireless,info 94:51:03:D3:B6:B8@wlan: connected
11:32:12 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :41167 -> 10.63.192.1:53
11:32:12 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:32:13 hotspot,debug Hotspot: new host detected 94:51:03:D3:B6:B8/10.63.192.253 by TCP :34668 -> 74.125.141.188:5228
11:32:13 hotspot,debug Hotspot: static host 94:51:03:D3:B6:B8/10.63.192.253 added, ip 10.63.192.253
11:32:14 dhcp,info Hotspot assigned 10.63.193.45 to 14:32:D1:1C:E1:6E
11:32:15 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.45 by UDP :40340 -> 10.63.192.1:53
11:32:15 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.45, ip 10.63.193.43: max addresses per mac is reached
11:32:24 dhcp,info Hotspot assigned 10.63.193.42 to 3C:18:9F:33:05:31
11:32:44 hotspot,debug Hotspot: dhcp host 10.63.193.74 removed: login timeout
11:32:45 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :54175 -> 10.63.192.1:53
11:32:45 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:32:49 dhcp,info Hotspot deassigned 10.63.193.46 from F8:A9:D0:5E:6A:9F
11:33:06 dhcp,info Hotspot assigned 10.63.193.40 to 44:91:DB:51:5E:EB
11:33:06 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.42 by UDP :60411 -> 10.63.192.1:53
11:33:06 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.42, ip 10.63.193.43: max addresses per mac is reached
11:33:11 dhcp,info Hotspot assigned 10.63.193.41 to 30:19:66:27:D9:9F
11:33:12 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :63309 -> 10.63.192.1:53
11:33:12 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:33:13 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :34466 -> 10.63.192.1:53
11:33:13 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:33:37 dhcp,info Hotspot assigned 10.63.193.39 to 88:9B:39:D0:AB:19
11:33:38 hotspot,debug Hotspot: new host detected 88:9B:39:D0:AB:19/10.63.193.39 by UDP :19652 -> 10.63.192.1:53
11:33:38 hotspot,debug Hotspot: dhcp host 88:9B:39:D0:AB:19/10.63.193.39 added, ip 10.63.193.39
11:33:59 hotspot,debug Hotspot: dynamic host 10.63.193.76 removed: login timeout
11:34:12 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :13730 -> 10.63.192.1:53
11:34:12 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:34:13 hotspot,debug Hotspot: static host 10.63.192.253 removed: login timeout
11:34:17 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by TCP :43245 -> 108.168.176.243:80
11:34:17 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:34:54 dhcp,info Hotspot assigned 10.63.193.50 to 18:22:7E:2A:5A:5E
11:35:08 dhcp,info Hotspot deassigned 10.63.193.50 from 18:22:7E:2A:5A:5E
11:35:13 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :51145 -> 10.63.192.1:53
11:35:13 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:35:15 dhcp,info Hotspot assigned 10.63.193.60 to 00:9F:08:01:5A:11
11:35:31 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :59871 -> 10.63.192.1:53
11:35:31 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:35:31 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/100.64.13.255 by TCP :60463 -> 216.58.222.106:443
11:35:31 hotspot,debug Hotspot: dynamic host 34:FC:EF:CF:50:24/100.64.13.255 added, ip 10.63.193.76
11:35:32 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.76 by UDP :31887 -> 10.63.192.1:53
11:35:32 hotspot,debug Hotspot: failed to add dynamic host 34:FC:EF:CF:50:24/10.63.193.76, ip 10.63.193.76: to-address is already used
11:35:35 hotspot,debug Hotspot: new host detected 94:51:03:D3:B6:B8/10.63.192.253 by TCP :45967 -> 74.125.141.188:5228
11:35:35 hotspot,debug Hotspot: static host 94:51:03:D3:B6:B8/10.63.192.253 added, ip 10.63.192.253
11:35:38 hotspot,debug Hotspot: dhcp host 10.63.193.39 removed: login timeout
11:36:16 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :33412 -> 10.63.192.1:53
11:36:16 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:36:33 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by TCP :41661 -> 158.85.58.15:5222
11:36:33 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:36:33 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.76 by UDP :21894 -> 10.63.192.1:53
11:36:33 hotspot,debug Hotspot: failed to add dynamic host 34:FC:EF:CF:50:24/10.63.193.76, ip 10.63.193.76: to-address is already used
11:36:54 dhcp,info Hotspot assigned 10.63.193.38 to 00:F4:6F:F6:0A:DF
11:36:56 hotspot,debug Hotspot: new host detected 00:F4:6F:F6:0A:DF/10.63.193.38 by UDP :36811 -> 10.63.192.1:53
11:36:56 hotspot,debug Hotspot: dhcp host 00:F4:6F:F6:0A:DF/10.63.193.38 added, ip 10.63.193.38
11:37:21 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :34072 -> 10.63.192.1:53
11:37:21 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:37:31 hotspot,debug Hotspot: dynamic host 10.63.193.76 removed: login timeout
11:37:33 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.76 by UDP :1169 -> 10.63.192.1:53
11:37:33 hotspot,debug Hotspot: dynamic host 34:FC:EF:CF:50:24/10.63.193.76 added, ip 10.63.193.76
11:37:34 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by TCP :50139 -> 174.36.210.48:80
11:37:34 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:37:35 hotspot,debug Hotspot: static host 10.63.192.253 removed: login timeout
11:37:53 dhcp,info Hotspot assigned 10.63.193.46 to F8:A9:D0:5E:6A:9F
11:37:54 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :1405 -> 10.63.192.1:53
11:37:54 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:38:21 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :12764 -> 10.63.192.1:53
11:38:21 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:38:40 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by TCP :58368 -> 173.192.222.176:5222
11:38:40 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:38:54 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :43736 -> 10.63.192.1:53
11:38:54 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:38:56 hotspot,debug Hotspot: dhcp host 10.63.193.38 removed: login timeout
11:39:22 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :59533 -> 10.63.192.1:53
11:39:22 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:39:31 wireless,info 94:51:03:D3:B6:B8@wlan: disconnected, extensive data loss
11:39:33 hotspot,debug Hotspot: dynamic host 10.63.193.76 removed: login timeout
11:39:40 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.76 by UDP :4063 -> 10.63.192.1:53
11:39:40 hotspot,debug Hotspot: dynamic host 34:FC:EF:CF:50:24/10.63.193.76 added, ip 10.63.193.76
11:39:41 dhcp,info Hotspot assigned 10.63.193.37 to 34:FC:EF:CF:50:24
11:39:45 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.37 by UDP :9080 -> 10.63.192.1:53
11:39:45 hotspot,debug Hotspot: dynamic host 10.63.193.76 removed: limiting addresses per mac
11:39:45 hotspot,debug Hotspot: dhcp host 34:FC:EF:CF:50:24/10.63.193.37 added, ip 10.63.193.37
11:39:56 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :48853 -> 10.63.192.1:53
11:39:56 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:40:26 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :28569 -> 10.63.192.1:53
11:40:26 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:40:35 dhcp,info Hotspot assigned 10.63.193.36 to 9C:D3:5B:51:B7:AE
11:40:36 hotspot,debug Hotspot: new host detected 9C:D3:5B:51:B7:AE/10.63.193.36 by UDP :39596 -> 10.63.192.1:53
11:40:36 hotspot,debug Hotspot: dhcp host 9C:D3:5B:51:B7:AE/10.63.193.36 added, ip 10.63.193.36
11:40:51 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :49592 -> 10.63.192.1:53
11:40:51 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:41:01 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :38436 -> 10.63.192.1:53
11:41:01 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:41:10 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:41:28 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :30119 -> 10.63.192.1:53
11:41:28 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:41:45 hotspot,debug Hotspot: dhcp host 10.63.193.37 removed: login timeout
11:41:45 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.37 by UDP :36887 -> 10.63.192.1:53
11:41:45 hotspot,debug Hotspot: dhcp host 34:FC:EF:CF:50:24/10.63.193.37 added, ip 10.63.193.37
11:42:04 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :31373 -> 10.63.192.1:53
11:42:04 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:42:10 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:42:21 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:42:21 wireless,info 94:51:03:D3:B6:B8@wlan: connected
11:42:26 hotspot,debug Hotspot: new host detected 94:51:03:D3:B6:B8/10.63.192.253 by UDP :34378 -> 10.63.192.1:53
11:42:26 hotspot,debug Hotspot: static host 94:51:03:D3:B6:B8/10.63.192.253 added, ip 10.63.192.253
11:42:26 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :6429 -> 10.63.192.1:53
11:42:26 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:42:36 hotspot,debug Hotspot: dhcp host 10.63.193.36 removed: login timeout
11:43:04 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :63921 -> 10.63.192.1:53
11:43:04 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:43:07 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :56948 -> 10.63.192.1:53
11:43:07 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:43:45 hotspot,debug Hotspot: dhcp host 10.63.193.37 removed: login timeout
11:43:46 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :3360 -> 10.63.192.1:53
11:43:46 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:43:57 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.37 by UDP :59609 -> 10.63.192.1:53
11:43:57 hotspot,debug Hotspot: dhcp host 34:FC:EF:CF:50:24/10.63.193.37 added, ip 10.63.193.37
11:44:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :27895 -> 10.63.192.1:53
11:44:05 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:44:08 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :65040 -> 10.63.192.1:53
11:44:08 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:44:26 hotspot,debug Hotspot: static host 10.63.192.253 removed: login timeout
11:44:31 hotspot,debug Hotspot: new host detected 94:51:03:D3:B6:B8/10.63.192.253 by UDP :65422 -> 10.63.192.1:53
11:44:31 hotspot,debug Hotspot: static host 94:51:03:D3:B6:B8/10.63.192.253 added, ip 10.63.192.253
11:44:38 dhcp,info Hotspot assigned 10.63.193.34 to B8:5A:73:A8:5B:84
11:44:41 hotspot,debug Hotspot: new host detected B8:5A:73:A8:5B:84/10.63.193.34 by UDP :51462 -> 10.63.192.1:53
11:44:41 hotspot,debug Hotspot: dhcp host B8:5A:73:A8:5B:84/10.63.193.34 added, ip 10.63.193.34
11:44:48 wireless,info 94:51:03:D3:B6:B8@wlan: disconnected, extensive data loss
11:44:50 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:44:51 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:44:55 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:45:00 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:45:01 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :64102 -> 10.63.192.1:53
11:45:01 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:45:05 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:45:07 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :27505 -> 10.63.192.1:53
11:45:07 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:45:10 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:45:10 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :44628 -> 10.63.192.1:53
11:45:10 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:45:11 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:45:12 wireless,info wlan: data from unknown device 94:51:03:D3:B6:B8, sent deauth
11:45:57 hotspot,debug Hotspot: dhcp host 10.63.193.37 removed: login timeout
11:45:59 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.37 by TCP :55573 -> 216.58.202.42:443
11:45:59 hotspot,debug Hotspot: dhcp host 34:FC:EF:CF:50:24/10.63.193.37 added, ip 10.63.193.37
11:46:08 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :26897 -> 10.63.192.1:53
11:46:08 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:46:13 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :26195 -> 10.63.192.1:53
11:46:13 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:46:20 hotspot,debug Hotspot: new host detected F8:95:C7:CF:4F:AF/10.63.193.74 by UDP :50490 -> 10.63.192.1:53
11:46:20 hotspot,debug Hotspot: dhcp host F8:95:C7:CF:4F:AF/10.63.193.74 added, ip 10.63.193.74
11:46:22 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :25845 -> 10.63.192.1:53
11:46:22 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:46:31 hotspot,debug Hotspot: static host 10.63.192.253 removed: login timeout
11:46:41 hotspot,debug Hotspot: dhcp host 10.63.193.34 removed: login timeout
11:46:53 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
11:47:08 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :13439 -> 10.63.192.1:53
11:47:08 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:47:16 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by TCP :40428 -> 158.85.58.105:5222
11:47:16 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:47:23 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by TCP :52470 -> 158.85.58.11:5222
11:47:23 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:47:26 dhcp,info Hotspot assigned 10.63.193.172 to F4:F1:E1:1E:3A:2C
11:47:33 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.193.172 by UDP :37541 -> 10.63.192.1:53
11:47:33 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.193.172 added, ip 10.63.193.172
11:47:59 hotspot,debug Hotspot: dhcp host 10.63.193.37 removed: login timeout
11:48:10 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :19285 -> 10.63.192.1:53
11:48:10 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:48:17 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by TCP :55889 -> 173.192.222.169:80
11:48:17 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:48:20 hotspot,debug Hotspot: dhcp host 10.63.193.74 removed: login timeout
11:48:24 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :65450 -> 10.63.192.1:53
11:48:24 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:49:04 hotspot,debug Hotspot: new host detected 34:FC:EF:CF:50:24/10.63.193.37 by UDP :32891 -> 10.63.192.1:53
11:49:04 hotspot,debug Hotspot: dhcp host 34:FC:EF:CF:50:24/10.63.193.37 added, ip 10.63.193.37
11:49:10 hotspot,debug Hotspot: new host detected F8:95:C7:CF:4F:AF/10.63.193.74 by UDP :31988 -> 8.8.8.8:53
11:49:10 hotspot,debug Hotspot: dhcp host F8:95:C7:CF:4F:AF/10.63.193.74 added, ip 10.63.193.74
11:49:19 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by TCP :51064 -> 173.193.230.112:5222
11:49:19 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.106, ip 10.63.193.106: max addresses per mac is reached
11:49:20 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :30275 -> 10.63.192.1:53
11:49:20 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.41, ip 10.63.193.43: max addresses per mac is reached
11:49:27 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by TCP :54487 -> 158.85.58.47:80
11:49:27 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.46, ip 10.63.193.43: max addresses per mac is reached
11:49:33 hotspot,debug Hotspot: dhcp host 10.63.193.172 removed: login timeout
11:49:49 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.193.172 by TCP :40155 -> 216.58.222.14:80
11:49:49 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.193.172 added, ip 10.63.193.172
11:50:21 system,info hotspot server Hotspot changed by ersitizastes
11:50:23 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :46256 -> 10.63.192.1:53
11:50:23 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.106 added, ip 10.63.193.106
11:50:58 dhcp,info Hotspot assigned 10.63.193.50 to 18:22:7E:2A:5A:5E
11:50:58 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by UDP :41457 -> 10.63.192.1:53
11:50:58 hotspot,debug Hotspot: dynamic host 10.63.193.106 removed: limiting addresses per mac
11:50:58 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.43
11:51:04 hotspot,debug Hotspot: dhcp host 10.63.193.37 removed: login timeout
11:51:04 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :54443 -> 10.63.192.1:53
11:51:04 hotspot,debug Hotspot: dynamic host 10.63.193.43 removed: limiting addresses per mac
11:51:04 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.106 added, ip 10.63.193.106
11:51:04 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :16757 -> 10.63.192.1:53
11:51:04 hotspot,debug Hotspot: dynamic host 10.63.193.106 removed: limiting addresses per mac
11:51:04 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.46 added, ip 10.63.193.43
11:51:04 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by UDP :18646 -> 10.63.192.1:53
11:51:04 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.30
11:51:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :57375 -> 10.63.192.1:53
11:51:05 hotspot,debug Hotspot: dynamic host 10.63.193.30 removed: limiting addresses per mac
11:51:05 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.46 added, ip 10.63.193.43
11:51:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by TCP :42518 -> 192.12.31.106:5228
11:51:05 hotspot,debug Hotspot: dynamic host 10.63.193.43 removed: limiting addresses per mac
11:51:05 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.30
11:51:06 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :48778 -> 10.63.192.1:53
11:51:06 hotspot,debug Hotspot: dynamic host 10.63.193.30 removed: limiting addresses per mac
11:51:06 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.46 added, ip 10.63.193.29
11:51:06 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by UDP :12765 -> 10.63.192.1:53
11:51:06 hotspot,debug Hotspot: dynamic host 10.63.193.29 removed: limiting addresses per mac
11:51:06 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.30
11:51:06 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.46 by UDP :46609 -> 10.63.192.1:53
11:51:07 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by UDP :17912 -> 10.63.192.1:53
11:51:07 hotspot,debug Hotspot: dynamic host 10.63.193.29 removed: limiting addresses per mac
11:51:07 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.28
11:51:09 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by UDP :54443 -> 10.63.192.1:53
11:51:09 hotspot,debug Hotspot: dynamic host 10.63.193.28 removed: limiting addresses per mac
11:51:09 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.106 added, ip 10.63.193.106
11:51:09 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by UDP :18646 -> 10.63.192.1:53
11:51:09 hotspot,debug Hotspot: dynamic host 10.63.193.106 removed: limiting addresses per mac
11:51:09 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.28
11:51:10 hotspot,debug Hotspot: dhcp host 10.63.193.74 removed: login timeout
11:51:23 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by TCP :59268 -> 174.36.251.211:80
11:51:23 hotspot,debug Hotspot: dynamic host 10.63.193.28 removed: limiting addresses per mac
11:51:23 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.106 added, ip 10.63.193.106
11:51:23 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by UDP :25091 -> 10.63.192.1:53
11:51:23 hotspot,debug Hotspot: dynamic host 10.63.193.106 removed: limiting addresses per mac
11:51:23 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.28
11:51:28 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :3064 -> 10.63.192.1:53
11:51:28 hotspot,debug Hotspot: dynamic host 10.63.193.28 removed: limiting addresses per mac
11:51:28 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.41 added, ip 10.63.193.27
11:51:30 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by UDP :34255 -> 10.63.192.1:53
11:51:30 hotspot,debug Hotspot: dynamic host 10.63.193.27 removed: limiting addresses per mac
11:51:30 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.28
11:51:31 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.106 by TCP :59268 -> 174.36.251.211:80
11:51:31 hotspot,debug Hotspot: dynamic host 10.63.193.28 removed: limiting addresses per mac
11:51:31 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.106 added, ip 10.63.193.106
11:51:31 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by TCP :59365 -> 54.215.19.103:80
11:51:31 hotspot,debug Hotspot: dynamic host 10.63.193.106 removed: limiting addresses per mac
11:51:31 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.27
11:51:33 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.41 by UDP :3064 -> 10.63.192.1:53
11:51:33 hotspot,debug Hotspot: dynamic host 10.63.193.27 removed: limiting addresses per mac
11:51:33 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.41 added, ip 10.63.193.26
11:51:33 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.50 by UDP :8999 -> 10.63.192.1:53
11:51:33 hotspot,debug Hotspot: dynamic host 10.63.193.26 removed: limiting addresses per mac
11:51:33 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.50 added, ip 10.63.193.27
11:51:35 hotspot,debug Hotspot: bypassed host 10.63.192.255 removed: server stopped
11:51:35 hotspot,debug Hotspot: bypassed host 10.63.192.3 removed: server stopped
11:51:35 hotspot,debug Hotspot: bypassed host 10.63.192.4 removed: server stopped
11:51:35 hotspot,debug Hotspot: bypassed host 10.63.192.254 removed: server stopped
11:51:35 hotspot,debug Hotspot: bypassed host 10.63.192.2 removed: server stopped
11:51:35 hotspot,debug Hotspot: bypassed host 10.63.192.5 removed: server stopped
11:51:35 hotspot,debug Hotspot: dhcp host 10.63.193.172 removed: server stopped
11:51:35 hotspot,debug Hotspot: dynamic host 10.63.193.27 removed: server stopped
11:51:35 system,info hotspot server Hotspot changed by ersitizastes
11:52:25 dhcp,info Hotspot assigned 10.63.193.25 to 58:A2:B5:DA:FD:96
11:53:40 dhcp,info Hotspot assigned 10.63.193.97 to 18:89:5B:3B:83:67
11:53:59 dhcp,info Hotspot deassigned 10.63.192.253 from 94:51:03:D3:B6:B8
11:54:03 dhcp,info Hotspot assigned 10.63.193.31 to 18:89:5B:0C:17:72
11:54:05 system,info simple queue added by ersitizastes
11:54:29 dhcp,info Hotspot assigned 10.63.193.84 to 9C:65:B0:E0:B1:45
11:54:32 dhcp,info Hotspot deassigned 10.63.193.25 from 58:A2:B5:DA:FD:96
11:54:32 dhcp,info Hotspot assigned 10.63.193.25 to 58:A2:B5:DA:FD:96
11:54:42 dhcp,info Hotspot assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
11:55:10 dhcp,info Hotspot assigned 10.63.193.35 to EC:88:92:40:CC:8B
11:55:17 system,info simple queue changed by ersitizastes
11:56:29 system,info DHCP server dhcp1 changed by ersitizastes
11:58:10 dhcp,info dhcp1 deassigned 10.63.193.37 from 34:FC:EF:CF:50:24
11:58:29 system,info hotspot server Hotspot changed by ersitizastes
11:58:38 system,info,account user ersitizastes logged in from 10.63.192.255 via telnet
I've found this dynamic Nat rule after remove the hotspot, from where comes this rule?
[ersitizastes@5g.net 0] > /ip firewall nat print detail
0 chain=srcnat action=masquerade out-interface=eth1 log=no log-prefix=""
1 D ;;; upnp 10.63.192.255: Teredo
chain=dstnat action=dst-nat to-addresses=10.63.192.255 to-ports=61355 protocol=udp dst-address=192.168.33.2 in
dst-port=61355 log=no log-prefix=""
Maybe the question is missed… There is no ‘default authenticate’ option tickbox anymore…
For me is still there…
I can confirm that too.
The option is missing when using the interface in Station mode. In AP mode it is available as shown in your screenshot
Info from wiki:
http://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#Scan
been havent troubble connecting whit client since 6.34rc43 server is vmware
Client trows something whit 10061 no connection but i cant read the rest
PeterDoBrasil, please look at this wiki page which explains more about the station modes in the RouterOS.
If your AP is RouterOS based then try to switch from station-pseudobridge to station-bridge.
http://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes
The new configuration causes big trouble on my Hotspot Network! The Hotspot host shows many diferent IP addresses for only one Mac Address, the Mac is from my outside AP, Translation doesn't work!!!!!
/ip hotspot host print
Flags: S - static, H - DHCP, D - dynamic, A - authorized, P - bypassed
MAC-ADDRESS ADDRESS TO-ADDRESS SERVER IDLE-TIMEOUT
0 SP ;;; 5g.net 1
4C:5E:0C:C4:41:BE 10.63.192.2 10.63.192.2 Hotspot
1 SP ;;; 5g.net 3
4C:5E:0C:C4:53:F8 10.63.192.4 10.63.192.4 Hotspot
2 SP ;;; HP Ether
08:2E:5F:75:6C:56 10.63.192.255 10.63.192.255 Hotspot
3 SP ;;; 5g.net 4
4C:5E:0C:C4:4D:FA 10.63.192.5 10.63.192.5 Hotspot
4 SP ;;; 5g.net 2
4C:5E:0C:CA:05:46 10.63.192.3 10.63.192.3 Hotspot
5 HA 64:6C:B2:51:9E:0D 10.63.194.67 10.63.194.67 Hotspot
6 HA 00:F4:6F:F6:0A:DF 10.63.194.84 10.63.194.84 Hotspot
7 D 4C:5E:0C:CA:05:46 10.63.193.28 10.63.193.150 Hotspot
8 D 4C:5E:0C:CA:05:46 10.63.194.18 10.63.194.86 Hotspot
9 D 4C:5E:0C:CA:05:46 10.63.193.59 10.63.194.29 Hotspot
10 H 74:BA:DB:04:26:13 10.63.194.28 10.63.194.28 Hotspot
11 H F4:F1:E1:F4:62:F6 10.63.193.3 10.63.193.3 Hotspot
12 H 84:11:9E:C3:1F:FE 10.63.194.87 10.63.194.87 Hotspot
13 HA 0C:B3:19:E9:AE:30 10.63.194.85 10.63.194.85 Hotspot
14 H 10:D3:8A:17:AB:26 10.63.194.88 10.63.194.88 Hotspot
15 H 38:2D:D1:A5:04:39 10.63.193.23 10.63.193.23 Hotspot
4C:5E:0C:CA:05:46 is the Mac Address from my AP; pseudobridge
/log print
feb/ 2/2016 22:17:40 by RouterOS 6.33
feb/02 19:00:31 system,error,critical router was rebooted without proper shutdown
feb/02 19:00:37 interface,info ether1 link up (speed 100M, full duplex)
feb/02 19:00:37 interface,info ether2 link up (speed 1G, full duplex)
feb/02 19:00:37 interface,info ether9 link up (speed 100M, full duplex)
feb/02 19:00:39 dhcp,info 172.16 deassigned 172.16.0.2 from 3C:E5:B4:0D:0D:27
feb/02 19:00:40 dhcp,info dhcp-client on ether1 got IP address 192.168.33.2
feb/02 19:00:40 interface,info ether10 link up (speed 100M, full duplex)
feb/02 19:00:42 dhcp,info 172.16 assigned 172.16.0.2 to 3C:E5:B4:0D:0D:27
feb/02 19:30:47 wireless,info 60:D7:AE:C8:92:CC@wlan: connected
feb/02 19:30:59 dhcp,info Hotspot assigned 10.63.193.5 to 74:BA:DB:04:26:13
feb/02 19:31:00 dhcp,info Hotspot deassigned 10.63.193.16 from 9C:D3:5B:51:B7:AE
feb/02 19:31:03 dhcp,info Hotspot deassigned 10.63.193.23 from 38:2D:D1:A5:04:39
feb/02 19:31:03 dhcp,info Hotspot assigned 10.63.193.23 to 38:2D:D1:A5:04:39
feb/02 19:31:04 dhcp,info Hotspot assigned 10.63.193.16 to 9C:D3:5B:51:B7:AE
feb/02 19:31:04 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 19:31:35 dhcp,info Hotspot deassigned 10.63.193.21 from 20:55:31:66:20:D8
feb/02 19:31:40 dhcp,info Hotspot assigned 10.63.193.21 to 20:55:31:66:20:D8
feb/02 19:32:09 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
feb/02 19:32:10 wireless,info 50:55:27:A0:E9:AF@wlan: connected
feb/02 19:32:11 dhcp,info Hotspot deassigned 10.63.193.133 from 50:55:27:A0:E9:AF
feb/02 19:32:11 dhcp,info Hotspot assigned 10.63.193.133 to 50:55:27:A0:E9:AF
feb/02 19:32:54 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 19:32:55 dhcp,info Hotspot deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
feb/02 19:33:00 dhcp,info Hotspot assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
feb/02 19:33:08 dhcp,info Hotspot deassigned 10.63.193.21 from 20:55:31:66:20:D8
feb/02 19:33:08 dhcp,info Hotspot assigned 10.63.193.21 to 20:55:31:66:20:D8
feb/02 19:34:23 system,info hotspot server profile default changed by ersitizastes
feb/02 19:34:33 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:35:09 dhcp,info Hotspot assigned 10.63.193.40 to B4:EF:39:7D:B2:50
feb/02 19:35:12 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:35:13 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:35:15 dhcp,info Hotspot assigned 10.63.193.1 to 10:D3:8A:04:9B:58
feb/02 19:35:16 dhcp,info Hotspot assigned 10.63.193.2 to F4:F1:E1:1E:3A:2C
feb/02 19:35:30 dhcp,info Hotspot deassigned 10.63.193.22 from 34:BE:00:95:74:65
feb/02 19:35:43 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:35:44 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:35:53 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:36:03 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:36:04 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:36:06 dhcp,info Hotspot assigned 10.63.193.0 to F8:95:C7:B4:25:3A
feb/02 19:36:08 dhcp,info Hotspot deassigned 10.63.193.6 from 64:89:9A:27:FA:67
feb/02 19:36:23 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:36:51 system,info hotspot server profile default changed by ersitizastes
feb/02 19:37:53 dhcp,info Hotspot deassigned 10.63.193.15 from 34:FC:EF:FF:AD:06
feb/02 19:38:24 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:38:25 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:38:26 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:38:28 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:38:40 dhcp,info Hotspot deassigned 10.63.193.18 from A8:9F:BA:02:A5:84
feb/02 19:38:51 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:39:05 dhcp,info Hotspot deassigned 10.63.193.12 from 34:FC:EF:D2:AB:CD
feb/02 19:39:44 dhcp,info Hotspot deassigned 10.63.193.19 from 00:F4:6F:FC:E4:47
feb/02 19:40:07 dhcp,info Hotspot assigned 10.63.193.7 to E8:B4:C8:28:76:16
feb/02 19:40:26 system,info new script added by ersitizastes
feb/02 19:40:31 system,info changed script settings by ersitizastes
feb/02 19:40:59 dhcp,info Hotspot deassigned 10.63.193.5 from 74:BA:DB:04:26:13
feb/02 19:41:21 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:42:43 dhcp,info Hotspot deassigned 10.63.193.9 from 3C:18:9F:33:05:31
feb/02 19:42:43 dhcp,info Hotspot assigned 10.63.193.9 to 3C:18:9F:33:05:31
feb/02 19:43:10 dhcp,info Hotspot assigned 10.63.193.5 to 74:BA:DB:04:26:13
feb/02 19:44:07 system,info hotspot server Hotspot added by ersitizastes
feb/02 19:44:08 system,info filter rule added
feb/02 19:44:08 system,info nat rule added
feb/02 19:45:09 dhcp,info Hotspot deassigned 10.63.193.40 from B4:EF:39:7D:B2:50
feb/02 19:45:10 wireless,info 94:51:03:D3:B6:B8@wlan: connected
feb/02 19:45:10 dhcp,info Hotspot assigned 10.63.192.253 to 94:51:03:D3:B6:B8
feb/02 19:45:16 dhcp,info Hotspot deassigned 10.63.193.2 from F4:F1:E1:1E:3A:2C
feb/02 19:45:24 dhcp,info Hotspot assigned 10.63.193.24 to 80:65:6D:4F:75:69
feb/02 19:45:30 dhcp,info Hotspot deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
feb/02 19:45:30 dhcp,info Hotspot assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
feb/02 19:45:39 hotspot,info,debug T-94:51:03:D3:B6:B8 (10.63.192.253): trying to log in by trial
feb/02 19:45:39 hotspot,account,info,debug T-94:51:03:D3:B6:B8 (10.63.192.253): logged in
feb/02 19:46:21 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): trying to log in by trial
feb/02 19:46:21 hotspot,account,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged in
feb/02 19:46:27 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged out: user request
feb/02 19:46:31 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): trying to log in by trial
feb/02 19:46:31 hotspot,account,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged in
feb/02 19:46:34 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged out: user request
feb/02 19:46:38 dhcp,info Hotspot assigned 10.63.193.28 to F4:0E:22:7E:AB:C8
feb/02 19:46:47 dhcp,info Hotspot assigned 10.63.193.11 to C4:9A:02:39:61:13
feb/02 19:47:41 dhcp,info Hotspot deassigned 10.63.193.0 from F8:95:C7:B4:25:3A
feb/02 19:47:50 dhcp,info Hotspot assigned 10.63.193.32 to 10:3B:59:CF:FE:A8
feb/02 19:49:08 system,info hotspot user profile 00 changed by ersitizastes
feb/02 19:49:34 wireless,info 34:FC:EF:D2:AB:CD@wlan: connected
feb/02 19:49:35 dhcp,info Hotspot assigned 10.63.193.12 to 34:FC:EF:D2:AB:CD
feb/02 19:49:35 dhcp,info Hotspot deassigned 10.63.193.133 from 50:55:27:A0:E9:AF
feb/02 19:49:35 dhcp,info Hotspot assigned 10.63.193.133 to 50:55:27:A0:E9:AF
feb/02 19:49:36 dhcp,info Hotspot deassigned 10.63.193.21 from 20:55:31:66:20:D8
feb/02 19:49:36 wireless,info 50:55:27:A0:E9:AF@wlan: disconnected, extensive data loss
feb/02 19:50:07 dhcp,info Hotspot deassigned 10.63.193.7 from E8:B4:C8:28:76:16
feb/02 19:50:20 system,info log action changed by ersitizastes
feb/02 19:50:32 dhcp,info Hotspot deassigned 10.63.193.11 from C4:9A:02:39:61:13
feb/02 19:50:33 dhcp,info Hotspot assigned 10.63.193.11 to C4:9A:02:39:61:13
feb/02 19:50:37 system,info log rule added by ersitizastes
feb/02 19:51:07 system,info hotspot server Hotspot changed by ersitizastes
feb/02 19:51:18 system,info hotspot server Hotspot changed by ersitizastes
feb/02 19:52:41 dhcp,info Hotspot assigned 10.63.193.21 to 20:55:31:66:20:D8
feb/02 19:52:43 dhcp,info Hotspot deassigned 10.63.193.9 from 3C:18:9F:33:05:31
feb/02 19:52:47 dhcp,info Hotspot deassigned 10.63.193.10 from 14:A3:64:94:50:C8
feb/02 19:53:01 dhcp,info Hotspot deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
feb/02 19:53:01 dhcp,info Hotspot assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
feb/02 19:53:11 dhcp,info Hotspot deassigned 10.63.193.5 from 74:BA:DB:04:26:13
feb/02 19:53:19 system,info DHCP server dhcp1 changed by ersitizastes
feb/02 19:53:26 dhcp,info dhcp1 assigned 10.63.193.37 to 14:1A:A3:68:7E:60
feb/02 19:54:48 dhcp,info dhcp1 assigned 10.63.193.75 to B4:EF:39:83:05:9C
feb/02 19:55:02 dhcp,info dhcp1 assigned 10.63.193.90 to C4:3A:BE:D2:D1:20
feb/02 19:55:25 dhcp,info dhcp1 deassigned 10.63.193.24 from 80:65:6D:4F:75:69
feb/02 19:55:56 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
feb/02 19:56:38 dhcp,info dhcp1 deassigned 10.63.193.28 from F4:0E:22:7E:AB:C8
feb/02 19:56:40 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 19:57:45 dhcp,info dhcp1 assigned 10.63.193.24 to 80:65:6D:4F:75:69
feb/02 19:57:50 system,info hotspot ip binding rule changed by ersitizastes
feb/02 19:57:51 dhcp,info dhcp1 deassigned 10.63.193.32 from 10:3B:59:CF:FE:A8
feb/02 19:58:01 system,info hotspot ip binding rule changed by ersitizastes
feb/02 19:58:11 system,info hotspot ip binding rule changed by ersitizastes
feb/02 19:58:22 system,info hotspot ip binding rule changed by ersitizastes
feb/02 19:58:36 system,info hotspot ip binding rule changed by ersitizastes
feb/02 19:58:44 system,info hotspot ip binding rule changed by ersitizastes
feb/02 19:59:02 dhcp,info dhcp1 assigned 10.63.194.14 to 84:38:38:D9:00:A4
feb/02 19:59:27 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
feb/02 19:59:45 wireless,info 34:FC:EF:D2:AB:CD@wlan: disconnected, extensive data loss
feb/02 20:00:28 dhcp,info dhcp1 deassigned 10.63.193.1 from 10:D3:8A:04:9B:58
feb/02 20:00:33 dhcp,info dhcp1 deassigned 10.63.193.11 from C4:9A:02:39:61:13
feb/02 20:00:49 dhcp,info dhcp1 deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
feb/02 20:01:01 dhcp,info dhcp1 assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
feb/02 20:01:32 dhcp,info dhcp1 assigned 10.63.194.15 to B8:5A:73:A8:5B:84
feb/02 20:01:36 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 20:02:39 dhcp,info dhcp1 assigned 10.63.194.16 to E4:90:7E:50:12:B3
feb/02 20:02:40 wireless,info 94:51:03:D3:B6:B8@wlan: disconnected, received disassoc: sending station leaving (8)
feb/02 20:02:41 dhcp,info dhcp1 deassigned 10.63.193.21 from 20:55:31:66:20:D8
feb/02 20:02:45 system,info hotspot user profile 00 changed by ersitizastes
feb/02 20:04:15 hotspot,info,debug T-94:51:03:D3:B6:B8 (10.63.192.253): logged out: keepalive timeout
feb/02 20:04:48 dhcp,info dhcp1 deassigned 10.63.193.75 from B4:EF:39:83:05:9C
feb/02 20:05:02 dhcp,info dhcp1 deassigned 10.63.193.90 from C4:3A:BE:D2:D1:20
feb/02 20:05:25 system,info new script added by ersitizastes
feb/02 20:05:30 system,info changed script settings by ersitizastes
feb/02 20:05:30 dhcp,info dhcp1 assigned 10.63.194.17 to 84:38:38:FE:EE:9A
feb/02 20:06:10 system,info DHCP server setting changed by ersitizastes
feb/02 20:06:58 system,info hotspot ip binding rule changed by ersitizastes
feb/02 20:07:08 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
feb/02 20:07:11 interface,info ether2 link down
feb/02 20:07:19 wireless,info 5C:C9:D3:0D:D1:AD@wlan: connected
feb/02 20:07:19 dhcp,info dhcp1 assigned 10.63.192.254 to 5C:C9:D3:0D:D1:AD
feb/02 20:07:27 wireless,info 5C:C9:D3:0D:D1:AD@wlan: disconnected, received disassoc: sending station leaving (8)
feb/02 20:07:39 wireless,info 5C:C9:D3:0D:D1:AD@wlan: connected
feb/02 20:07:46 hotspot,info,debug T-5C:C9:D3:0D:D1:AD (10.63.192.254): trying to log in by trial
feb/02 20:07:46 hotspot,account,info,debug T-5C:C9:D3:0D:D1:AD (10.63.192.254): logged in
feb/02 20:08:45 interface,info ether2 link up (speed 1G, full duplex)
feb/02 20:08:51 wireless,info 5C:C9:D3:0D:D1:AD@wlan: disconnected, received disassoc: sending station leaving (8)
feb/02 20:08:59 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 20:09:02 dhcp,info dhcp1 deassigned 10.63.194.14 from 84:38:38:D9:00:A4
feb/02 20:09:14 dhcp,info dhcp1 deassigned 10.63.193.12 from 34:FC:EF:D2:AB:CD
feb/02 20:09:16 dhcp,info dhcp1 assigned 10.63.194.19 to 14:32:D1:1C:E1:6E
feb/02 20:10:12 dhcp,info dhcp1 deassigned 10.63.192.253 from 94:51:03:D3:B6:B8
feb/02 20:10:47 wireless,info 60:D7:AE:C8:92:CC@wlan: disconnected, disabling
feb/02 20:10:47 system,info device changed by ersitizastes
feb/02 20:10:48 wireless,info wlan: data from unknown device 60:D7:AE:C8:92:CC, sent deauth
feb/02 20:10:50 dhcp,info dhcp1 assigned 10.63.194.20 to 40:0E:85:84:C5:85
feb/02 20:10:50 dhcp,info dhcp1 deassigned 10.63.193.16 from 9C:D3:5B:51:B7:AE
feb/02 20:10:51 hotspot,info,debug T-5C:C9:D3:0D:D1:AD (10.63.192.254): logged out: keepalive timeout
feb/02 20:11:25 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
feb/02 20:11:32 dhcp,info dhcp1 deassigned 10.63.194.15 from B8:5A:73:A8:5B:84
feb/02 20:12:00 dhcp,info dhcp1 assigned 10.63.193.16 to 9C:D3:5B:51:B7:AE
feb/02 20:12:02 dhcp,info dhcp1 assigned 10.63.194.18 to 34:FC:EF:FF:AD:06
feb/02 20:12:53 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 20:13:31 dhcp,info dhcp1 assigned 10.63.194.23 to F8:95:C7:AE:1B:4F
feb/02 20:14:23 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
feb/02 20:14:45 system,info hotspot user profile 10 added by ersitizastes
feb/02 20:14:54 dhcp,info dhcp1 deassigned 10.63.194.20 from 40:0E:85:84:C5:85
feb/02 20:15:01 system,info hotspot user profile 00 changed by ersitizastes
feb/02 20:15:36 system,info hotspot user profile 10 changed by ersitizastes
feb/02 20:15:46 system,info hotspot user profile 10 changed by ersitizastes
feb/02 20:16:42 system,info hotspot user profile 10 changed by ersitizastes
feb/02 20:17:02 dhcp,info dhcp1 assigned 10.63.193.28 to F4:0E:22:7E:AB:C8
feb/02 20:17:05 system,info hotspot user profile 30 added by ersitizastes
feb/02 20:17:05 dhcp,info dhcp1 assigned 10.63.193.90 to C4:3A:BE:D2:D1:20
feb/02 20:17:23 dhcp,info dhcp1 deassigned 10.63.194.23 from F8:95:C7:AE:1B:4F
feb/02 20:17:26 dhcp,info dhcp1 assigned 10.63.194.23 to F8:95:C7:AE:1B:4F
feb/02 20:17:39 dhcp,info dhcp1 deassigned 10.63.192.254 from 5C:C9:D3:0D:D1:AD
feb/02 20:18:11 system,info hotspot user profile 30 changed by ersitizastes
feb/02 20:18:26 system,info hotspot user profile 60 added by ersitizastes
feb/02 20:18:58 system,info hotspot user profile 60 changed by ersitizastes
feb/02 20:19:16 dhcp,info dhcp1 deassigned 10.63.194.19 from 14:32:D1:1C:E1:6E
feb/02 20:19:16 system,info hotspot user profile 100 added by ersitizastes
feb/02 20:19:27 system,info hotspot user profile 100 changed by ersitizastes
feb/02 20:19:28 dhcp,info dhcp1 assigned 10.63.194.25 to F8:95:C7:AF:20:92
feb/02 20:19:41 dhcp,info dhcp1 assigned 10.63.194.26 to C4:9A:02:9E:19:A1
feb/02 20:19:51 system,info hotspot user profile 100 changed by ersitizastes
feb/02 20:20:06 system,info hotspot user profile 30 changed by ersitizastes
feb/02 20:20:20 system,info hotspot user profile 60 changed by ersitizastes
feb/02 20:20:25 dhcp,info dhcp1 deassigned 10.63.194.17 from 84:38:38:FE:EE:9A
feb/02 20:23:09 system,info mangle rule added by ersitizastes
feb/02 20:24:02 system,info mangle rule added by ersitizastes
feb/02 20:25:27 system,info wireless access-list entry added by ersitizastes
feb/02 20:25:28 wireless,info 94:51:03:D3:B6:B8@wlan: connected
feb/02 20:25:32 dhcp,info dhcp1 assigned 10.63.192.253 to 94:51:03:D3:B6:B8
feb/02 20:25:33 hotspot,info,debug T-94:51:03:D3:B6:B8 (10.63.192.253): trying to log in by mac-cookie
feb/02 20:25:33 hotspot,account,info,debug T-94:51:03:D3:B6:B8 (10.63.192.253): logged in
feb/02 20:25:34 wireless,info 94:51:03:D3:B6:B8@wlan: disconnected, access-list changed
feb/02 20:25:34 system,info wireless access-list entry changed by ersitizastes
feb/02 20:25:34 wireless,info 94:51:03:D3:B6:B8@wlan: connected
feb/02 20:25:45 dhcp,info dhcp1 deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
feb/02 20:25:58 dhcp,info dhcp1 assigned 10.63.194.27 to 44:80:EB:CC:B2:5B
feb/02 20:26:01 system,info wireless access-list entry added by ersitizastes
feb/02 20:26:09 system,info wireless access-list entry changed by ersitizastes
feb/02 20:27:02 dhcp,info dhcp1 deassigned 10.63.193.28 from F4:0E:22:7E:AB:C8
feb/02 20:27:05 dhcp,info dhcp1 deassigned 10.63.193.90 from C4:3A:BE:D2:D1:20
feb/02 20:27:10 dhcp,info dhcp1 assigned 10.63.194.28 to 74:BA:DB:04:26:13
feb/02 20:27:12 system,info mangle rule removed by ersitizastes
feb/02 20:27:26 dhcp,info dhcp1 deassigned 10.63.194.23 from F8:95:C7:AE:1B:4F
feb/02 20:28:10 dhcp,info dhcp1 assigned 10.63.194.29 to F8:95:C7:B0:02:08
feb/02 20:28:47 dhcp,info dhcp1 assigned 10.63.194.22 to AC:9E:17:0F:63:0D
feb/02 20:28:55 system,info hotspot walled-garden rule added by ersitizastes
feb/02 20:28:56 system,info hotspot walled-garden rule added
feb/02 20:29:02 dhcp,info dhcp1 deassigned 10.63.193.16 from 9C:D3:5B:51:B7:AE
feb/02 20:29:02 dhcp,info dhcp1 assigned 10.63.193.16 to 9C:D3:5B:51:B7:AE
feb/02 20:29:08 system,info hotspot walled-garden rule changed by ersitizastes
feb/02 20:29:12 dhcp,info dhcp1 assigned 10.63.194.30 to 58:3F:54:9F:DA:69
feb/02 20:29:28 dhcp,info dhcp1 deassigned 10.63.194.25 from F8:95:C7:AF:20:92
feb/02 20:30:59 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
feb/02 20:31:39 dhcp,info dhcp1 deassigned 10.63.194.18 from 34:FC:EF:FF:AD:06
feb/02 20:31:39 system,info DHCP server dhcp1 changed by ersitizastes
feb/02 20:32:05 dhcp,info dhcp1 deassigned 10.63.193.23 from 38:2D:D1:A5:04:39
feb/02 20:32:07 dhcp,info dhcp1 deassigned 10.63.194.16 from E4:90:7E:50:12:B3
feb/02 20:33:08 dhcp,info dhcp1 assigned 10.63.193.23 to 38:2D:D1:A5:04:39
feb/02 20:33:15 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
feb/02 20:33:59 dhcp,info dhcp1 assigned 10.63.193.21 to 20:55:31:66:20:D8
feb/02 20:34:01 dhcp,info dhcp1 assigned 10.63.194.18 to 34:FC:EF:FF:AD:06
feb/02 20:35:35 dhcp,info dhcp1 deassigned 10.63.194.26 from C4:9A:02:9E:19:A1
feb/02 20:36:45 dhcp,info dhcp1 deassigned 10.63.193.24 from 80:65:6D:4F:75:69
feb/02 20:36:57 hotspot,info,debug T-94:51:03:D3:B6:B8 (10.63.192.253): logged out: session timeout
feb/02 20:37:00 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 20:38:11 dhcp,info dhcp1 deassigned 10.63.194.29 from F8:95:C7:B0:02:08
feb/02 20:38:33 dhcp,info dhcp1 deassigned 10.63.193.133 from 50:55:27:A0:E9:AF
feb/02 20:38:47 dhcp,info dhcp1 deassigned 10.63.194.22 from AC:9E:17:0F:63:0D
feb/02 20:39:12 dhcp,info dhcp1 deassigned 10.63.194.30 from 58:3F:54:9F:DA:69
feb/02 20:40:13 dhcp,info dhcp1 assigned 10.63.194.33 to EC:88:92:40:CC:8B
feb/02 20:41:37 system,info new script scheduled by ersitizastes
feb/02 20:41:41 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
feb/02 20:42:13 system,info changed scheduled script settings by ersitizastes
feb/02 20:42:17 system,info changed scheduled script settings by ersitizastes
feb/02 20:42:29 dhcp,info dhcp1 deassigned 10.63.194.28 from 74:BA:DB:04:26:13
feb/02 20:42:33 dhcp,info dhcp1 assigned 10.63.194.28 to 74:BA:DB:04:26:13
feb/02 20:42:37 system,info changed scheduled script settings by ersitizastes
feb/02 20:43:14 system,info new script scheduled by ersitizastes
feb/02 20:43:17 system,info changed scheduled script settings by ersitizastes
feb/02 20:43:26 wireless,info 94:51:03:D3:B6:B8@wlan: disconnected, received disassoc: sending station leaving (8)
feb/02 20:43:28 system,info changed scheduled script settings by ersitizastes
feb/02 20:43:35 dhcp,info dhcp1 assigned 10.63.194.34 to 20:55:31:74:FC:48
feb/02 20:43:48 dhcp,info dhcp1 assigned 10.63.194.35 to F4:F1:E1:1E:3A:2C
feb/02 20:43:50 dhcp,info dhcp1 deassigned 10.63.194.28 from 74:BA:DB:04:26:13
feb/02 20:44:00 dhcp,info dhcp1 assigned 10.63.194.28 to 74:BA:DB:04:26:13
feb/02 20:44:27 system,info new script added by ersitizastes
feb/02 20:44:28 system,info hotspot user profile 00 changed by ersitizastes
feb/02 20:44:35 system,info changed script settings by ersitizastes
feb/02 20:45:24 system,info new script added by ersitizastes
feb/02 20:45:27 system,info changed script settings by ersitizastes
feb/02 20:46:18 system,info new script scheduled by ersitizastes
feb/02 20:46:23 system,info changed scheduled script settings by ersitizastes
feb/02 20:46:38 system,info changed scheduled script settings by ersitizastes
feb/02 20:46:49 dhcp,info dhcp1 assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
feb/02 20:46:51 system,info changed scheduled script settings by ersitizastes
feb/02 20:46:54 dhcp,info dhcp1 assigned 10.63.194.22 to AC:9E:17:0F:63:0D
feb/02 20:47:11 system,info new script scheduled by ersitizastes
feb/02 20:47:15 dhcp,info dhcp1 assigned 10.63.194.36 to 50:B7:C3:CC:5C:A8
feb/02 20:47:17 system,info changed scheduled script settings by ersitizastes
feb/02 20:47:29 system,info changed scheduled script settings by ersitizastes
feb/02 20:48:04 hotspot,info,debug T-50:B7:C3:CC:5C:A8 (10.63.194.36): trying to log in by trial
feb/02 20:48:04 hotspot,account,info,debug T-50:B7:C3:CC:5C:A8 (10.63.194.36): logged in
feb/02 20:48:20 dhcp,info dhcp1 assigned 10.63.194.26 to C4:9A:02:9E:19:A1
feb/02 20:48:41 system,info new script scheduled by ersitizastes
feb/02 20:48:49 system,info changed scheduled script settings by ersitizastes
feb/02 20:49:15 dhcp,info dhcp1 deassigned 10.63.194.28 from 74:BA:DB:04:26:13
feb/02 20:49:26 dhcp,info dhcp1 assigned 10.63.194.28 to 74:BA:DB:04:26:13
feb/02 20:49:58 dhcp,info dhcp1 assigned 10.63.194.38 to 64:89:9A:27:FA:67
feb/02 20:50:00 dhcp,info dhcp1 assigned 10.63.194.39 to 58:A2:B5:DA:FD:96
feb/02 20:50:22 dhcp,info dhcp1 assigned 10.63.193.31 to 18:89:5B:0C:17:72
feb/02 20:50:33 hotspot,info,debug T-18:89:5B:0C:17:72 (10.63.193.31): trying to log in by trial
feb/02 20:50:33 hotspot,account,info,debug T-18:89:5B:0C:17:72 (10.63.193.31): logged in
feb/02 20:50:33 dhcp,info dhcp1 deassigned 10.63.192.253 from 94:51:03:D3:B6:B8
feb/02 20:51:41 dhcp,info dhcp1 assigned 10.63.193.133 to 50:55:27:A0:E9:AF
feb/02 20:53:03 system,info new script scheduled by ersitizastes
feb/02 20:53:11 system,info changed scheduled script settings by ersitizastes
feb/02 20:54:51 dhcp,info dhcp1 assigned 10.63.194.40 to 34:FC:EF:D1:29:25
feb/02 20:55:20 dhcp,info dhcp1 deassigned 10.63.194.28 from 74:BA:DB:04:26:13
feb/02 20:55:20 dhcp,info dhcp1 assigned 10.63.194.28 to 74:BA:DB:04:26:13
feb/02 20:55:26 system,info,account user ersitizastes logged in from 10.63.192.255 via telnet
feb/02 20:55:40 system,info,account user ersitizastes logged out from 10.63.192.255 via telnet
feb/02 20:55:43 system,info new script scheduled by ersitizastes
feb/02 20:55:52 system,info changed scheduled script settings by ersitizastes
feb/02 20:57:01 system,info new script scheduled by ersitizastes
feb/02 20:57:24 system,info changed scheduled script settings by ersitizastes
feb/02 20:57:25 system,info changed scheduled script settings by ersitizastes
feb/02 20:57:33 system,info changed scheduled script settings by ersitizastes
feb/02 20:58:01 dhcp,info dhcp1 deassigned 10.63.194.38 from 64:89:9A:27:FA:67
feb/02 20:58:01 dhcp,info dhcp1 assigned 10.63.194.38 to 64:89:9A:27:FA:67
feb/02 20:58:06 dhcp,info dhcp1 assigned 10.63.194.41 to 34:FC:EF:D3:AD:1D
feb/02 20:58:10 dhcp,info dhcp1 assigned 10.63.194.42 to 34:FC:EF:CF:50:24
feb/02 20:58:30 hotspot,info,debug T-64:89:9A:27:FA:67 (10.63.194.38): trying to log in by trial
feb/02 20:58:30 hotspot,account,info,debug T-64:89:9A:27:FA:67 (10.63.194.38): logged in
feb/02 20:59:18 system,info hotspot user profile 110 added by ersitizastes
feb/02 20:59:32 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
feb/02 21:00:00 system,info hotspot user profile 10 changed by ersitizastes
feb/02 21:00:03 interface,info ether10 link down
feb/02 21:00:05 dhcp,info 172.16 deassigned 172.16.0.2 from 3C:E5:B4:0D:0D:27
feb/02 21:00:05 interface,info ether10 link up (speed 100M, full duplex)
feb/02 21:00:08 dhcp,info 172.16 assigned 172.16.0.2 to 3C:E5:B4:0D:0D:27
feb/02 21:00:17 system,info hotspot user profile 30 changed by ersitizastes
feb/02 21:00:24 system,info hotspot user profile 60 changed by ersitizastes
feb/02 21:00:26 hotspot,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): trying to log in by trial
feb/02 21:00:26 hotspot,account,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): logged in
feb/02 21:00:31 system,info hotspot user profile 100 changed by ersitizastes
feb/02 21:00:37 system,info hotspot user profile 110 changed by ersitizastes
feb/02 21:01:53 dhcp,info dhcp1 deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
feb/02 21:01:53 dhcp,info dhcp1 assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
feb/02 21:02:39 system,info new script added by ersitizastes
feb/02 21:02:45 system,info changed script settings by ersitizastes
feb/02 21:02:49 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
feb/02 21:02:49 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
feb/02 21:02:49 hotspot,info,debug T-50:B7:C3:CC:5C:A8 (10.63.194.36): logged out: keepalive timeout
feb/02 21:03:13 dhcp,info dhcp1 deassigned 10.63.193.16 from 9C:D3:5B:51:B7:AE
feb/02 21:03:13 dhcp,info dhcp1 assigned 10.63.193.16 to 9C:D3:5B:51:B7:AE
feb/02 21:03:54 system,info changed email settings by ersitizastes
feb/02 21:04:23 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
feb/02 21:04:23 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
feb/02 21:04:31 system,info changed email settings by ersitizastes
feb/02 21:04:33 dhcp,info dhcp1 assigned 10.63.194.44 to B8:5A:73:B1:50:E0
feb/02 21:04:59 system,info Interface Traffic Graphing Config added by ersitizastes
feb/02 21:05:16 system,info Interface Traffic Graphing Config added by ersitizastes
feb/02 21:05:33 system,info Interface Traffic Graphing Config added by ersitizastes
feb/02 21:06:03 system,info Interface Traffic Graphing Config added by ersitizastes
feb/02 21:06:32 dhcp,info dhcp1 assigned 10.63.193.59 to F8:A9:D0:5A:F4:85
feb/02 21:06:45 hotspot,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): logged out: keepalive timeout
feb/02 21:07:19 dhcp,info dhcp1 deassigned 10.63.194.26 from C4:9A:02:9E:19:A1
feb/02 21:08:06 dhcp,info dhcp1 deassigned 10.63.194.33 from EC:88:92:40:CC:8B
feb/02 21:08:09 dhcp,info dhcp1 assigned 10.63.194.33 to EC:88:92:40:CC:8B
feb/02 21:08:23 dhcp,info dhcp1 assigned 10.63.193.90 to C4:3A:BE:D2:D1:20
feb/02 21:08:29 system,info monitoring new host by ersitizastes
feb/02 21:08:29 script,warning Google Up
feb/02 21:08:37 system,info netwatch host modified by ersitizastes
feb/02 21:08:37 script,warning Google Up
feb/02 21:08:45 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
feb/02 21:10:00 system,info monitoring new host by ersitizastes
feb/02 21:10:00 script,warning 5g.net 1 Up
feb/02 21:10:14 system,info netwatch host modified by ersitizastes
feb/02 21:10:14 script,warning 5g.net 1 Up
feb/02 21:10:34 dhcp,info dhcp1 deassigned 10.63.193.133 from 50:55:27:A0:E9:AF
feb/02 21:10:41 dhcp,info dhcp1 assigned 10.63.193.133 to 50:55:27:A0:E9:AF
feb/02 21:10:49 system,info monitoring new host by ersitizastes
feb/02 21:10:49 script,warning 5g.net 2 Up
feb/02 21:10:58 system,info monitoring new host by ersitizastes
feb/02 21:10:58 script,warning 5g.net 2 Up
feb/02 21:11:04 system,info monitored host removed by ersitizastes
feb/02 21:11:17 system,info netwatch host modified by ersitizastes
feb/02 21:11:17 script,warning 5g.net 2 Up
feb/02 21:11:19 dhcp,info dhcp1 assigned 10.63.193.3 to F4:F1:E1:F4:62:F6
feb/02 21:11:48 hotspot,info,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): trying to log in by trial
feb/02 21:11:48 hotspot,account,info,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): logged in
feb/02 21:12:01 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): trying to log in by trial
feb/02 21:12:01 hotspot,account,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged in
feb/02 21:12:48 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged out: user request
feb/02 21:13:49 wireless,info wlan: data from unknown device 50:55:27:A0:E9:AF, sent deauth
feb/02 21:14:00 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): trying to log in by trial
feb/02 21:14:00 hotspot,account,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged in
feb/02 21:14:14 dhcp,info dhcp1 deassigned 10.63.193.23 from 38:2D:D1:A5:04:39
feb/02 21:14:14 dhcp,info dhcp1 assigned 10.63.193.23 to 38:2D:D1:A5:04:39
feb/02 21:15:39 system,info log rule added by ersitizastes
feb/02 21:16:03 script,error 5g.net 2 Down
feb/02 21:16:10 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by ICMP type<3> code<3> to 10.63.192.1
feb/02 21:16:10 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:16:15 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 21:16:15 hotspot,debug Hotspot: dhcp host 10.63.194.27 removed: login timeout
feb/02 21:16:16 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :59687 -> 61.145.124.57:80
feb/02 21:16:16 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 21:16:20 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.22 by TCP :37124 -> 192.12.31.106:5228
feb/02 21:16:20 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.22, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:16:50 hotspot,debug Hotspot: new host detected 44:80:EB:CC:B2:5B/10.63.194.27 by UDP :33966 -> 10.63.192.1:53
feb/02 21:16:50 hotspot,debug Hotspot: dhcp host 44:80:EB:CC:B2:5B/10.63.194.27 added, ip 10.63.194.27
feb/02 21:16:52 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :32977 -> 10.63.192.1:53
feb/02 21:16:52 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:17:05 dhcp,info dhcp1 deassigned 10.63.193.133 from 50:55:27:A0:E9:AF
feb/02 21:17:05 hotspot,debug Hotspot: dhcp host 10.63.193.133 changed type to dynamic (remove after 5s)
feb/02 21:17:05 dhcp,info dhcp1 assigned 10.63.193.133 to 50:55:27:A0:E9:AF
feb/02 21:17:05 hotspot,debug Hotspot: dynamic host 10.63.193.133 changed type to dhcp (got back lease)
feb/02 21:17:31 dhcp,info dhcp1 assigned 10.63.194.48 to 00:F4:6F:C9:DD:01
feb/02 21:17:34 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :54106 -> 10.63.192.1:53
feb/02 21:17:34 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:17:37 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:17:39 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by TCP :43148 -> 108.168.174.17:80
feb/02 21:17:39 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:17:43 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.22 by TCP :47127 -> 192.12.31.91:5228
feb/02 21:17:43 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.22, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:17:52 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by ICMP type<3> code<3> to 10.63.192.1
feb/02 21:17:52 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:18:00 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by TCP :53388 -> 173.194.213.188:5228
feb/02 21:18:00 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:18:00 script,warning 5g.net 2 Up
feb/02 21:18:16 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 21:18:16 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :56745 -> 183.61.112.29:80
feb/02 21:18:16 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 21:18:18 system,info,account user ersitizastes logged in from 10.63.192.255 via telnet
feb/02 21:18:23 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.193.2 by UDP :35264 -> 10.63.192.1:53
feb/02 21:18:23 hotspot,debug Hotspot: dynamic host C4:9A:02:61:DA:A3/10.63.193.2 added, ip 10.63.193.2
feb/02 21:18:23 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/100.103.129.231 by TCP :43795 -> 10.63.192.1:7
feb/02 21:18:23 hotspot,debug Hotspot: dynamic host 10.63.193.2 removed: limiting addresses per mac
feb/02 21:18:23 hotspot,debug Hotspot: dynamic host C4:9A:02:61:DA:A3/100.103.129.231 added, ip 10.63.194.49
feb/02 21:18:30 system,info,account user ersitizastes logged out from 10.63.192.255 via telnet
feb/02 21:18:35 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :37658 -> 10.63.192.1:53
feb/02 21:18:35 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:18:37 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.193.2 by UDP :42002 -> 10.63.192.1:53
feb/02 21:18:37 hotspot,debug Hotspot: dynamic host 10.63.194.49 removed: limiting addresses per mac
feb/02 21:18:37 hotspot,debug Hotspot: dynamic host C4:9A:02:61:DA:A3/10.63.193.2 added, ip 10.63.193.2
feb/02 21:18:43 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by TCP :43148 -> 108.168.174.17:80
feb/02 21:18:43 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:18:50 hotspot,debug Hotspot: dhcp host 10.63.194.27 removed: login timeout
feb/02 21:19:06 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.22 by TCP :52602 -> 192.12.31.84:5223
feb/02 21:19:06 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.22, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:19:06 dhcp,info dhcp1 deassigned 10.63.194.34 from 20:55:31:74:FC:48
feb/02 21:19:12 dhcp,info dhcp1 assigned 10.63.194.34 to 20:55:31:74:FC:48
feb/02 21:19:13 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.34 by UDP :18322 -> 10.63.192.1:53
feb/02 21:19:13 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.34, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:19:19 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by TCP :41108 -> 108.168.176.250:5222
feb/02 21:19:19 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:19:30 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :47791 -> 10.63.192.1:53
feb/02 21:19:30 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
feb/02 21:19:36 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by TCP :35911 -> 54.213.65.93:80
feb/02 21:19:36 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:19:45 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :41033 -> 10.63.192.1:53
feb/02 21:19:45 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:20:00 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:20:01 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by TCP :54244 -> 208.71.186.86:80
feb/02 21:20:01 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:20:14 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.34 by UDP :20634 -> 10.63.192.1:53
feb/02 21:20:14 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.34, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:20:16 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 21:20:20 hotspot,debug Hotspot: new host detected 44:80:EB:CC:B2:5B/10.63.194.27 by TCP :53762 -> 174.37.231.87:80
feb/02 21:20:20 hotspot,debug Hotspot: dhcp host 44:80:EB:CC:B2:5B/10.63.194.27 added, ip 10.63.194.27
feb/02 21:20:21 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by TCP :41108 -> 108.168.176.250:5222
feb/02 21:20:21 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:20:29 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.22 by UDP :36712 -> 10.63.192.1:53
feb/02 21:20:29 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.22, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:20:32 dhcp,info dhcp1 deassigned 10.63.194.33 from EC:88:92:40:CC:8B
feb/02 21:20:33 hotspot,info,debug T-18:89:5B:0C:17:72 (10.63.193.31): logged out: session timeout
feb/02 21:20:33 hotspot,debug T-18:89:5B:0C:17:72 (10.63.193.31): removing queue
feb/02 21:20:33 hotspot,debug T-18:89:5B:0C:17:72 (10.63.193.31): removing address-list
feb/02 21:20:33 hotspot,debug T-18:89:5B:0C:17:72 (10.63.193.31): removing ip->user binding
feb/02 21:20:36 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :11754 -> 10.63.192.1:53
feb/02 21:20:36 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:20:37 hotspot,debug Hotspot: dynamic host 10.63.193.2 removed: login timeout
feb/02 21:20:38 dhcp,info dhcp1 assigned 10.63.194.33 to EC:88:92:40:CC:8B
feb/02 21:20:40 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :23367 -> 10.63.192.1:53
feb/02 21:20:40 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:20:46 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :12245 -> 10.63.192.1:53
feb/02 21:20:46 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:20:51 system,info dhcp lease changed by ersitizastes
feb/02 21:21:03 script,error Google Down
feb/02 21:21:30 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: login timeout
feb/02 21:21:31 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by TCP :50303 -> 149.154.175.50:443
feb/02 21:21:31 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
feb/02 21:21:34 dhcp,info dhcp1 assigned 10.63.193.44 to 6C:2F:2C:1C:E4:DC
feb/02 21:21:37 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :64886 -> 10.63.192.1:53
feb/02 21:21:37 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:21:41 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :11473 -> 10.63.192.1:53
feb/02 21:21:41 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:21:42 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :3099 -> 10.63.192.1:53
feb/02 21:21:42 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:21:43 hotspot,debug Hotspot: new host detected 6C:2F:2C:1C:E4:DC/10.63.193.44 by UDP :63814 -> 10.63.192.1:53
feb/02 21:21:43 hotspot,debug Hotspot: dhcp host 6C:2F:2C:1C:E4:DC/10.63.193.44 added, ip 10.63.193.44
feb/02 21:21:45 system,info dhcp lease changed by ersitizastes
feb/02 21:21:52 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.22 by TCP :45978 -> 192.12.31.89:5228
feb/02 21:21:52 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.22, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:22:01 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:22:05 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by UDP :57453 -> 8.8.8.8:53
feb/02 21:22:05 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:22:20 hotspot,debug Hotspot: dhcp host 10.63.194.27 removed: login timeout
feb/02 21:22:27 hotspot,debug Hotspot: new host detected 44:80:EB:CC:B2:5B/10.63.194.27 by TCP :41242 -> 31.13.73.1:443
feb/02 21:22:27 hotspot,debug Hotspot: dhcp host 44:80:EB:CC:B2:5B/10.63.194.27 added, ip 10.63.194.27
feb/02 21:22:33 hotspot,debug Hotspot: dhcp host 10.63.193.31 removed: login timeout
feb/02 21:22:33 hotspot,debug Hotspot: new host detected 18:89:5B:0C:17:72/10.63.193.31 by TCP :58124 -> 31.13.73.36:443
feb/02 21:22:33 hotspot,debug Hotspot: dhcp host 18:89:5B:0C:17:72/10.63.193.31 added, ip 10.63.193.31
feb/02 21:22:44 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :2015 -> 10.63.192.1:53
feb/02 21:22:44 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:22:44 dhcp,info dhcp1 deassigned 10.63.193.31 from 18:89:5B:0C:17:72
feb/02 21:22:44 hotspot,debug Hotspot: dhcp host 10.63.193.31 changed type to dynamic (remove after 5s)
feb/02 21:22:49 hotspot,debug Hotspot: dynamic host 10.63.193.31 removed: lost dhcp lease
feb/02 21:22:53 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :55424 -> 10.63.192.1:53
feb/02 21:22:53 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:22:57 dhcp,info dhcp1 assigned 10.63.193.31 to 18:89:5B:0C:17:72
feb/02 21:23:00 hotspot,debug Hotspot: new host detected 18:89:5B:0C:17:72/10.63.193.31 by UDP :49123 -> 10.63.192.1:53
feb/02 21:23:00 hotspot,debug Hotspot: dhcp host 18:89:5B:0C:17:72/10.63.193.31 added, ip 10.63.193.31
feb/02 21:23:14 system,info hotspot server profile default changed by ersitizastes
feb/02 21:23:16 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.22 by UDP :15323 -> 10.63.192.1:53
feb/02 21:23:16 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.22, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:23:19 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :49185 -> 10.63.192.1:53
feb/02 21:23:19 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:23:31 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: login timeout
feb/02 21:23:42 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :14050 -> 10.63.192.1:53
feb/02 21:23:42 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:23:43 hotspot,debug Hotspot: dhcp host 10.63.193.44 removed: login timeout
feb/02 21:23:47 dhcp,info dhcp1 assigned 10.63.194.51 to 00:A0:E1:01:58:32
feb/02 21:23:50 system,info hotspot user profile 00 changed by ersitizastes
feb/02 21:23:52 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.51 by UDP :8850 -> 10.63.192.1:53
feb/02 21:23:52 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.51, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:24:05 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:24:12 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :8945 -> 10.63.192.1:53
feb/02 21:24:12 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:24:16 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by UDP :37477 -> 10.63.192.1:53
feb/02 21:24:16 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:24:19 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :48834 -> 10.63.192.1:53
feb/02 21:24:19 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:24:23 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.22 by TCP :57336 -> 31.13.73.1:443
feb/02 21:24:23 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.22, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:24:27 hotspot,debug Hotspot: dhcp host 10.63.194.27 removed: login timeout
feb/02 21:24:37 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :64599 -> 10.63.192.1:53
feb/02 21:24:37 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
feb/02 21:24:40 dhcp,info dhcp1 deassigned 10.63.193.44 from 6C:2F:2C:1C:E4:DC
feb/02 21:24:40 dhcp,info dhcp1 assigned 10.63.193.44 to 6C:2F:2C:1C:E4:DC
feb/02 21:24:40 hotspot,debug Hotspot: new host detected 6C:2F:2C:1C:E4:DC/10.63.193.44 by UDP :36723 -> 10.63.192.1:53
feb/02 21:24:40 hotspot,debug Hotspot: dhcp host 6C:2F:2C:1C:E4:DC/10.63.193.44 added, ip 10.63.193.44
feb/02 21:24:43 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :34973 -> 10.63.192.1:53
feb/02 21:24:43 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:24:52 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.51 by TCP :33546 -> 66.220.158.2:443
feb/02 21:24:52 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.51, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:25:00 hotspot,debug Hotspot: dhcp host 10.63.193.31 removed: login timeout
feb/02 21:25:01 hotspot,debug Hotspot: new host detected 18:89:5B:0C:17:72/10.63.193.31 by UDP :14671 -> 10.63.192.1:53
feb/02 21:25:01 hotspot,debug Hotspot: dhcp host 18:89:5B:0C:17:72/10.63.193.31 added, ip 10.63.193.31
feb/02 21:25:03 dhcp,info dhcp1 assigned 10.63.194.52 to C4:9A:02:61:DA:A3
feb/02 21:25:04 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.194.52 by UDP :62202 -> 10.63.192.1:53
feb/02 21:25:04 hotspot,debug Hotspot: dhcp host C4:9A:02:61:DA:A3/10.63.194.52 added, ip 10.63.194.52
feb/02 21:25:13 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :15235 -> 10.63.192.1:53
feb/02 21:25:13 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:25:13 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by TCP :47108 -> 158.85.58.26:5222
feb/02 21:25:13 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:25:21 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :2784 -> 10.63.192.1:53
feb/02 21:25:21 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:25:43 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by TCP :51267 -> 158.85.58.43:443
feb/02 21:25:43 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:25:53 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.51 by UDP :58804 -> 8.8.8.8:53
feb/02 21:25:53 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.51, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:26:03 script,warning Google Up
feb/02 21:26:03 script,error 5g.net 2 Down
feb/02 21:26:16 hotspot,debug Hotspot: new host detected 44:80:EB:CC:B2:5B/10.63.194.27 by UDP :32650 -> 10.63.192.1:53
feb/02 21:26:16 hotspot,debug Hotspot: dhcp host 44:80:EB:CC:B2:5B/10.63.194.27 added, ip 10.63.194.27
feb/02 21:26:16 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:26:23 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :39656 -> 10.63.192.1:53
feb/02 21:26:23 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:26:37 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: login timeout
feb/02 21:26:40 hotspot,debug Hotspot: dhcp host 10.63.193.44 removed: login timeout
feb/02 21:26:43 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :63725 -> 10.63.192.1:53
feb/02 21:26:43 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:26:44 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
feb/02 21:26:55 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.51 by UDP :51570 -> 8.8.8.8:53
feb/02 21:26:55 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.51, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:26:58 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by TCP :50350 -> 149.154.175.50:443
feb/02 21:26:58 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
feb/02 21:27:00 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by TCP :48676 -> 208.71.186.86:80
feb/02 21:27:00 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:27:00 script,warning 5g.net 2 Up
feb/02 21:27:01 hotspot,debug Hotspot: dhcp host 10.63.193.31 removed: login timeout
feb/02 21:27:01 hotspot,debug Hotspot: new host detected 18:89:5B:0C:17:72/10.63.193.31 by UDP :50824 -> 10.63.192.1:53
feb/02 21:27:01 hotspot,debug Hotspot: dhcp host 18:89:5B:0C:17:72/10.63.193.31 added, ip 10.63.193.31
feb/02 21:27:04 hotspot,debug Hotspot: dhcp host 10.63.194.52 removed: login timeout
feb/02 21:27:04 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by ICMP type<3> code<3> to 10.63.192.1
feb/02 21:27:04 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:27:10 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :13020 -> 10.63.192.1:53
feb/02 21:27:10 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:27:20 dhcp,info dhcp1 deassigned 10.63.194.33 from EC:88:92:40:CC:8B
feb/02 21:27:26 dhcp,info dhcp1 assigned 10.63.194.33 to EC:88:92:40:CC:8B
feb/02 21:27:27 dhcp,info dhcp1 deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
feb/02 21:27:27 dhcp,info dhcp1 assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
feb/02 21:27:28 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :16732 -> 10.63.192.1:53
feb/02 21:27:28 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:27:30 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :30498 -> 10.63.192.1:53
feb/02 21:27:30 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:27:40 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by TCP :49083 -> 108.168.177.6:5222
feb/02 21:27:40 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:27:44 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :58319 -> 10.63.192.1:53
feb/02 21:27:44 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:27:52 dhcp,info dhcp1 deassigned 10.63.193.44 from 6C:2F:2C:1C:E4:DC
feb/02 21:27:52 dhcp,info dhcp1 assigned 10.63.193.44 to 6C:2F:2C:1C:E4:DC
feb/02 21:27:52 hotspot,debug Hotspot: new host detected 6C:2F:2C:1C:E4:DC/10.63.193.44 by UDP :24305 -> 10.63.192.1:53
feb/02 21:27:52 hotspot,debug Hotspot: dhcp host 6C:2F:2C:1C:E4:DC/10.63.193.44 added, ip 10.63.193.44
feb/02 21:27:56 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.51 by UDP :22797 -> 8.8.8.8:53
feb/02 21:27:56 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.51, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:28:04 hotspot,info,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): logged out: keepalive timeout
feb/02 21:28:04 hotspot,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): removing queue
feb/02 21:28:04 hotspot,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): removing address-list
feb/02 21:28:04 hotspot,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): removing ip->user binding
feb/02 21:28:04 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: keepalive timeout
feb/02 21:28:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by TCP :35547 -> 169.55.69.138:443
feb/02 21:28:05 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:28:13 hotspot,info,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): trying to log in by trial
feb/02 21:28:13 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): using profile <00>
feb/02 21:28:13 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): adding ip->user binding
feb/02 21:28:13 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): adding address-list rule <00>
feb/02 21:28:13 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): adding queue <256k/256k 0/0 0/0 0/0 8 64k/64k>
feb/02 21:28:13 hotspot,account,info,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): logged in
feb/02 21:28:16 hotspot,debug Hotspot: dhcp host 10.63.194.27 removed: login timeout
feb/02 21:28:17 hotspot,debug Hotspot: new host detected 44:80:EB:CC:B2:5B/10.63.194.27 by TCP :40128 -> 216.58.222.14:443
feb/02 21:28:17 hotspot,debug Hotspot: dhcp host 44:80:EB:CC:B2:5B/10.63.194.27 added, ip 10.63.194.27
feb/02 21:28:20 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.194.52 by UDP :18748 -> 10.63.192.1:53
feb/02 21:28:20 hotspot,debug Hotspot: dhcp host C4:9A:02:61:DA:A3/10.63.194.52 added, ip 10.63.194.52
feb/02 21:28:28 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :46179 -> 10.63.192.1:53
feb/02 21:28:28 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:28:30 hotspot,info,debug T-64:89:9A:27:FA:67 (10.63.194.38): logged out: session timeout
feb/02 21:28:30 hotspot,debug T-64:89:9A:27:FA:67 (10.63.194.38): removing queue
feb/02 21:28:30 hotspot,debug T-64:89:9A:27:FA:67 (10.63.194.38): removing address-list
feb/02 21:28:30 hotspot,debug T-64:89:9A:27:FA:67 (10.63.194.38): removing ip->user binding
feb/02 21:28:31 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :2267 -> 10.63.192.1:53
feb/02 21:28:31 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:28:40 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by TCP :57475 -> 169.54.55.203:5222
feb/02 21:28:40 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:28:44 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :8756 -> 10.63.192.1:53
feb/02 21:28:44 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:28:57 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.51 by UDP :40344 -> 10.63.192.1:53
feb/02 21:28:57 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.51, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:28:58 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: login timeout
feb/02 21:28:59 dhcp,info dhcp1 deassigned 10.63.194.28 from 74:BA:DB:04:26:13
feb/02 21:28:59 hotspot,debug Hotspot: dhcp host 10.63.194.28 changed type to dynamic (remove after 5s)
feb/02 21:28:59 dhcp,info dhcp1 assigned 10.63.194.28 to 74:BA:DB:04:26:13
feb/02 21:28:59 hotspot,debug Hotspot: dynamic host 10.63.194.28 changed type to dhcp (got back lease)
feb/02 21:29:00 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:29:01 hotspot,debug Hotspot: dhcp host 10.63.193.31 removed: login timeout
feb/02 21:29:03 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged out: keepalive timeout
feb/02 21:29:03 hotspot,debug T-50:55:27:A0:E9:AF (10.63.193.133): removing queue
feb/02 21:29:03 hotspot,debug T-50:55:27:A0:E9:AF (10.63.193.133): removing address-list
feb/02 21:29:03 hotspot,debug T-50:55:27:A0:E9:AF (10.63.193.133): removing ip->user binding
feb/02 21:29:03 hotspot,debug Hotspot: dhcp host 10.63.193.133 removed: keepalive timeout
feb/02 21:29:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by UDP :7870 -> 10.63.192.1:53
feb/02 21:29:05 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:29:07 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :54056 -> 8.8.4.4:53
feb/02 21:29:07 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
feb/02 21:29:08 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by UDP :27061 -> 8.8.8.8:53
feb/02 21:29:08 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:29:30 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :46450 -> 10.63.192.1:53
feb/02 21:29:30 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:29:32 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :9922 -> 10.63.192.1:53
feb/02 21:29:32 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:29:44 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by TCP :39391 -> 31.13.73.1:443
feb/02 21:29:44 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:29:59 dhcp,info dhcp1 deassigned 10.63.194.52 from C4:9A:02:61:DA:A3
feb/02 21:29:59 hotspot,debug Hotspot: dhcp host 10.63.194.52 changed type to dynamic (remove after 5s)
feb/02 21:29:59 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.51 by UDP :19621 -> 10.63.192.1:53
feb/02 21:29:59 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.51, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:29:59 dhcp,info dhcp1 assigned 10.63.194.52 to C4:9A:02:61:DA:A3
feb/02 21:29:59 hotspot,debug Hotspot: dynamic host 10.63.194.52 changed type to dhcp (got back lease)
feb/02 21:30:03 script,error Google Down
feb/02 21:30:04 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :17300 -> 10.63.192.1:53
feb/02 21:30:04 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:30:13 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/179.200.153.41 by ICMP type<3> code<3> to 189.40.198.80
feb/02 21:30:13 hotspot,debug Hotspot: dhcp host 10.63.194.52 removed: limiting addresses per mac
feb/02 21:30:13 hotspot,debug Hotspot: dynamic host C4:9A:02:61:DA:A3/179.200.153.41 added, ip 10.63.193.2
feb/02 21:30:13 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.194.52 by TCP :48560 -> 216.58.222.14:80
feb/02 21:30:13 hotspot,debug Hotspot: dynamic host 10.63.193.2 removed: limiting addresses per mac
feb/02 21:30:13 hotspot,debug Hotspot: dhcp host C4:9A:02:61:DA:A3/10.63.194.52 added, ip 10.63.194.52
feb/02 21:30:13 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/179.200.153.41 by ICMP type<3> code<3> to 189.40.198.81
feb/02 21:30:14 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.194.52 by TCP :48560 -> 216.58.222.14:80
feb/02 21:30:14 hotspot,debug Hotspot: dynamic host 10.63.193.2 removed: limiting addresses per mac
feb/02 21:30:14 hotspot,debug Hotspot: dhcp host C4:9A:02:61:DA:A3/10.63.194.52 added, ip 10.63.194.52
feb/02 21:30:17 hotspot,debug Hotspot: dhcp host 10.63.194.27 removed: login timeout
feb/02 21:30:24 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by UDP :15384 -> 10.63.192.1:53
feb/02 21:30:24 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:30:25 hotspot,debug Hotspot: new host detected 18:89:5B:0C:17:72/10.63.193.31 by UDP :12239 -> 10.63.192.1:53
feb/02 21:30:25 hotspot,debug Hotspot: dhcp host 18:89:5B:0C:17:72/10.63.193.31 added, ip 10.63.193.31
feb/02 21:30:30 hotspot,debug Hotspot: dhcp host 10.63.194.38 removed: login timeout
feb/02 21:30:31 hotspot,debug Hotspot: new host detected 64:89:9A:27:FA:67/10.63.194.38 by TCP :54530 -> 169.45.87.176:443
feb/02 21:30:31 hotspot,debug Hotspot: dhcp host 64:89:9A:27:FA:67/10.63.194.38 added, ip 10.63.194.38
feb/02 21:30:32 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :17482 -> 10.63.192.1:53
feb/02 21:30:32 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:30:43 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :54439 -> 10.63.192.1:53
feb/02 21:30:43 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:30:53 dhcp,info dhcp1 assigned 10.63.194.17 to 84:38:38:FE:EE:9A
feb/02 21:30:54 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.17 by UDP :55538 -> 10.63.192.1:53
feb/02 21:30:54 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.17, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:31:01 script,warning Google Up
feb/02 21:31:02 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :12164 -> 10.63.192.1:53
feb/02 21:31:02 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.51 by TCP :37284 -> 66.220.158.19:443
feb/02 21:31:02 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:31:02 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.51, ip 10.63.194.55: max addresses per mac is reached
feb/02 21:31:05 dhcp,info dhcp1 deassigned 10.63.194.27 from 44:80:EB:CC:B2:5B
feb/02 21:31:07 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: login timeout
feb/02 21:31:08 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:31:22 wireless,info wlan: data from unknown device 60:D7:AE:C8:92:CC, sent deauth
feb/02 21:31:25 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by UDP :16105 -> 10.63.192.1:53
feb/02 21:31:25 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:31:35 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :36139 -> 10.63.192.1:53
feb/02 21:31:35 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:31:41 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by TCP :34044 -> 108.168.174.16:443
feb/02 21:31:41 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:31:46 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :29936 -> 10.63.192.1:53
feb/02 21:31:46 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:31:52 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by TCP :45614 -> 158.85.5.200:443
feb/02 21:31:52 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:31:59 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by UDP :38430 -> 10.63.192.1:53
feb/02 21:31:59 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 21:32:03 script,error Google Down
feb/02 21:32:04 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :63741 -> 10.63.192.1:53
feb/02 21:32:04 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:32:14 hotspot,debug Hotspot: dhcp host 10.63.194.52 removed: login timeout
feb/02 21:32:25 hotspot,debug Hotspot: dhcp host 10.63.193.31 removed: login timeout
feb/02 21:32:25 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by TCP :53085 -> 169.55.235.180:443
feb/02 21:32:25 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:32:25 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.17 by UDP :48532 -> 10.63.192.1:53
feb/02 21:32:25 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.17, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:32:31 hotspot,debug Hotspot: dhcp host 10.63.194.38 removed: login timeout
feb/02 21:32:31 hotspot,debug Hotspot: new host detected 64:89:9A:27:FA:67/10.63.194.38 by TCP :45820 -> 169.53.250.171:443
feb/02 21:32:31 hotspot,debug Hotspot: dhcp host 64:89:9A:27:FA:67/10.63.194.38 added, ip 10.63.194.38
feb/02 21:32:35 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by TCP :45430 -> 50.22.225.79:80
feb/02 21:32:35 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:32:42 hotspot,debug Hotspot: new host detected 18:89:5B:0C:17:72/10.63.193.31 by UDP :47665 -> 10.63.192.1:53
feb/02 21:32:42 hotspot,debug Hotspot: dhcp host 18:89:5B:0C:17:72/10.63.193.31 added, ip 10.63.193.31
feb/02 21:32:43 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :17525 -> 10.63.192.1:53
feb/02 21:32:43 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:32:46 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by TCP :34498 -> 158.85.58.59:80
feb/02 21:32:46 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:33:02 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
feb/02 21:33:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :18097 -> 10.63.192.1:53
feb/02 21:33:05 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:33:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by TCP :40453 -> 108.168.174.25:80
feb/02 21:33:05 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:33:06 hotspot,debug Hotspot: new host detected 60:D7:AE:C8:92:CC/10.63.193.51 by UDP :54348 -> 10.63.192.1:53
feb/02 21:33:06 hotspot,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): trying to log in by mac-cookie
feb/02 21:33:06 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): using profile <00>
feb/02 21:33:06 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): adding ip->user binding
feb/02 21:33:06 hotspot,debug Hotspot: dhcp host 60:D7:AE:C8:92:CC/10.63.193.51 added, ip 10.63.193.51
feb/02 21:33:06 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): adding address-list rule <00>
feb/02 21:33:06 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): adding queue <256k/256k 0/0 0/0 0/0 8 64k/64k>
feb/02 21:33:06 hotspot,account,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): logged in
feb/02 21:33:08 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by UDP :47811 -> 10.63.192.1:53
feb/02 21:33:08 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:33:08 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by UDP :20871 -> 10.63.192.1:53
feb/02 21:33:08 hotspot,info,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): trying to log in by mac-cookie
feb/02 21:33:08 hotspot,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): using profile <00>
feb/02 21:33:08 hotspot,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): adding ip->user binding
feb/02 21:33:08 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 21:33:08 hotspot,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): adding address-list rule <00>
feb/02 21:33:08 hotspot,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): adding queue <256k/256k 0/0 0/0 0/0 8 64k/64k>
feb/02 21:33:08 hotspot,account,info,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): logged in
feb/02 21:33:10 dhcp,info dhcp1 assigned 10.63.194.56 to C4:43:8F:5F:3A:33
feb/02 21:33:26 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by UDP :65164 -> 10.63.192.1:53
feb/02 21:33:26 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:33:31 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.17 by UDP :41718 -> 10.63.192.1:53
feb/02 21:33:31 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.17, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:33:36 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :59424 -> 10.63.192.1:53
feb/02 21:33:36 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:33:48 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :62956 -> 10.63.192.1:53
feb/02 21:33:48 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:33:59 dhcp,info dhcp1 deassigned 10.63.193.21 from 20:55:31:66:20:D8
feb/02 21:33:59 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 21:34:01 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :22917 -> 10.63.192.1:53
feb/02 21:34:01 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:34:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :23141 -> 10.63.192.1:53
feb/02 21:34:05 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:34:06 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by TCP :38175 -> 158.85.58.39:443
feb/02 21:34:06 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:34:17 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :49901 -> 218.213.248.137:80
feb/02 21:34:17 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 21:34:31 hotspot,debug Hotspot: dhcp host 10.63.194.38 removed: login timeout
feb/02 21:34:37 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by TCP :53718 -> 174.37.217.93:80
feb/02 21:34:37 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:34:40 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.133 by TCP :32965 -> 174.37.231.91:5222
feb/02 21:34:40 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.133, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:34:42 hotspot,debug Hotspot: dhcp host 10.63.193.31 removed: login timeout
feb/02 21:34:43 hotspot,debug Hotspot: new host detected 18:89:5B:0C:17:72/10.63.193.31 by UDP :7945 -> 10.63.192.1:53
feb/02 21:34:43 hotspot,debug Hotspot: dhcp host 18:89:5B:0C:17:72/10.63.193.31 added, ip 10.63.193.31
feb/02 21:34:49 dhcp,info dhcp1 assigned 10.63.193.41 to 88:C9:D0:DE:85:AB
feb/02 21:34:52 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :61245 -> 10.63.192.1:53
feb/02 21:34:52 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:34:53 hotspot,debug Hotspot: new host detected 88:C9:D0:DE:85:AB/10.63.193.41 by UDP :17913 -> 192.168.2.2:53
feb/02 21:34:53 hotspot,debug Hotspot: dhcp host 88:C9:D0:DE:85:AB/10.63.193.41 added, ip 10.63.193.41
feb/02 21:34:54 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.17 by UDP :33033 -> 10.63.192.1:53
feb/02 21:34:54 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.17, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:35:06 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by TCP :39789 -> 66.220.158.68:443
feb/02 21:35:06 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:35:06 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :13609 -> 10.63.192.1:53
feb/02 21:35:06 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:35:08 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:35:10 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by TCP :53331 -> 216.58.202.14:443
feb/02 21:35:10 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:35:18 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.194.52 by UDP :35916 -> 10.63.192.1:53
feb/02 21:35:18 hotspot,debug Hotspot: dhcp host C4:9A:02:61:DA:A3/10.63.194.52 added, ip 10.63.194.52
feb/02 21:35:19 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/100.73.26.60 by TCP :47569 -> 10.63.192.1:7
feb/02 21:35:19 hotspot,debug Hotspot: dhcp host 10.63.194.52 removed: limiting addresses per mac
feb/02 21:35:19 hotspot,debug Hotspot: dynamic host C4:9A:02:61:DA:A3/100.73.26.60 added, ip 10.63.193.2
feb/02 21:35:19 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.194.52 by TCP :54969 -> 216.58.202.46:80
feb/02 21:35:19 hotspot,debug Hotspot: dynamic host 10.63.193.2 removed: limiting addresses per mac
feb/02 21:35:19 hotspot,debug Hotspot: dhcp host C4:9A:02:61:DA:A3/10.63.194.52 added, ip 10.63.194.52
feb/02 21:35:26 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by TCP :43916 -> 158.85.58.44:5222
feb/02 21:35:26 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:35:29 hotspot,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): logged out: keepalive timeout
feb/02 21:35:29 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): removing queue
feb/02 21:35:29 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): removing address-list
feb/02 21:35:29 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): removing ip->user binding
feb/02 21:35:29 hotspot,debug Hotspot: dhcp host 10.63.193.51 removed: keepalive timeout
feb/02 21:35:53 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :37456 -> 10.63.192.1:53
feb/02 21:35:53 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:36:02 script,warning Google Up
feb/02 21:36:07 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.17 by UDP :45858 -> 10.63.192.1:53
feb/02 21:36:07 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.17, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:36:15 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.48 by UDP :57187 -> 10.63.192.1:53
feb/02 21:36:15 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.48, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:36:17 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 21:36:17 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :33910 -> 10.63.192.1:80
feb/02 21:36:17 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 21:36:25 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :6955 -> 10.63.192.1:53
feb/02 21:36:25 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:36:27 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :28604 -> 10.63.192.1:53
feb/02 21:36:27 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:36:28 hotspot,debug Hotspot: new host detected 50:55:27:A0:E9:AF/10.63.193.133 by ICMP type<3> code<3> to 10.63.192.1
feb/02 21:36:28 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): trying to log in by mac-cookie
feb/02 21:36:28 hotspot,debug T-50:55:27:A0:E9:AF (10.63.193.133): using profile <00>
feb/02 21:36:28 hotspot,debug T-50:55:27:A0:E9:AF (10.63.193.133): adding ip->user binding
feb/02 21:36:28 hotspot,debug Hotspot: dhcp host 50:55:27:A0:E9:AF/10.63.193.133 added, ip 10.63.193.133
feb/02 21:36:28 hotspot,debug T-50:55:27:A0:E9:AF (10.63.193.133): adding address-list rule <00>
feb/02 21:36:28 hotspot,debug T-50:55:27:A0:E9:AF (10.63.193.133): adding queue <256k/256k 0/0 0/0 0/0 8 64k/64k>
feb/02 21:36:28 hotspot,account,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged in
feb/02 21:36:31 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :58847 -> 10.63.192.1:53
feb/02 21:36:31 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:36:43 hotspot,debug Hotspot: dhcp host 10.63.193.31 removed: login timeout
feb/02 21:36:53 hotspot,debug Hotspot: dhcp host 10.63.193.41 removed: login timeout
feb/02 21:36:53 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by TCP :38014 -> 50.22.225.77:5222
feb/02 21:36:53 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:37:00 dhcp,info dhcp1 assigned 10.63.193.28 to F4:0E:22:7E:AB:C8
feb/02 21:37:10 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:37:13 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :37782 -> 10.63.192.1:53
feb/02 21:37:13 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.28, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:37:19 hotspot,debug Hotspot: dhcp host 10.63.194.52 removed: login timeout
feb/02 21:37:20 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 21:37:21 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.17 by UDP :34246 -> 10.63.192.1:53
feb/02 21:37:21 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.17, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:37:28 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :3533 -> 10.63.192.1:53
feb/02 21:37:28 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:37:30 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :53855 -> 10.63.192.1:53
feb/02 21:37:30 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:37:38 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by UDP :23402 -> 8.8.8.8:53
feb/02 21:37:38 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:37:54 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :41620 -> 10.63.192.1:53
feb/02 21:37:54 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:38:14 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :6316 -> 10.63.192.1:53
feb/02 21:38:14 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:38:17 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 21:38:31 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :53357 -> 8.8.4.4:53
feb/02 21:38:31 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:38:34 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.17 by UDP :39743 -> 10.63.192.1:53
feb/02 21:38:34 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.17, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:38:36 dhcp,info dhcp1 assigned 10.63.194.58 to C4:9A:02:5D:A1:DC
feb/02 21:38:37 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.58 by UDP :58815 -> 10.63.192.1:53
feb/02 21:38:37 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.58, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:38:38 dhcp,info dhcp1 deassigned 10.63.194.58 from C4:9A:02:5D:A1:DC
feb/02 21:38:39 dhcp,info dhcp1 assigned 10.63.194.58 to C4:9A:02:5D:A1:DC
feb/02 21:38:46 hotspot,info,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): logged out: keepalive timeout
feb/02 21:38:46 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): removing queue
feb/02 21:38:46 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): removing address-list
feb/02 21:38:46 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): removing ip->user binding
feb/02 21:38:46 hotspot,debug Hotspot: dhcp host 10.63.193.44 removed: keepalive timeout
feb/02 21:38:54 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :2919 -> 10.63.192.1:53
feb/02 21:38:54 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:38:56 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :32141 -> 10.63.192.1:53
feb/02 21:38:56 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:39:07 dhcp,info dhcp1 assigned 10.63.194.54 to 84:11:9E:C2:02:FE
feb/02 21:39:08 hotspot,debug Hotspot: new host detected 84:11:9E:C2:02:FE/10.63.194.54 by UDP :42279 -> 10.63.192.1:53
feb/02 21:39:08 hotspot,debug Hotspot: dhcp host 84:11:9E:C2:02:FE/10.63.194.54 added, ip 10.63.194.54
feb/02 21:39:15 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :47014 -> 10.63.192.1:53
feb/02 21:39:15 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.28, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:39:38 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:39:42 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :24711 -> 10.63.192.1:53
feb/02 21:39:42 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.59, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:39:48 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by TCP :40020 -> 184.173.161.173:80
feb/02 21:39:48 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:39:59 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :17659 -> 10.63.192.1:53
feb/02 21:39:59 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:40:00 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :52251 -> 10.63.192.1:53
feb/02 21:40:00 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:40:00 dhcp,info dhcp1 deassigned 10.63.194.58 from C4:9A:02:5D:A1:DC
feb/02 21:40:01 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.194.52 by UDP :9347 -> 10.63.192.1:53
feb/02 21:40:01 hotspot,debug Hotspot: dhcp host C4:9A:02:61:DA:A3/10.63.194.52 added, ip 10.63.194.52
feb/02 21:40:21 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :41586 -> 10.63.192.1:53
feb/02 21:40:21 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.28, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:40:21 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by TCP :55497 -> 158.85.58.22:80
feb/02 21:40:21 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:40:30 dhcp,info dhcp1 deassigned 10.63.194.52 from C4:9A:02:61:DA:A3
feb/02 21:40:30 hotspot,debug Hotspot: dhcp host 10.63.194.52 changed type to dynamic (remove after 5s)
feb/02 21:40:35 hotspot,debug Hotspot: dynamic host 10.63.194.52 removed: lost dhcp lease
feb/02 21:41:01 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :31608 -> 10.63.192.1:53
feb/02 21:41:01 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.13, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:41:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :22134 -> 10.63.192.1:53
feb/02 21:41:05 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.18, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:41:08 hotspot,debug Hotspot: new host detected 6C:2F:2C:1C:E4:DC/10.63.193.44 by UDP :37362 -> 10.63.192.1:53
feb/02 21:41:08 hotspot,info,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): trying to log in by mac-cookie
feb/02 21:41:08 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): using profile <00>
feb/02 21:41:08 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): adding ip->user binding
feb/02 21:41:08 hotspot,debug Hotspot: dhcp host 6C:2F:2C:1C:E4:DC/10.63.193.44 added, ip 10.63.193.44
feb/02 21:41:08 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): adding address-list rule <00>
feb/02 21:41:08 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): adding queue <256k/256k 0/0 0/0 0/0 8 64k/64k>
feb/02 21:41:08 hotspot,account,info,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): logged in
feb/02 21:41:08 hotspot,debug Hotspot: dhcp host 10.63.194.54 removed: login timeout
feb/02 21:41:13 dhcp,info dhcp1 deassigned 10.63.193.23 from 38:2D:D1:A5:04:39
feb/02 21:41:14 dhcp,info dhcp1 assigned 10.63.194.52 to C4:9A:02:61:DA:A3
feb/02 21:41:15 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.194.52 by UDP :28868 -> 10.63.192.1:53
feb/02 21:41:15 hotspot,debug Hotspot: dhcp host C4:9A:02:61:DA:A3/10.63.194.52 added, ip 10.63.194.52
feb/02 21:41:16 dhcp,info dhcp1 assigned 10.63.193.23 to 38:2D:D1:A5:04:39
feb/02 21:41:17 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by UDP :37813 -> 10.63.192.1:53
feb/02 21:41:17 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 21:41:26 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :44392 -> 10.63.192.1:53
feb/02 21:41:26 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.193.28, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:41:27 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :35275 -> 10.63.192.1:53
feb/02 21:41:27 hotspot,debug Hotspot: failed to add dynamic host 4C:5E:0C:CA:05:46/10.63.194.33, ip 10.63.193.150: max addresses per mac is reached
feb/02 21:41:48 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:41:48 system,info log rule removed by ersitizastes
feb/02 21:42:41 hotspot,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): trying to log in by mac-cookie
feb/02 21:42:41 hotspot,account,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): logged in
feb/02 21:42:47 dhcp,info dhcp1 deassigned 10.63.193.44 from 6C:2F:2C:1C:E4:DC
feb/02 21:42:47 dhcp,info dhcp1 assigned 10.63.194.61 to 14:32:D1:1C:E1:24
feb/02 21:42:52 hotspot,info,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): logged out: lost dhcp lease
feb/02 21:43:49 wireless,info wlan: data from unknown device 64:6C:B2:51:9E:0D, sent deauth
feb/02 21:44:03 system,info hotspot server Hotspot changed by ersitizastes
feb/02 21:45:24 dhcp,info dhcp1 deassigned 10.63.194.28 from 74:BA:DB:04:26:13
feb/02 21:45:24 dhcp,info dhcp1 assigned 10.63.194.28 to 74:BA:DB:04:26:13
feb/02 21:45:35 wireless,info wlan: data from unknown device 64:6C:B2:51:9E:0D, sent deauth
feb/02 21:46:51 hotspot,info,debug T-F4:F1:E1:F4:62:F6 (10.63.193.3): logged out: session timeout
feb/02 21:47:05 wireless,info wlan: data from unknown device 64:6C:B2:51:9E:0D, sent deauth
feb/02 21:47:11 hotspot,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): logged out: keepalive timeout
feb/02 21:47:14 dhcp,info dhcp1 deassigned 10.63.194.42 from 34:FC:EF:CF:50:24
feb/02 21:47:15 dhcp,info dhcp1 deassigned 10.63.194.36 from 50:B7:C3:CC:5C:A8
feb/02 21:47:24 dhcp,info dhcp1 assigned 10.63.194.42 to 34:FC:EF:CF:50:24
feb/02 21:47:52 system,info hotspot server Hotspot changed by ersitizastes
feb/02 21:49:11 wireless,info wlan: data from unknown device 64:6C:B2:51:9E:0D, sent deauth
feb/02 21:50:00 dhcp,info dhcp1 deassigned 10.63.194.39 from 58:A2:B5:DA:FD:96
feb/02 21:50:38 hotspot,info,debug T-50:55:27:A0:E9:AF (10.63.193.133): logged out: session timeout
feb/02 21:50:38 hotspot,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): trying to log in by mac-cookie
feb/02 21:50:38 hotspot,account,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): logged in
feb/02 21:50:55 system,info hotspot ip binding rule changed by ersitizastes
feb/02 21:51:42 wireless,info wlan: data from unknown device 64:6C:B2:51:9E:0D, sent deauth
feb/02 21:51:43 wireless,info wlan: data from unknown device 64:6C:B2:51:9E:0D, sent deauth
feb/02 21:51:45 wireless,info wlan: data from unknown device 64:6C:B2:51:9E:0D, sent deauth
feb/02 21:52:06 dhcp,info dhcp1 assigned 10.63.194.67 to 64:6C:B2:51:9E:0D
feb/02 21:52:08 system,info hotspot ip binding rule changed by ersitizastes
feb/02 21:52:59 dhcp,info dhcp1 assigned 10.63.193.44 to 6C:2F:2C:1C:E4:DC
feb/02 21:53:00 hotspot,info,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): trying to log in by mac-cookie
feb/02 21:53:00 hotspot,account,info,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): logged in
feb/02 21:53:05 hotspot,info,debug T-64:6C:B2:51:9E:0D (10.63.194.67): trying to log in by trial
feb/02 21:53:05 hotspot,account,info,debug T-64:6C:B2:51:9E:0D (10.63.194.67): logged in
feb/02 21:53:07 dhcp,info dhcp1 deassigned 10.63.194.34 from 20:55:31:74:FC:48
feb/02 21:53:25 dhcp,info dhcp1 assigned 10.63.194.69 to 1C:B7:2C:C4:61:14
feb/02 21:53:52 dhcp,info dhcp1 assigned 10.63.194.34 to 20:55:31:74:FC:48
feb/02 21:54:28 system,info log rule added by ersitizastes
feb/02 21:54:40 hotspot,debug Hotspot: dynamic host 10.63.194.37 removed: login timeout
feb/02 21:54:42 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:54:51 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 21:54:51 dhcp,info dhcp1 deassigned 10.63.194.40 from 34:FC:EF:D1:29:25
feb/02 21:54:53 hotspot,debug Hotspot: dynamic host 10.63.194.68 removed: login timeout
feb/02 21:54:54 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :7659 -> 10.63.192.1:53
feb/02 21:54:54 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.33 added, ip 10.63.193.150
feb/02 21:54:54 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by UDP :33474 -> 10.63.192.1:53
feb/02 21:54:54 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:54:54 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :42915 -> 10.63.192.1:53
feb/02 21:54:54 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.13 added, ip 10.63.194.72
feb/02 21:55:15 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
feb/02 21:55:18 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
feb/02 21:55:18 hotspot,debug Hotspot: dhcp host 10.63.193.51 changed type to dynamic (remove after 5s)
feb/02 21:55:18 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
feb/02 21:55:18 hotspot,debug Hotspot: dynamic host 10.63.193.51 changed type to dhcp (got back lease)
feb/02 21:55:21 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :18135 -> 10.63.192.1:53
feb/02 21:55:21 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.18 added, ip 10.63.194.37
feb/02 21:55:26 hotspot,debug Hotspot: dynamic host 10.63.194.70 removed: login timeout
feb/02 21:55:28 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 21:55:36 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.69 by TCP :48081 -> 31.13.85.2:443
feb/02 21:55:36 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.69 added, ip 10.63.194.73
feb/02 21:55:50 hotspot,debug Hotspot: dynamic host 10.63.194.29 removed: login timeout
feb/02 21:55:54 hotspot,debug Hotspot: dynamic host 10.63.194.71 removed: login timeout
feb/02 21:56:01 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 21:56:02 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :42140 -> 10.63.192.1:53
feb/02 21:56:02 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.194.29
feb/02 21:56:03 hotspot,debug Hotspot: dynamic host 10.63.194.45 removed: login timeout
feb/02 21:56:20 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :42004 -> 173.194.209.188:5228
feb/02 21:56:20 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 21:56:32 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :3590 -> 10.63.192.1:53
feb/02 21:56:32 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.59 added, ip 10.63.194.74
feb/02 21:56:54 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 21:56:54 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:56:54 hotspot,debug Hotspot: dynamic host 10.63.194.72 removed: login timeout
feb/02 21:57:08 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :38800 -> 10.63.192.1:53
feb/02 21:57:08 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.13 added, ip 10.63.193.150
feb/02 21:57:13 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 21:57:16 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
feb/02 21:57:16 hotspot,debug Hotspot: dhcp host 10.63.193.51 changed type to dynamic (remove after 5s)
feb/02 21:57:16 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
feb/02 21:57:16 hotspot,debug Hotspot: dynamic host 10.63.193.51 changed type to dhcp (got back lease)
feb/02 21:57:21 hotspot,debug Hotspot: dynamic host 10.63.194.37 removed: login timeout
feb/02 21:57:22 dhcp,info dhcp1 deassigned 10.63.194.28 from 74:BA:DB:04:26:13
feb/02 21:57:22 dhcp,info dhcp1 assigned 10.63.194.28 to 74:BA:DB:04:26:13
feb/02 21:57:23 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by TCP :60109 -> 183.61.112.123:80
feb/02 21:57:23 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 21:57:26 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by UDP :8494 -> 10.63.192.1:53
feb/02 21:57:26 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 21:57:36 hotspot,debug Hotspot: dynamic host 10.63.194.73 removed: login timeout
feb/02 21:57:46 system,info,account user ersitizastes logged in from 10.63.192.255 via telnet
feb/02 21:58:02 hotspot,debug Hotspot: dynamic host 10.63.194.29 removed: login timeout
feb/02 21:58:06 dhcp,info dhcp1 deassigned 10.63.194.41 from 34:FC:EF:D3:AD:1D
feb/02 21:58:13 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :50240 -> 10.63.192.1:53
feb/02 21:58:13 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.194.75
feb/02 21:58:20 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 21:58:32 hotspot,debug Hotspot: dynamic host 10.63.194.74 removed: login timeout
feb/02 21:58:38 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :47184 -> 178.162.219.58:443
feb/02 21:58:38 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 21:58:39 dhcp,info dhcp1 assigned 10.63.194.58 to C4:9A:02:5D:A1:DC
feb/02 21:58:39 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.58 by UDP :10227 -> 10.63.192.1:53
feb/02 21:58:39 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.58 added, ip 10.63.194.29
feb/02 21:59:08 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 21:59:16 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by TCP :42993 -> 158.85.58.9:80
feb/02 21:59:16 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.13 added, ip 10.63.193.150
feb/02 21:59:17 dhcp,info dhcp1 deassigned 10.63.194.33 from EC:88:92:40:CC:8B
feb/02 21:59:23 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 21:59:27 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 21:59:27 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :1060 -> 10.63.192.1:53
feb/02 21:59:27 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.18 added, ip 10.63.194.76
feb/02 21:59:29 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by TCP :43232 -> 69.28.57.171:8888
feb/02 21:59:29 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 22:00:03 script,error Google Down
feb/02 22:00:07 dhcp,info dhcp1 deassigned 10.63.194.35 from F4:F1:E1:1E:3A:2C
feb/02 22:00:11 dhcp,info dhcp1 assigned 10.63.194.35 to F4:F1:E1:1E:3A:2C
feb/02 22:00:13 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :65228 -> 10.63.192.1:53
feb/02 22:00:13 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
feb/02 22:00:13 hotspot,debug Hotspot: dynamic host 10.63.194.75 removed: login timeout
feb/02 22:00:15 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
feb/02 22:00:15 hotspot,debug Hotspot: dhcp host 10.63.193.51 changed type to dynamic (remove after 5s)
feb/02 22:00:19 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
feb/02 22:00:19 hotspot,debug Hotspot: dynamic host 10.63.193.51 changed type to dhcp (got back lease)
feb/02 22:00:24 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :60884 -> 10.63.192.1:53
feb/02 22:00:24 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.194.77
feb/02 22:00:38 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 22:00:39 hotspot,debug Hotspot: dynamic host 10.63.194.29 removed: login timeout
feb/02 22:00:40 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.58 by UDP :63722 -> 10.63.192.1:53
feb/02 22:00:40 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.58 added, ip 10.63.194.29
feb/02 22:00:53 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :59332 -> 31.13.73.3:443
feb/02 22:00:53 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 22:01:16 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 22:01:16 dhcp,info dhcp1 deassigned 10.63.193.37 from 14:1A:A3:68:7E:60
feb/02 22:01:27 hotspot,debug Hotspot: dynamic host 10.63.194.76 removed: login timeout
feb/02 22:01:29 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 22:01:32 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by UDP :55165 -> 8.8.8.8:53
feb/02 22:01:32 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 22:01:37 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :60193 -> 10.63.192.1:53
feb/02 22:01:37 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.13 added, ip 10.63.193.150
feb/02 22:02:03 script,warning Google Up
feb/02 22:02:13 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: login timeout
feb/02 22:02:24 hotspot,debug Hotspot: dynamic host 10.63.194.77 removed: login timeout
feb/02 22:02:40 hotspot,debug Hotspot: dynamic host 10.63.194.29 removed: login timeout
feb/02 22:02:44 interface,info ether9 link down
feb/02 22:02:53 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 22:03:00 script,error 5g.net 1 Down
feb/02 22:03:03 script,error 5g.net 2 Down
feb/02 22:03:11 interface,info ether9 link up (speed 100M, full duplex)
feb/02 22:03:13 dhcp,info dhcp1 deassigned 10.63.193.16 from 9C:D3:5B:51:B7:AE
feb/02 22:03:30 hotspot,info,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): logged out: keepalive timeout
feb/02 22:03:30 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): removing queue
feb/02 22:03:30 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): removing address-list
feb/02 22:03:30 hotspot,debug T-6C:2F:2C:1C:E4:DC (10.63.193.44): removing ip->user binding
feb/02 22:03:30 hotspot,debug Hotspot: dhcp host 10.63.193.44 removed: keepalive timeout
feb/02 22:03:32 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 22:03:36 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by UDP :9639 -> 10.63.192.1:53
feb/02 22:03:36 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 22:03:37 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 22:03:41 dhcp,info dhcp1 deassigned 10.63.193.23 from 38:2D:D1:A5:04:39
feb/02 22:03:41 dhcp,info dhcp1 assigned 10.63.193.23 to 38:2D:D1:A5:04:39
feb/02 22:03:41 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by UDP :22301 -> 10.63.192.1:53
feb/02 22:03:41 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 22:03:42 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :42807 -> 10.63.192.1:53
feb/02 22:03:42 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.193.150
feb/02 22:04:00 script,warning 5g.net 1 Up
feb/02 22:04:00 script,warning 5g.net 2 Up
feb/02 22:04:26 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
feb/02 22:04:26 hotspot,debug Hotspot: dhcp host 10.63.193.51 changed type to dynamic (remove after 5s)
feb/02 22:04:31 hotspot,info,debug T-60:D7:AE:C8:92:CC (10.63.193.51): logged out: lost dhcp lease
feb/02 22:04:31 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): removing queue
feb/02 22:04:31 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): removing address-list
feb/02 22:04:31 hotspot,debug T-60:D7:AE:C8:92:CC (10.63.193.51): removing ip->user binding
feb/02 22:04:31 hotspot,debug Hotspot: dynamic host 10.63.193.51 removed: lost dhcp lease
feb/02 22:04:33 dhcp,info dhcp1 deassigned 10.63.194.44 from B8:5A:73:B1:50:E0
feb/02 22:04:42 hotspot,info,debug T-64:6C:B2:51:9E:0D (10.63.194.67): logged out: keepalive timeout
feb/02 22:04:42 hotspot,debug T-64:6C:B2:51:9E:0D (10.63.194.67): removing queue
feb/02 22:04:42 hotspot,debug T-64:6C:B2:51:9E:0D (10.63.194.67): removing address-list
feb/02 22:04:42 hotspot,debug T-64:6C:B2:51:9E:0D (10.63.194.67): removing ip->user binding
feb/02 22:04:42 hotspot,debug Hotspot: dhcp host 10.63.194.67 removed: keepalive timeout
feb/02 22:05:02 dhcp,info dhcp1 deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
feb/02 22:05:04 hotspot,debug Hotspot: new host detected 64:6C:B2:51:9E:0D/10.63.194.67 by UDP :56050 -> 10.63.192.1:53
feb/02 22:05:04 hotspot,info,debug T-64:6C:B2:51:9E:0D (10.63.194.67): trying to log in by mac-cookie
feb/02 22:05:04 hotspot,debug T-64:6C:B2:51:9E:0D (10.63.194.67): using profile <00>
feb/02 22:05:04 hotspot,debug T-64:6C:B2:51:9E:0D (10.63.194.67): adding ip->user binding
feb/02 22:05:04 hotspot,debug Hotspot: dhcp host 64:6C:B2:51:9E:0D/10.63.194.67 added, ip 10.63.194.67
feb/02 22:05:04 hotspot,debug T-64:6C:B2:51:9E:0D (10.63.194.67): adding address-list rule <00>
feb/02 22:05:04 hotspot,debug T-64:6C:B2:51:9E:0D (10.63.194.67): adding queue <256k/256k 0/0 0/0 0/0 8 64k/64k>
feb/02 22:05:04 hotspot,account,info,debug T-64:6C:B2:51:9E:0D (10.63.194.67): logged in
feb/02 22:05:07 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.58 by UDP :40420 -> 10.63.192.1:53
feb/02 22:05:07 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.58 added, ip 10.63.194.78
feb/02 22:05:17 dhcp,info dhcp1 assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
feb/02 22:05:18 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.13 by UDP :22291 -> 10.63.192.1:53
feb/02 22:05:18 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.13 added, ip 10.63.194.29
feb/02 22:05:36 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 22:05:36 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by TCP :35068 -> 173.194.118.68:443
feb/02 22:05:36 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 22:05:41 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 22:05:42 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 22:05:46 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :40330 -> 10.63.192.1:53
feb/02 22:05:46 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.193.150
feb/02 22:06:04 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
feb/02 22:06:04 system,info,account user ersitizastes logged out from 10.63.192.255 via telnet
feb/02 22:07:07 hotspot,debug Hotspot: dynamic host 10.63.194.78 removed: login timeout
feb/02 22:07:18 hotspot,debug Hotspot: dynamic host 10.63.194.29 removed: login timeout
feb/02 22:07:33 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :18061 -> 10.63.192.1:53
feb/02 22:07:33 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.59 added, ip 10.63.194.80
feb/02 22:07:36 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 22:07:36 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by TCP :59255 -> 173.194.118.65:443
feb/02 22:07:36 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 22:07:39 dhcp,info dhcp1 deassigned 10.63.193.59 from F8:A9:D0:5A:F4:85
feb/02 22:07:39 dhcp,info dhcp1 assigned 10.63.193.59 to F8:A9:D0:5A:F4:85
feb/02 22:07:46 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 22:07:53 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :49504 -> 10.63.192.1:53
feb/02 22:07:53 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.193.150
feb/02 22:07:59 dhcp,info dhcp1 deassigned 10.63.194.58 from C4:9A:02:5D:A1:DC
feb/02 22:07:59 dhcp,info dhcp1 assigned 10.63.194.58 to C4:9A:02:5D:A1:DC
feb/02 22:08:02 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.58 by UDP :51208 -> 10.63.192.1:53
feb/02 22:08:02 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.58 added, ip 10.63.194.81
feb/02 22:08:03 script,error Google Down
feb/02 22:08:23 dhcp,info dhcp1 deassigned 10.63.193.90 from C4:3A:BE:D2:D1:20
feb/02 22:08:54 dhcp,info dhcp1 deassigned 10.63.193.23 from 38:2D:D1:A5:04:39
feb/02 22:09:01 script,warning Google Up
feb/02 22:09:33 hotspot,debug Hotspot: dynamic host 10.63.194.80 removed: login timeout
feb/02 22:09:33 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :52890 -> 10.63.192.1:53
feb/02 22:09:33 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.59 added, ip 10.63.194.29
feb/02 22:09:36 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 22:09:44 dhcp,info dhcp1 assigned 10.63.193.23 to 38:2D:D1:A5:04:39
feb/02 22:09:44 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by UDP :2587 -> 10.63.192.1:53
feb/02 22:09:44 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 22:09:53 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 22:09:53 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :55006 -> 10.63.192.1:53
feb/02 22:09:53 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.193.150
feb/02 22:10:01 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by TCP :55498 -> 205.251.251.114:80
feb/02 22:10:01 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 22:10:02 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :47629 -> 10.63.192.1:53
feb/02 22:10:02 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.18 added, ip 10.63.194.82
feb/02 22:10:02 hotspot,debug Hotspot: dynamic host 10.63.194.81 removed: login timeout
feb/02 22:10:28 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :46346 -> 8.8.8.8:53
feb/02 22:10:28 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
feb/02 22:10:45 wireless,info wlan: data from unknown device 00:F4:6F:F6:0A:DF, sent deauth
feb/02 22:11:24 wireless,info wlan: data from unknown device 00:F4:6F:F6:0A:DF, sent deauth
feb/02 22:11:26 wireless,info wlan: data from unknown device 00:F4:6F:F6:0A:DF, sent deauth
feb/02 22:11:33 hotspot,debug Hotspot: dynamic host 10.63.194.29 removed: login timeout
feb/02 22:11:44 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 22:11:44 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :32956 -> 61.145.124.57:80
feb/02 22:11:44 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 22:11:53 dhcp,info dhcp1 assigned 10.63.194.84 to 00:F4:6F:F6:0A:DF
feb/02 22:11:53 hotspot,debug Hotspot: new host detected 00:F4:6F:F6:0A:DF/10.63.194.84 by UDP :38280 -> 10.63.192.1:53
feb/02 22:11:53 hotspot,debug Hotspot: dhcp host 00:F4:6F:F6:0A:DF/10.63.194.84 added, ip 10.63.194.84
feb/02 22:11:53 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 22:12:01 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 22:12:02 hotspot,debug Hotspot: dynamic host 10.63.194.82 removed: login timeout
feb/02 22:12:05 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :46675 -> 10.63.192.1:53
feb/02 22:12:05 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.193.150
feb/02 22:12:06 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :4737 -> 10.63.192.1:53
feb/02 22:12:06 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.18 added, ip 10.63.194.86
feb/02 22:12:12 hotspot,info,debug T-00:F4:6F:F6:0A:DF (10.63.194.84): trying to log in by trial
feb/02 22:12:12 hotspot,debug T-00:F4:6F:F6:0A:DF (10.63.194.84): using profile <00>
feb/02 22:12:12 hotspot,debug T-00:F4:6F:F6:0A:DF (10.63.194.84): adding ip->user binding
feb/02 22:12:12 hotspot,debug T-00:F4:6F:F6:0A:DF (10.63.194.84): adding address-list rule <00>
feb/02 22:12:12 hotspot,debug T-00:F4:6F:F6:0A:DF (10.63.194.84): adding queue <256k/256k 0/0 0/0 0/0 8 64k/64k>
feb/02 22:12:12 hotspot,account,info,debug T-00:F4:6F:F6:0A:DF (10.63.194.84): logged in
feb/02 22:12:17 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :46746 -> 10.63.192.1:53
feb/02 22:12:17 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.59 added, ip 10.63.194.29
feb/02 22:12:21 dhcp,info dhcp1 deassigned 10.63.194.28 from 74:BA:DB:04:26:13
feb/02 22:12:21 dhcp,info dhcp1 assigned 10.63.194.28 to 74:BA:DB:04:26:13
feb/02 22:12:25 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by UDP :44460 -> 10.63.192.1:53
feb/02 22:12:25 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 22:12:25 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by UDP :1274 -> 10.63.192.1:53
feb/02 22:12:25 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 22:12:28 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: login timeout
feb/02 22:12:42 dhcp,info dhcp1 assigned 10.63.194.87 to 84:11:9E:C3:1F:FE
feb/02 22:12:47 hotspot,debug Hotspot: new host detected 84:11:9E:C3:1F:FE/10.63.194.87 by TCP :48754 -> 31.13.71.3:443
feb/02 22:12:47 hotspot,debug Hotspot: dhcp host 84:11:9E:C3:1F:FE/10.63.194.87 added, ip 10.63.194.87
feb/02 22:12:52 dhcp,info dhcp1 assigned 10.63.194.85 to 0C:B3:19:E9:AE:30
feb/02 22:12:53 hotspot,debug Hotspot: new host detected 0C:B3:19:E9:AE:30/10.63.194.85 by UDP :44941 -> 10.63.192.1:53
feb/02 22:12:53 hotspot,debug Hotspot: dhcp host 0C:B3:19:E9:AE:30/10.63.194.85 added, ip 10.63.194.85
feb/02 22:12:55 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
feb/02 22:12:55 system,info,account user ersitizastes logged in from 10.63.192.255 via telnet
feb/02 22:12:57 dhcp,info dhcp1 assigned 10.63.194.88 to 10:D3:8A:17:AB:26
feb/02 22:12:58 hotspot,debug Hotspot: new host detected 10:D3:8A:17:AB:26/10.63.194.88 by TCP :39443 -> 10.63.192.1:7
feb/02 22:12:58 hotspot,debug Hotspot: dhcp host 10:D3:8A:17:AB:26/10.63.194.88 added, ip 10.63.194.88
feb/02 22:13:03 script,error Google Down
feb/02 22:13:04 dhcp,info dhcp1 deassigned 10.63.194.85 from 0C:B3:19:E9:AE:30
feb/02 22:13:04 hotspot,debug Hotspot: dhcp host 10.63.194.85 changed type to dynamic (remove after 5s)
feb/02 22:13:04 dhcp,info dhcp1 assigned 10.63.194.85 to 0C:B3:19:E9:AE:30
feb/02 22:13:04 hotspot,debug Hotspot: dynamic host 10.63.194.85 changed type to dhcp (got back lease)
feb/02 22:13:13 system,info,account user ersitizastes logged out from 10.63.192.255 via telnet
feb/02 22:13:29 system,info,account user ersitizastes logged in from 10.63.192.255 via telnet
feb/02 22:13:44 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 22:13:44 hotspot,info,debug T-0C:B3:19:E9:AE:30 (10.63.194.85): trying to log in by trial
feb/02 22:13:44 hotspot,debug T-0C:B3:19:E9:AE:30 (10.63.194.85): using profile <00>
feb/02 22:13:44 hotspot,debug T-0C:B3:19:E9:AE:30 (10.63.194.85): adding ip->user binding
feb/02 22:13:44 hotspot,debug T-0C:B3:19:E9:AE:30 (10.63.194.85): adding address-list rule <00>
feb/02 22:13:44 hotspot,debug T-0C:B3:19:E9:AE:30 (10.63.194.85): adding queue <256k/256k 0/0 0/0 0/0 8 64k/64k>
feb/02 22:13:44 hotspot,account,info,debug T-0C:B3:19:E9:AE:30 (10.63.194.85): logged in
feb/02 22:13:45 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :60247 -> 183.61.112.123:80
feb/02 22:13:45 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 22:13:59 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :40733 -> 8.8.8.8:53
feb/02 22:13:59 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
feb/02 22:14:05 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 22:14:06 hotspot,debug Hotspot: dynamic host 10.63.194.86 removed: login timeout
feb/02 22:14:09 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :39797 -> 10.63.192.1:53
feb/02 22:14:09 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.18 added, ip 10.63.193.150
feb/02 22:14:09 system,info,account user ersitizastes logged out from 10.63.192.255 via telnet
feb/02 22:14:12 dhcp,info dhcp1 assigned 10.63.194.33 to EC:88:92:40:CC:8B
feb/02 22:14:13 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :46655 -> 10.63.192.1:53
feb/02 22:14:13 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.194.89
feb/02 22:14:17 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by UDP :12532 -> 10.63.192.1:53
feb/02 22:14:17 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.33 added, ip 10.63.194.90
feb/02 22:14:17 hotspot,debug Hotspot: dynamic host 10.63.194.29 removed: login timeout
feb/02 22:14:25 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 22:14:25 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by TCP :51674 -> 173.194.118.73:443
feb/02 22:14:25 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 22:14:25 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 22:14:27 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.58 by UDP :49131 -> 10.63.192.1:53
feb/02 22:14:27 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.58 added, ip 10.63.194.29
feb/02 22:14:27 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by UDP :19262 -> 10.63.192.1:53
feb/02 22:14:27 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.59 added, ip 10.63.194.91
feb/02 22:14:36 hotspot,debug Hotspot: new host detected F4:F1:E1:F4:62:F6/10.63.193.3 by TCP :40513 -> 173.194.118.98:443
feb/02 22:14:36 hotspot,debug Hotspot: dhcp host F4:F1:E1:F4:62:F6/10.63.193.3 added, ip 10.63.193.3
feb/02 22:14:40 dhcp,info dhcp1 deassigned 10.63.194.58 from C4:9A:02:5D:A1:DC
feb/02 22:14:44 dhcp,info dhcp1 assigned 10.63.194.58 to C4:9A:02:5D:A1:DC
feb/02 22:14:47 hotspot,debug Hotspot: dhcp host 10.63.194.87 removed: login timeout
feb/02 22:14:47 hotspot,debug Hotspot: new host detected 84:11:9E:C3:1F:FE/10.63.194.87 by TCP :46202 -> 173.194.118.71:443
feb/02 22:14:47 hotspot,debug Hotspot: dhcp host 84:11:9E:C3:1F:FE/10.63.194.87 added, ip 10.63.194.87
feb/02 22:14:58 hotspot,debug Hotspot: dhcp host 10.63.194.88 removed: login timeout
feb/02 22:15:06 hotspot,debug Hotspot: new host detected 10:D3:8A:17:AB:26/10.63.194.88 by UDP :60284 -> 10.63.192.1:53
feb/02 22:15:06 hotspot,debug Hotspot: dhcp host 10:D3:8A:17:AB:26/10.63.194.88 added, ip 10.63.194.88
feb/02 22:15:42 system,info,account user ersitizastes logged in from 10.63.192.255 via telnet
feb/02 22:15:45 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: login timeout
feb/02 22:15:47 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by TCP :53291 -> 69.28.57.171:8888
feb/02 22:15:47 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
feb/02 22:15:47 dhcp,info dhcp1 deassigned 10.63.194.22 from AC:9E:17:0F:63:0D
feb/02 22:15:59 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: login timeout
feb/02 22:16:01 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :54913 -> 8.8.4.4:53
feb/02 22:16:01 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
feb/02 22:16:09 hotspot,debug Hotspot: dynamic host 10.63.193.150 removed: login timeout
feb/02 22:16:11 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.18 by UDP :1741 -> 10.63.192.1:53
feb/02 22:16:11 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.18 added, ip 10.63.193.150
feb/02 22:16:13 hotspot,debug Hotspot: dynamic host 10.63.194.89 removed: login timeout
feb/02 22:16:17 hotspot,debug Hotspot: dynamic host 10.63.194.90 removed: login timeout
feb/02 22:16:17 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.194.33 by TCP :45830 -> 108.168.176.245:80
feb/02 22:16:17 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.194.33 added, ip 10.63.194.92
feb/02 22:16:19 dhcp,info dhcp1 deassigned 10.63.194.84 from 00:F4:6F:F6:0A:DF
feb/02 22:16:19 hotspot,debug Hotspot: dhcp host 10.63.194.84 changed type to dynamic (remove after 5s)
feb/02 22:16:19 dhcp,info dhcp1 assigned 10.63.194.84 to 00:F4:6F:F6:0A:DF
feb/02 22:16:19 hotspot,debug Hotspot: dynamic host 10.63.194.84 changed type to dhcp (got back lease)
feb/02 22:16:24 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.28 by UDP :33560 -> 10.63.192.1:53
feb/02 22:16:24 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.28 added, ip 10.63.194.37
feb/02 22:16:25 hotspot,debug Hotspot: dhcp host 10.63.194.28 removed: login timeout
feb/02 22:16:27 hotspot,debug Hotspot: new host detected 74:BA:DB:04:26:13/10.63.194.28 by TCP :52356 -> 216.58.222.14:443
feb/02 22:16:27 hotspot,debug Hotspot: dhcp host 74:BA:DB:04:26:13/10.63.194.28 added, ip 10.63.194.28
feb/02 22:16:27 hotspot,debug Hotspot: dynamic host 10.63.194.29 removed: login timeout
feb/02 22:16:27 hotspot,debug Hotspot: dynamic host 10.63.194.91 removed: login timeout
feb/02 22:16:36 hotspot,debug Hotspot: dhcp host 10.63.193.3 removed: login timeout
feb/02 22:16:41 hotspot,debug Hotspot: new host detected 4C:5E:0C:CA:05:46/10.63.193.59 by TCP :48482 -> 158.85.58.110:80
feb/02 22:16:41 hotspot,debug Hotspot: dynamic host 4C:5E:0C:CA:05:46/10.63.193.59 added, ip 10.63.194.29
feb/02 22:16:47 hotspot,debug Hotspot: dhcp host 10.63.194.87 removed: login timeout
feb/02 22:16:56 system,info,account user ersitizastes logged out from 10.63.192.255 via telnet
feb/02 22:16:59 dhcp,info dhcp1 deassigned 10.63.194.52 from C4:9A:02:61:DA:A3
feb/02 22:16:59 dhcp,info dhcp1 assigned 10.63.194.52 to C4:9A:02:61:DA:A3
feb/02 22:17:00 hotspot,debug Hotspot: new host detected C4:9A:02:61:DA:A3/10.63.194.52 by UDP :24757 -> 10.63.192.1:53
feb/02 22:17:00 hotspot,debug Hotspot: dhcp host C4:9A:02:61:DA:A3/10.63.194.52 added, ip 10.63.194.52
feb/02 22:17:00 system,info,account user ersitizastes logged in from 10.63.192.255 via telnet
feb/02 22:17:00 script,warning Google Up
feb/02 22:17:06 hotspot,debug Hotspot: dhcp host 10.63.194.88 removed: login timeout
feb/02 22:17:16 dhcp,info dhcp1 deassigned 10.63.194.84 from 00:F4:6F:F6:0A:DF
feb/02 22:17:16 hotspot,debug Hotspot: dhcp host 10.63.194.84 changed type to dynamic (remove after 5s)
feb/02 22:17:16 dhcp,info dhcp1 assigned 10.63.194.84 to 00:F4:6F:F6:0A:DF
feb/02 22:17:16 hotspot,debug Hotspot: dynamic host 10.63.194.84 changed type to dhcp (got back lease)
Can I use station wds instead station pseudobridge, or can I use station-bridge?
PeterDoBrasil, as I wrote in the last post try to use station-bridge mode instead of station-pseudobridge if your AP is RouterOS based and that should not cause problems like you have with the pseudobridge option.
Version 6.35rc3 will be released today.
Changes since previous version:
*) dude - <changes discussed here: http://forum.mikrotik.com/t/the-dude-work-continues-v6-35rc-test-builds/94981/1 >
*) interface - show stats properly in bits not bytes;
*) traffic-monitor - show stats properly in bits not bytes;
*) smips - properly detect smips boards for winbox & webfig;
*) ccr1072 - fix traffic halting when sfp+ 1-4 or 5-8 where all disabled.
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
How can I upgrade the hAP Lite?
There isn’t enough disk space available.
Resolved
station-bridge causes the same problem, I've testet station-wds, now Hotspot runs Propertly, wifi Link is O.K, all my devices are Routerboard, Iám only use BaseBox 2,4 ghz!
[ersitizastes@5g.net 0] > /ip hotspot host print
Flags: S - static, H - DHCP, D - dynamic, A - authorized, P - bypassed
MAC-ADDRESS ADDRESS TO-ADDRESS SERVER IDLE-TIMEOUT
0 SP ;;; 5g.net 1
4C:5E:0C:C4:41:BE 10.63.192.2 10.63.192.2 Hotspot
1 SP ;;; 5g.net 2
4C:5E:0C:CA:05:46 10.63.192.3 10.63.192.3 Hotspot
2 SP ;;; HP Ether
08:2E:5F:75:6C:56 10.63.192.255 10.63.192.255 Hotspot
3 SP ;;; 5g.net 3
4C:5E:0C:C4:53:F8 10.63.192.4 10.63.192.4 Hotspot
4 SP ;;; HP Wifi
5C:C9:D3:0D:D1:AD 10.63.192.254 10.63.192.254 Hotspot
5 SP ;;; 5g.net 4
4C:5E:0C:C4:4D:F9 10.63.192.5 10.63.192.5 Hotspot
6 H 14:32:D1:10:FE:CE 10.63.193.36 10.63.193.36 Hotspot
7 H F4:F1:E1:1E:3A:2C 10.63.194.35 10.63.194.35 Hotspot
8 H 9C:E6:E7:07:04:65 10.63.193.45 10.63.193.45 Hotspot
9 H 38:2D:D1:A5:04:39 10.63.193.23 10.63.193.23 Hotspot
10 H 48:59:29:E3:59:62 10.63.194.120 10.63.194.120 Hotspot
11 H 34:BE:00:95:74:65 10.63.193.47 10.63.193.47 Hotspot
12 H 50:55:27:A0:E9:AF 10.63.193.133 10.63.193.133 Hotspot
13 H 60:D7:AE:C8:92:CC 10.63.193.51 10.63.193.51 Hotspot
/log print
feb/ 3/2016 10:43: 7 by RouterOS 6.33
software id = KPNX-1FGN
08:33:31 hotspot,debug Hotspot: dynamic host 10.63.194.40 removed: keepalive timeout
08:34:53 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
08:34:53 hotspot,debug Hotspot: dhcp host 10.63.193.51 changed type to dynamic (remove after 5s)
08:34:55 hotspot,debug Hotspot: dynamic host 10.63.193.51 removed: keepalive timeout
08:35:01 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by UDP :4686 -> 10.63.192.1:53
08:35:01 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
08:35:13 dhcp,info dhcp1 assigned 10.63.193.8 to 9C:D9:17:8A:C4:1A
08:35:14 hotspot,debug Hotspot: new host detected 9C:D9:17:8A:C4:1A/10.63.193.8 by UDP :55831 -> 10.63.192.1:53
08:35:14 hotspot,debug Hotspot: dhcp host 9C:D9:17:8A:C4:1A/10.63.193.8 added, ip 10.63.193.8
08:35:43 dhcp,info dhcp1 assigned 10.63.194.136 to B4:30:52:B0:9E:72
08:35:48 hotspot,debug Hotspot: new host detected B4:30:52:B0:9E:72/10.63.194.136 by TCP :38741 -> 192.12.31.96:443
08:35:48 hotspot,debug Hotspot: dhcp host B4:30:52:B0:9E:72/10.63.194.136 added, ip 10.63.194.136
08:36:31 dhcp,info dhcp1 assigned 10.63.192.254 to 5C:C9:D3:0D:D1:AD
08:36:31 dhcp,error dhcp1: failed to add arp entry for IP 10.63.192.254: already have such arp (6)
08:36:34 hotspot,debug Hotspot: bypassed host 10.63.192.254 moved to bridge port from
08:36:58 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
08:37:17 hotspot,debug Hotspot: new host detected 60:D7:AE:C8:92:CC/10.63.193.51 by UDP :35646 -> 10.63.192.1:53
08:37:17 hotspot,debug Hotspot: dhcp host 60:D7:AE:C8:92:CC/10.63.193.51 added, ip 10.63.193.51
08:37:58 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :57227 -> 10.63.192.1:53
08:37:58 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
08:38:06 dhcp,info dhcp1 deassigned 10.63.193.133 from 50:55:27:A0:E9:AF
08:40:10 hotspot,debug Hotspot: dhcp host 10.63.193.51 removed: keepalive timeout
08:40:47 hotspot,debug Hotspot: dhcp host 10.63.193.8 removed: keepalive timeout
08:42:20 hotspot,debug Hotspot: bypassed host 10.63.192.255 moved to bridge port from
08:42:26 hotspot,debug Hotspot: bypassed host 10.63.192.3 moved to bridge port from <>
08:42:32 hotspot,debug Hotspot: new host detected 8C:3A:E3:07:CA:30/10.63.194.155 by UDP :48503 -> 10.63.192.1:53
08:42:32 hotspot,debug Hotspot: dhcp host 8C:3A:E3:07:CA:30/10.63.194.155 added, ip 10.63.194.155
08:43:00 script,warning 5g.net 2 Up
08:43:44 hotspot,debug Hotspot: dhcp host 10.63.193.6 removed: keepalive timeout
08:44:27 hotspot,debug Hotspot: dhcp host 10.63.194.143 removed: keepalive timeout
08:44:36 hotspot,debug Hotspot: dhcp host 10.63.194.155 removed: keepalive timeout
08:45:54 hotspot,debug Hotspot: new host detected 58:A2:B5:DA:FD:96/10.63.194.39 by UDP :44674 -> 10.63.192.1:53
08:45:54 hotspot,debug Hotspot: dhcp host 58:A2:B5:DA:FD:96/10.63.194.39 added, ip 10.63.194.39
08:46:01 dhcp,info dhcp1 deassigned 10.63.194.39 from 58:A2:B5:DA:FD:96
08:46:01 hotspot,debug Hotspot: dhcp host 10.63.194.39 changed type to dynamic (remove after 5s)
08:46:01 dhcp,info dhcp1 assigned 10.63.194.39 to 58:A2:B5:DA:FD:96
08:46:01 hotspot,debug Hotspot: dynamic host 10.63.194.39 changed type to dhcp (got back lease)
08:46:31 dhcp,info dhcp1 deassigned 10.63.192.254 from 5C:C9:D3:0D:D1:AD
08:47:31 dhcp,info dhcp1 assigned 10.63.194.33 to EC:88:92:40:CC:8B
08:47:35 hotspot,debug Hotspot: new host detected EC:88:92:40:CC:8B/10.63.194.33 by UDP :24236 -> 10.63.192.1:53
08:47:35 hotspot,debug Hotspot: dhcp host EC:88:92:40:CC:8B/10.63.194.33 added, ip 10.63.194.33
08:47:42 hotspot,info,debug T-EC:88:92:40:CC:8B (10.63.194.33): trying to log in by trial
08:47:42 hotspot,debug T-EC:88:92:40:CC:8B (10.63.194.33): using profile <00>
08:47:42 hotspot,debug T-EC:88:92:40:CC:8B (10.63.194.33): adding ip->user binding
08:47:42 hotspot,debug T-EC:88:92:40:CC:8B (10.63.194.33): adding address-list rule <00>
08:47:42 hotspot,debug T-EC:88:92:40:CC:8B (10.63.194.33): adding queue <180k/180k 0/0 0/0 0/0 8 64k/64k>
08:47:42 hotspot,account,info,debug T-EC:88:92:40:CC:8B (10.63.194.33): logged in
08:48:40 dhcp,info dhcp1 assigned 10.63.192.254 to 5C:C9:D3:0D:D1:AD
08:48:40 dhcp,error dhcp1: failed to add arp entry for IP 10.63.192.254: already have such arp (6)
08:49:24 dhcp,info dhcp1 deassigned 10.63.194.150 from C4:9A:02:39:E6:12
08:50:24 dhcp,info dhcp1 deassigned 10.63.194.136 from B4:30:52:B0:9E:72
08:50:24 hotspot,debug Hotspot: dhcp host 10.63.194.136 changed type to dynamic (remove after 5s)
08:50:24 dhcp,info dhcp1 assigned 10.63.194.136 to B4:30:52:B0:9E:72
08:50:24 hotspot,debug Hotspot: dynamic host 10.63.194.136 changed type to dhcp (got back lease)
08:50:30 dhcp,info dhcp1 assigned 10.63.193.59 to F8:A9:D0:5A:F4:85
08:50:47 hotspot,debug Hotspot: new host detected 80:65:6D:56:6E:A5/10.63.194.143 by UDP :44139 -> 10.63.192.1:53
08:50:47 hotspot,debug Hotspot: dhcp host 80:65:6D:56:6E:A5/10.63.194.143 added, ip 10.63.194.143
08:51:18 hotspot,debug Hotspot: new host detected F8:A9:D0:5A:F4:85/10.63.193.59 by UDP :42949 -> 10.63.192.1:53
08:51:18 hotspot,debug Hotspot: dhcp host F8:A9:D0:5A:F4:85/10.63.193.59 added, ip 10.63.193.59
08:52:31 dhcp,info dhcp1 deassigned 10.63.194.151 from C4:42:02:39:9E:90
08:53:19 hotspot,debug Hotspot: new host detected 34:FC:EF:D1:29:25/10.63.193.6 by UDP :55296 -> 10.63.192.1:53
08:53:19 hotspot,debug Hotspot: dhcp host 34:FC:EF:D1:29:25/10.63.193.6 added, ip 10.63.193.6
08:53:24 dhcp,info dhcp1 deassigned 10.63.193.6 from 34:FC:EF:D1:29:25
08:53:24 hotspot,debug Hotspot: dhcp host 10.63.193.6 changed type to dynamic (remove after 5s)
08:53:28 dhcp,info dhcp1 assigned 10.63.193.6 to 34:FC:EF:D1:29:25
08:53:28 hotspot,debug Hotspot: dynamic host 10.63.193.6 changed type to dhcp (got back lease)
08:54:28 hotspot,debug Hotspot: dhcp host 10.63.194.143 removed: keepalive timeout
08:54:45 hotspot,debug Hotspot: dhcp host 10.63.194.39 removed: keepalive timeout
08:55:54 dhcp,info dhcp1 assigned 10.63.194.120 to 48:59:29:E3:59:62
08:56:01 dhcp,info dhcp1 deassigned 10.63.194.144 from 34:FC:EF:CF:50:24
08:56:30 dhcp,info dhcp1 assigned 10.63.193.11 to D0:59:E4:36:95:99
08:56:31 hotspot,debug Hotspot: new host detected D0:59:E4:36:95:99/10.63.193.11 by UDP :20164 -> 10.63.192.1:53
08:56:31 hotspot,debug Hotspot: dhcp host D0:59:E4:36:95:99/10.63.193.11 added, ip 10.63.193.11
08:57:17 hotspot,debug Hotspot: new host detected 48:59:29:E3:59:62/10.63.194.120 by UDP :57118 -> 10.63.192.1:53
08:57:17 hotspot,debug Hotspot: dhcp host 48:59:29:E3:59:62/10.63.194.120 added, ip 10.63.194.120
08:57:56 hotspot,debug Hotspot: new host detected 8C:3A:E3:07:CA:30/10.63.194.155 by UDP :36938 -> 10.63.192.1:53
08:57:56 hotspot,debug Hotspot: dhcp host 8C:3A:E3:07:CA:30/10.63.194.155 added, ip 10.63.194.155
08:57:58 dhcp,info dhcp1 deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
08:57:58 dhcp,info dhcp1 assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
08:57:59 hotspot,debug Hotspot: new host detected 18:22:7E:2A:5A:5E/10.63.193.13 by TCP :49890 -> 192.12.31.106:5223
08:57:59 hotspot,debug Hotspot: dhcp host 18:22:7E:2A:5A:5E/10.63.193.13 added, ip 10.63.193.13
08:58:38 hotspot,debug Hotspot: dhcp host 10.63.193.11 removed: keepalive timeout
08:58:40 dhcp,info dhcp1 deassigned 10.63.192.254 from 5C:C9:D3:0D:D1:AD
08:59:35 dhcp,info dhcp1 deassigned 10.63.194.153 from 64:89:9A:2B:2D:55
09:00:24 hotspot,debug Hotspot: dhcp host 10.63.194.155 removed: keepalive timeout
09:00:40 dhcp,info dhcp1 deassigned 10.63.194.18 from 34:FC:EF:FF:AD:06
09:01:27 dhcp,info dhcp1 deassigned 10.63.194.152 from 34:FC:EF:C3:61:36
09:01:40 dhcp,info dhcp1 deassigned 10.63.194.26 from C4:9A:02:9E:19:A1
09:02:25 hotspot,debug Hotspot: dhcp host 10.63.194.136 removed: keepalive timeout
09:02:39 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
09:03:04 hotspot,debug Hotspot: dhcp host 10.63.193.13 removed: keepalive timeout
09:03:19 wireless,info wlan: data from unknown device 60:D7:AE:C8:92:CC, sent deauth
09:04:50 dhcp,info dhcp1 deassigned 10.63.194.155 from 8C:3A:E3:07:CA:30
09:05:09 hotspot,debug Hotspot: dhcp host 10.63.194.120 removed: keepalive timeout
09:05:55 dhcp,info dhcp1 deassigned 10.63.194.136 from B4:30:52:B0:9E:72
09:06:02 dhcp,info dhcp1 assigned 10.63.194.136 to B4:30:52:B0:9E:72
09:06:06 hotspot,debug Hotspot: new host detected B4:30:52:B0:9E:72/10.63.194.136 by UDP :7516 -> 10.63.192.1:53
09:06:06 hotspot,debug Hotspot: dhcp host B4:30:52:B0:9E:72/10.63.194.136 added, ip 10.63.194.136
09:06:10 dhcp,info dhcp1 assigned 10.63.193.14 to 20:62:74:E9:92:B0
09:06:10 hotspot,debug Hotspot: new host detected 20:62:74:E9:92:B0/10.63.193.14 by UDP :58460 -> 10.63.192.1:53
09:06:10 hotspot,debug Hotspot: dhcp host 20:62:74:E9:92:B0/10.63.193.14 added, ip 10.63.193.14
09:06:14 dhcp,info dhcp1 deassigned 10.63.193.14 from 20:62:74:E9:92:B0
09:06:14 hotspot,debug Hotspot: dhcp host 10.63.193.14 changed type to dynamic (remove after 5s)
09:06:14 dhcp,info dhcp1 assigned 10.63.193.14 to 20:62:74:E9:92:B0
09:06:14 hotspot,debug Hotspot: dynamic host 10.63.193.14 changed type to dhcp (got back lease)
09:06:24 hotspot,info,debug T-20:62:74:E9:92:B0 (10.63.193.14): trying to log in by trial
09:06:24 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): using profile <00>
09:06:24 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): adding ip->user binding
09:06:24 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): adding address-list rule <00>
09:06:24 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): adding queue <180k/180k 0/0 0/0 0/0 8 64k/64k>
09:06:24 hotspot,account,info,debug T-20:62:74:E9:92:B0 (10.63.193.14): logged in
09:06:53 dhcp,info dhcp1 assigned 10.63.194.138 to 44:91:DB:51:5E:EB
09:08:58 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: keepalive timeout
09:10:55 hotspot,info,debug T-20:62:74:E9:92:B0 (10.63.193.14): logged out: keepalive timeout
09:10:55 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): removing queue
09:10:55 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): removing address-list
09:10:55 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): removing ip->user binding
09:10:55 hotspot,debug Hotspot: dhcp host 10.63.193.14 removed: keepalive timeout
09:11:56 dhcp,info dhcp1 deassigned 10.63.194.127 from 14:A3:64:25:0E:91
09:12:34 dhcp,info dhcp1 assigned 10.63.194.135 to 3C:18:9F:33:05:31
09:12:37 hotspot,debug Hotspot: new host detected 3C:18:9F:33:05:31/10.63.194.135 by UDP :60308 -> 10.63.192.1:53
09:12:37 hotspot,debug Hotspot: dhcp host 3C:18:9F:33:05:31/10.63.194.135 added, ip 10.63.194.135
09:13:09 dhcp,info dhcp1 deassigned 10.63.193.4 from AC:D0:74:14:00:59
09:13:39 interface,info ether2 link up (speed 100M, full duplex)
09:13:39 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :25757 -> 10.63.192.1:53
09:13:39 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
09:13:42 wireless,info 94:51:03:D3:B6:B8@wlan: connected
09:13:46 dhcp,info dhcp1 assigned 10.63.192.253 to 94:51:03:D3:B6:B8
09:13:47 hotspot,debug Hotspot: new host detected 94:51:03:D3:B6:B8/10.63.192.253 by TCP :40512 -> 108.177.12.188:5228
09:13:47 hotspot,debug Hotspot: dhcp host 94:51:03:D3:B6:B8/10.63.192.253 added, ip 10.63.192.253
09:13:52 interface,info ether2 link down
09:13:52 wireless,info 5C:C9:D3:0D:D1:AD@wlan: connected
09:13:52 dhcp,info dhcp1 assigned 10.63.192.254 to 5C:C9:D3:0D:D1:AD
09:13:52 dhcp,error dhcp1: failed to add arp entry for IP 10.63.192.254: already have such arp (6)
09:13:52 hotspot,debug Hotspot: bypassed host 10.63.192.254 moved to bridge port from
09:13:54 interface,info ether2 link up (speed 1G, full duplex)
09:13:56 hotspot,debug Hotspot: bypassed host 10.63.192.255 moved to bridge port from
09:13:58 dhcp,info dhcp1 deassigned 10.63.194.120 from 48:59:29:E3:59:62
09:13:58 dhcp,info dhcp1 assigned 10.63.194.120 to 48:59:29:E3:59:62
09:14:01 hotspot,debug Hotspot: new host detected 48:59:29:E3:59:62/10.63.194.120 by UDP :18584 -> 10.63.192.1:53
09:14:01 hotspot,debug Hotspot: dhcp host 48:59:29:E3:59:62/10.63.194.120 added, ip 10.63.194.120
09:14:11 wireless,info 5C:C9:D3:0D:D1:AD@wlan: disconnected, received disassoc: sending station leaving (8)
09:14:39 dhcp,info dhcp1 assigned 10.63.192.255 to 08:2E:5F:75:6C:56
09:14:39 dhcp,error dhcp1: failed to add arp entry for IP 10.63.192.255: already have such arp (6)
09:14:49 hotspot,debug Hotspot: dhcp host 10.63.193.6 removed: keepalive timeout
09:15:44 hotspot,debug Hotspot: new host detected 6C:2F:2C:1C:E4:DC/10.63.193.44 by UDP :44545 -> 10.63.192.1:53
09:15:44 hotspot,debug Hotspot: dhcp host 6C:2F:2C:1C:E4:DC/10.63.193.44 added, ip 10.63.193.44
09:16:41 dhcp,info dhcp1 deassigned 10.63.194.140 from 9C:65:B0:FA:3F:26
09:17:13 hotspot,debug Hotspot: dhcp host 10.63.194.136 removed: keepalive timeout
09:17:25 hotspot,info,debug T-EC:88:92:40:CC:8B (10.63.194.33): logged out: keepalive timeout
09:17:25 hotspot,debug T-EC:88:92:40:CC:8B (10.63.194.33): removing queue
09:17:25 hotspot,debug T-EC:88:92:40:CC:8B (10.63.194.33): removing address-list
09:17:25 hotspot,debug T-EC:88:92:40:CC:8B (10.63.194.33): removing ip->user binding
09:17:25 hotspot,debug Hotspot: dhcp host 10.63.194.33 removed: keepalive timeout
09:18:06 hotspot,debug Hotspot: dhcp host 10.63.193.59 removed: keepalive timeout
09:18:39 hotspot,debug Hotspot: new host detected F8:A9:D0:5A:F4:85/10.63.193.59 by UDP :47293 -> 10.63.192.1:53
09:18:39 hotspot,debug Hotspot: dhcp host F8:A9:D0:5A:F4:85/10.63.193.59 added, ip 10.63.193.59
09:18:40 dhcp,info dhcp1 deassigned 10.63.193.59 from F8:A9:D0:5A:F4:85
09:18:40 hotspot,debug Hotspot: dhcp host 10.63.193.59 changed type to dynamic (remove after 5s)
09:18:41 hotspot,debug Hotspot: dhcp host 10.63.194.135 removed: keepalive timeout
09:18:44 hotspot,debug Hotspot: dhcp host 10.63.193.44 removed: keepalive timeout
09:18:45 hotspot,debug Hotspot: dynamic host 10.63.193.59 removed: lost dhcp lease
09:18:46 hotspot,debug Hotspot: new host detected F8:A9:D0:5A:F4:85/10.63.193.59 by UDP :63009 -> 10.63.192.1:53
09:18:46 hotspot,debug Hotspot: dynamic host F8:A9:D0:5A:F4:85/10.63.193.59 added, ip 10.63.193.17
09:19:43 dhcp,info dhcp1 assigned 10.63.193.59 to F8:A9:D0:5A:F4:85
09:19:43 hotspot,debug Hotspot: dynamic host 10.63.193.17 removed: dhcp entry overrides dynamic one
09:19:57 hotspot,debug Hotspot: new host detected F8:A9:D0:5A:F4:85/10.63.193.59 by UDP :60884 -> 10.63.192.1:53
09:19:57 hotspot,debug Hotspot: dhcp host F8:A9:D0:5A:F4:85/10.63.193.59 added, ip 10.63.193.59
09:21:48 dhcp,info dhcp1 assigned 10.63.193.22 to 30:19:66:27:D9:9F
09:21:49 hotspot,debug Hotspot: new host detected 30:19:66:27:D9:9F/10.63.193.22 by UDP :35114 -> 10.63.192.1:53
09:21:49 hotspot,debug Hotspot: dhcp host 30:19:66:27:D9:9F/10.63.193.22 added, ip 10.63.193.22
09:22:13 hotspot,debug Hotspot: dhcp host 10.63.193.59 removed: keepalive timeout
09:23:51 hotspot,debug Hotspot: dhcp host 10.63.193.22 removed: keepalive timeout
09:23:52 dhcp,info dhcp1 deassigned 10.63.192.254 from 5C:C9:D3:0D:D1:AD
09:24:21 dhcp,info dhcp1 assigned 10.63.194.146 to C4:42:02:21:02:DC
09:24:48 hotspot,debug Hotspot: new host detected C4:42:02:21:02:DC/10.63.194.146 by TCP :32877 -> 52.16.205.72:5223
09:24:48 hotspot,debug Hotspot: dhcp host C4:42:02:21:02:DC/10.63.194.146 added, ip 10.63.194.146
09:25:41 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: keepalive timeout
09:26:03 dhcp,info dhcp1 assigned 10.63.193.24 to E4:90:7E:50:12:B3
09:26:04 hotspot,debug Hotspot: new host detected E4:90:7E:50:12:B3/10.63.193.24 by UDP :43829 -> 10.63.192.1:53
09:26:04 hotspot,debug Hotspot: dhcp host E4:90:7E:50:12:B3/10.63.193.24 added, ip 10.63.193.24
09:26:52 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: keepalive timeout
09:26:55 hotspot,debug Hotspot: dhcp host 10.63.194.146 removed: keepalive timeout
09:27:20 dhcp,info dhcp1 deassigned 10.63.193.14 from 20:62:74:E9:92:B0
09:27:20 dhcp,info dhcp1 assigned 10.63.193.14 to 20:62:74:E9:92:B0
09:27:20 hotspot,debug Hotspot: new host detected 20:62:74:E9:92:B0/10.63.193.14 by UDP :63292 -> 10.63.192.1:53
09:27:20 hotspot,info,debug T-20:62:74:E9:92:B0 (10.63.193.14): trying to log in by mac-cookie
09:27:20 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): using profile <00>
09:27:20 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): adding ip->user binding
09:27:20 hotspot,debug Hotspot: dhcp host 20:62:74:E9:92:B0/10.63.193.14 added, ip 10.63.193.14
09:27:20 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): adding address-list rule <00>
09:27:20 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): adding queue <180k/180k 0/0 0/0 0/0 8 64k/64k>
09:27:20 hotspot,account,info,debug T-20:62:74:E9:92:B0 (10.63.193.14): logged in
09:27:55 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :54374 -> 10.63.192.1:53
09:27:55 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
09:27:57 dhcp,info dhcp1 deassigned 10.63.193.24 from E4:90:7E:50:12:B3
09:27:57 hotspot,debug Hotspot: dhcp host 10.63.193.24 changed type to dynamic (remove after 5s)
09:27:59 dhcp,info dhcp1 assigned 10.63.193.24 to E4:90:7E:50:12:B3
09:27:59 hotspot,debug Hotspot: dynamic host 10.63.193.24 changed type to dhcp (got back lease)
09:28:22 dhcp,info dhcp1 deassigned 10.63.194.39 from 58:A2:B5:DA:FD:96
09:28:22 dhcp,info dhcp1 assigned 10.63.194.39 to 58:A2:B5:DA:FD:96
09:29:04 dhcp,info dhcp1 deassigned 10.63.193.24 from E4:90:7E:50:12:B3
09:29:04 hotspot,debug Hotspot: dhcp host 10.63.193.24 changed type to dynamic (remove after 5s)
09:29:05 dhcp,info dhcp1 assigned 10.63.193.24 to E4:90:7E:50:12:B3
09:29:05 hotspot,debug Hotspot: dynamic host 10.63.193.24 changed type to dhcp (got back lease)
09:29:25 dhcp,info dhcp1 deassigned 10.63.193.14 from 20:62:74:E9:92:B0
09:29:25 hotspot,debug Hotspot: dhcp host 10.63.193.14 changed type to dynamic (remove after 5s)
09:29:30 hotspot,info,debug T-20:62:74:E9:92:B0 (10.63.193.14): logged out: lost dhcp lease
09:29:30 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): removing queue
09:29:30 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): removing address-list
09:29:30 hotspot,debug T-20:62:74:E9:92:B0 (10.63.193.14): removing ip->user binding
09:29:30 hotspot,debug Hotspot: dynamic host 10.63.193.14 removed: lost dhcp lease
09:30:03 script,error 5g.net 2 Down
09:30:41 wireless,info 94:51:03:D3:B6:B8@wlan: disconnected, received disassoc: sending station leaving (8)
09:30:45 dhcp,info dhcp1 deassigned 10.63.194.120 from 48:59:29:E3:59:62
09:30:45 hotspot,debug Hotspot: dhcp host 10.63.194.120 changed type to dynamic (remove after 5s)
09:30:50 hotspot,debug Hotspot: dynamic host 10.63.194.120 removed: lost dhcp lease
09:31:00 script,warning 5g.net 2 Up
09:31:15 hotspot,debug Hotspot: new host detected 18:22:7E:2A:5A:5E/10.63.193.13 by UDP :37296 -> 10.63.192.1:53
09:31:15 hotspot,debug Hotspot: dhcp host 18:22:7E:2A:5A:5E/10.63.193.13 added, ip 10.63.193.13
09:31:21 hotspot,debug Hotspot: dynamic host 10.63.193.30 removed: keepalive timeout
09:31:28 hotspot,debug Hotspot: dhcp host 10.63.193.24 removed: keepalive timeout
09:31:47 hotspot,debug Hotspot: dhcp host 10.63.192.253 removed: keepalive timeout
09:31:50 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
09:31:52 hotspot,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): trying to log in by trial
09:31:52 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): using profile <00>
09:31:52 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding ip->user binding
09:31:52 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding address-list rule <00>
09:31:52 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding queue <180k/180k 0/0 0/0 0/0 8 64k/64k>
09:31:52 hotspot,account,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): logged in
09:32:25 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: keepalive timeout
09:34:59 system,info arp entry changed by ersitizastes
09:35:10 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
09:35:12 interface,info ether2 link down
09:35:13 dhcp,info dhcp1 deassigned 10.63.193.8 from 9C:D9:17:8A:C4:1A
09:35:17 interface,info ether2 link up (speed 1G, full duplex)
09:35:55 system,info,account user ersitizastes logged in from 08:2E:5F:75:6C:56 via winbox
09:36:26 system,info arp entry removed by ersitizastes
09:36:32 interface,info ether2 link down
09:36:33 system,info,account user ersitizastes logged out from 08:2E:5F:75:6C:56 via winbox
09:36:37 interface,info ether2 link up (speed 1G, full duplex)
09:36:51 interface,info ether2 link down
09:36:54 interface,info ether2 link up (speed 1G, full duplex)
09:37:28 system,info,account user ersitizastes logged in from 08:2E:5F:75:6C:56 via winbox
09:38:30 dhcp,info dhcp1 deassigned 10.63.192.255 from 08:2E:5F:75:6C:56
09:38:30 system,info dhcp lease changed by ersitizastes
09:38:32 system,info dhcp lease changed by ersitizastes
09:38:37 interface,info ether2 link down
09:38:38 system,info,account user ersitizastes logged out from 08:2E:5F:75:6C:56 via winbox
09:38:42 interface,info ether2 link up (speed 1G, full duplex)
09:38:47 dhcp,info dhcp1 deassigned 10.63.192.253 from 94:51:03:D3:B6:B8
09:38:49 dhcp,info dhcp1 assigned 10.63.192.255 to 08:2E:5F:75:6C:56
09:39:04 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
09:39:22 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
09:41:01 dhcp,info dhcp1 deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
09:41:01 hotspot,debug Hotspot: dhcp host 10.63.193.13 changed type to dynamic (remove after 5s)
09:41:01 dhcp,info dhcp1 assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
09:41:01 hotspot,debug Hotspot: dynamic host 10.63.193.13 changed type to dhcp (got back lease)
09:44:05 dhcp,info dhcp1 assigned 10.63.193.27 to 48:59:29:FA:52:94
09:44:09 hotspot,debug Hotspot: new host detected 48:59:29:FA:52:94/10.63.193.27 by UDP :2270 -> 10.63.192.1:53
09:44:09 hotspot,debug Hotspot: dhcp host 48:59:29:FA:52:94/10.63.193.27 added, ip 10.63.193.27
09:45:38 dhcp,info dhcp1 deassigned 10.63.194.135 from 3C:18:9F:33:05:31
09:45:38 dhcp,info dhcp1 assigned 10.63.194.135 to 3C:18:9F:33:05:31
09:45:41 hotspot,debug Hotspot: new host detected 3C:18:9F:33:05:31/10.63.194.135 by UDP :50695 -> 10.63.192.1:53
09:45:41 hotspot,debug Hotspot: dhcp host 3C:18:9F:33:05:31/10.63.194.135 added, ip 10.63.194.135
09:46:44 hotspot,debug Hotspot: dhcp host 10.63.193.27 removed: keepalive timeout
09:47:02 hotspot,debug Hotspot: new host detected 30:19:66:27:D9:9F/10.63.193.22 by TCP :48594 -> 31.13.73.3:443
09:47:02 hotspot,debug Hotspot: dhcp host 30:19:66:27:D9:9F/10.63.193.22 added, ip 10.63.193.22
09:47:31 dhcp,info dhcp1 deassigned 10.63.194.33 from EC:88:92:40:CC:8B
09:49:12 dhcp,info dhcp1 deassigned 10.63.193.22 from 30:19:66:27:D9:9F
09:49:12 hotspot,debug Hotspot: dhcp host 10.63.193.22 changed type to dynamic (remove after 5s)
09:49:17 hotspot,debug Hotspot: dynamic host 10.63.193.22 removed: lost dhcp lease
09:49:29 dhcp,info dhcp1 assigned 10.63.193.32 to 78:F8:82:E2:F8:1B
09:49:30 hotspot,debug Hotspot: new host detected 78:F8:82:E2:F8:1B/10.63.193.32 by UDP :36672 -> 10.63.192.1:53
09:49:30 hotspot,debug Hotspot: dhcp host 78:F8:82:E2:F8:1B/10.63.193.32 added, ip 10.63.193.32
09:49:43 dhcp,info dhcp1 assigned 10.63.193.22 to 30:19:66:27:D9:9F
09:49:44 hotspot,debug Hotspot: new host detected 30:19:66:27:D9:9F/10.63.193.22 by TCP :33174 -> 31.13.73.3:443
09:49:44 hotspot,debug Hotspot: dhcp host 30:19:66:27:D9:9F/10.63.193.22 added, ip 10.63.193.22
09:49:59 hotspot,debug Hotspot: dhcp host 10.63.194.135 removed: keepalive timeout
09:50:35 hotspot,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): logged out: keepalive timeout
09:50:35 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing queue
09:50:35 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing address-list
09:50:35 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing ip->user binding
09:50:35 hotspot,debug Hotspot: dhcp host 10.63.193.13 removed: keepalive timeout
09:50:37 dhcp,info dhcp1 assigned 10.63.193.33 to 00:0D:F0:99:D8:9F
09:50:37 hotspot,debug Hotspot: new host detected 00:0D:F0:99:D8:9F/10.63.193.33 by UDP :137 -> 10.63.192.1:137
09:50:37 hotspot,debug Hotspot: dhcp host 00:0D:F0:99:D8:9F/10.63.193.33 added, ip 10.63.193.33
09:50:46 dhcp,info dhcp1 deassigned 10.63.194.143 from 80:65:6D:56:6E:A5
09:50:55 hotspot,debug Hotspot: new host detected 58:A2:B5:DA:FD:96/10.63.194.39 by UDP :56000 -> 10.63.192.1:53
09:50:55 hotspot,debug Hotspot: dhcp host 58:A2:B5:DA:FD:96/10.63.194.39 added, ip 10.63.194.39
09:51:48 dhcp,info dhcp1 deassigned 10.63.194.135 from 3C:18:9F:33:05:31
09:51:48 dhcp,info dhcp1 assigned 10.63.194.135 to 3C:18:9F:33:05:31
09:51:51 hotspot,debug Hotspot: new host detected 3C:18:9F:33:05:31/10.63.194.135 by UDP :50349 -> 10.63.192.1:53
09:51:51 hotspot,debug Hotspot: dhcp host 3C:18:9F:33:05:31/10.63.194.135 added, ip 10.63.194.135
09:51:53 hotspot,debug Hotspot: dhcp host 10.63.193.32 removed: keepalive timeout
09:51:58 dhcp,info dhcp1 deassigned 10.63.194.39 from 58:A2:B5:DA:FD:96
09:51:58 hotspot,debug Hotspot: dhcp host 10.63.194.39 changed type to dynamic (remove after 5s)
09:51:58 dhcp,info dhcp1 assigned 10.63.194.39 to 58:A2:B5:DA:FD:96
09:51:58 hotspot,debug Hotspot: dynamic host 10.63.194.39 changed type to dhcp (got back lease)
09:53:14 hotspot,debug Hotspot: new host detected 18:22:7E:2A:5A:5E/10.63.193.13 by UDP :38200 -> 10.63.192.1:53
09:53:14 hotspot,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): trying to log in by mac-cookie
09:53:14 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): using profile <00>
09:53:14 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding ip->user binding
09:53:14 hotspot,debug Hotspot: dhcp host 18:22:7E:2A:5A:5E/10.63.193.13 added, ip 10.63.193.13
09:53:15 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding address-list rule <00>
09:53:15 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding queue <180k/180k 0/0 0/0 0/0 8 64k/64k>
09:53:15 hotspot,account,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): logged in
09:53:28 dhcp,info dhcp1 deassigned 10.63.193.6 from 34:FC:EF:D1:29:25
09:53:56 hotspot,debug Hotspot: dhcp host 10.63.193.33 removed: keepalive timeout
09:54:24 hotspot,debug Hotspot: dhcp host 10.63.193.22 removed: keepalive timeout
09:54:41 hotspot,debug Hotspot: dhcp host 10.63.194.135 removed: keepalive timeout
09:55:57 dhcp,info dhcp1 deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
09:55:57 hotspot,debug Hotspot: dhcp host 10.63.193.13 changed type to dynamic (remove after 5s)
09:55:57 dhcp,info dhcp1 assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
09:55:57 hotspot,debug Hotspot: dynamic host 10.63.193.13 changed type to dhcp (got back lease)
09:56:06 hotspot,debug Hotspot: dhcp host 10.63.194.39 removed: keepalive timeout
09:56:30 dhcp,info dhcp1 deassigned 10.63.193.11 from D0:59:E4:36:95:99
09:56:49 hotspot,debug Hotspot: new host detected 44:91:DB:51:5E:EB/10.63.194.138 by ICMP type<3> code<3> to 10.63.192.1
09:56:49 hotspot,debug Hotspot: dhcp host 44:91:DB:51:5E:EB/10.63.194.138 added, ip 10.63.194.138
09:57:05 dhcp,info dhcp1 assigned 10.63.194.143 to 80:65:6D:56:6E:A5
09:57:06 hotspot,debug Hotspot: new host detected 80:65:6D:56:6E:A5/10.63.194.143 by UDP :35558 -> 10.63.192.1:53
09:57:06 hotspot,debug Hotspot: dhcp host 80:65:6D:56:6E:A5/10.63.194.143 added, ip 10.63.194.143
09:57:21 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
09:57:24 hotspot,debug Hotspot: new host detected 60:D7:AE:C8:92:CC/10.63.193.51 by UDP :1963 -> 10.63.192.1:53
09:57:24 hotspot,debug Hotspot: dhcp host 60:D7:AE:C8:92:CC/10.63.193.51 added, ip 10.63.193.51
09:57:31 dhcp,info dhcp1 deassigned 10.63.193.13 from 18:22:7E:2A:5A:5E
09:57:31 hotspot,debug Hotspot: dhcp host 10.63.193.13 changed type to dynamic (remove after 5s)
09:57:36 hotspot,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): logged out: lost dhcp lease
09:57:36 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing queue
09:57:36 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing address-list
09:57:36 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing ip->user binding
09:57:36 hotspot,debug Hotspot: dynamic host 10.63.193.13 removed: lost dhcp lease
09:57:50 hotspot,debug Hotspot: new host detected 58:A2:B5:DA:FD:96/10.63.194.39 by ICMP type<3> code<3> to 10.63.192.1
09:57:50 hotspot,debug Hotspot: dhcp host 58:A2:B5:DA:FD:96/10.63.194.39 added, ip 10.63.194.39
09:59:35 hotspot,debug Hotspot: dhcp host 10.63.194.143 removed: keepalive timeout
10:00:40 hotspot,debug Hotspot: dhcp host 10.63.194.39 removed: keepalive timeout
10:02:46 dhcp,info dhcp1 assigned 10.63.193.13 to 18:22:7E:2A:5A:5E
10:03:00 dhcp,info dhcp1 assigned 10.63.193.34 to 64:6C:B2:66:CE:DE
10:03:01 hotspot,debug Hotspot: new host detected 64:6C:B2:66:CE:DE/10.63.193.34 by UDP :34396 -> 10.63.192.1:53
10:03:01 hotspot,debug Hotspot: dhcp host 64:6C:B2:66:CE:DE/10.63.193.34 added, ip 10.63.193.34
10:03:14 dhcp,info dhcp1 deassigned 10.63.193.34 from 64:6C:B2:66:CE:DE
10:03:14 hotspot,debug Hotspot: dhcp host 10.63.193.34 changed type to dynamic (remove after 5s)
10:03:14 dhcp,info dhcp1 assigned 10.63.193.34 to 64:6C:B2:66:CE:DE
10:03:14 hotspot,debug Hotspot: dynamic host 10.63.193.34 changed type to dhcp (got back lease)
10:03:37 hotspot,debug Hotspot: new host detected 50:55:27:A0:E9:AF/10.63.193.133 by TCP :53803 -> 58.67.196.175:7006
10:03:37 hotspot,debug Hotspot: dynamic host 50:55:27:A0:E9:AF/10.63.193.133 added, ip 10.63.193.35
10:03:42 dhcp,info dhcp1 assigned 10.63.193.133 to 50:55:27:A0:E9:AF
10:03:42 hotspot,debug Hotspot: dynamic host 10.63.193.35 removed: dhcp entry overrides dynamic one
10:03:43 hotspot,debug Hotspot: new host detected 50:55:27:A0:E9:AF/10.63.193.133 by ICMP type<3> code<3> to 10.63.192.1
10:03:43 hotspot,debug Hotspot: dhcp host 50:55:27:A0:E9:AF/10.63.193.133 added, ip 10.63.193.133
10:03:54 dhcp,info dhcp1 deassigned 10.63.193.23 from 38:2D:D1:A5:04:39
10:04:18 hotspot,debug Hotspot: new host detected 18:22:7E:2A:5A:5E/10.63.193.13 by UDP :48695 -> 10.63.192.1:53
10:04:18 hotspot,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): trying to log in by mac-cookie
10:04:18 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): using profile <00>
10:04:18 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding ip->user binding
10:04:18 hotspot,debug Hotspot: dhcp host 18:22:7E:2A:5A:5E/10.63.193.13 added, ip 10.63.193.13
10:04:18 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding address-list rule <00>
10:04:18 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding queue <180k/180k 0/0 0/0 0/0 8 64k/64k>
10:04:18 hotspot,account,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): logged in
10:04:33 hotspot,info,debug T-64:6C:B2:66:CE:DE (10.63.193.34): trying to log in by trial
10:04:33 hotspot,debug T-64:6C:B2:66:CE:DE (10.63.193.34): using profile <00>
10:04:33 hotspot,debug T-64:6C:B2:66:CE:DE (10.63.193.34): adding ip->user binding
10:04:33 hotspot,debug T-64:6C:B2:66:CE:DE (10.63.193.34): adding address-list rule <00>
10:04:33 hotspot,debug T-64:6C:B2:66:CE:DE (10.63.193.34): adding queue <180k/180k 0/0 0/0 0/0 8 64k/64k>
10:04:33 hotspot,account,info,debug T-64:6C:B2:66:CE:DE (10.63.193.34): logged in
10:05:54 hotspot,debug Hotspot: dhcp host 10.63.193.133 removed: keepalive timeout
10:05:56 dhcp,info dhcp1 deassigned 10.63.194.35 from F4:F1:E1:1E:3A:2C
10:05:56 dhcp,info dhcp1 assigned 10.63.194.35 to F4:F1:E1:1E:3A:2C
10:05:57 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :15502 -> 10.63.192.1:53
10:05:57 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
10:07:03 script,error 5g.net 2 Down
10:07:28 interface,info ether9 link down
10:07:45 hotspot,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): logged out: keepalive timeout
10:07:45 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing queue
10:07:45 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing address-list
10:07:45 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing ip->user binding
10:07:45 hotspot,debug Hotspot: dhcp host 10.63.193.13 removed: keepalive timeout
10:07:54 interface,info ether9 link up (speed 100M, full duplex)
10:08:01 script,error 5g.net 1 Down
10:08:10 hotspot,info,debug T-64:6C:B2:66:CE:DE (10.63.193.34): logged out: keepalive timeout
10:08:10 hotspot,debug T-64:6C:B2:66:CE:DE (10.63.193.34): removing queue
10:08:10 hotspot,debug T-64:6C:B2:66:CE:DE (10.63.193.34): removing address-list
10:08:10 hotspot,debug T-64:6C:B2:66:CE:DE (10.63.193.34): removing ip->user binding
10:08:10 hotspot,debug Hotspot: dhcp host 10.63.193.34 removed: keepalive timeout
10:08:32 dhcp,info dhcp1 deassigned 10.63.194.138 from 44:91:DB:51:5E:EB
10:08:32 hotspot,debug Hotspot: dhcp host 10.63.194.138 changed type to dynamic (remove after 5s)
10:08:37 hotspot,debug Hotspot: dynamic host 10.63.194.138 removed: lost dhcp lease
10:08:48 dhcp,info dhcp1 assigned 10.63.194.138 to 44:91:DB:51:5E:EB
10:09:00 script,warning 5g.net 1 Up
10:09:01 script,warning 5g.net 2 Up
10:09:21 hotspot,debug Hotspot: dhcp host 10.63.194.35 removed: keepalive timeout
10:09:23 hotspot,debug Hotspot: dhcp host 10.63.193.51 removed: keepalive timeout
10:09:59 dhcp,info dhcp1 assigned 10.63.193.36 to 14:32:D1:10:FE:CE
10:10:00 hotspot,debug Hotspot: new host detected 60:D7:AE:C8:92:CC/10.63.193.51 by UDP :39064 -> 10.63.192.1:53
10:10:00 hotspot,debug Hotspot: dhcp host 60:D7:AE:C8:92:CC/10.63.193.51 added, ip 10.63.193.51
10:10:00 hotspot,debug Hotspot: new host detected 14:32:D1:10:FE:CE/10.63.193.36 by UDP :62322 -> 10.63.192.1:53
10:10:00 hotspot,debug Hotspot: dhcp host 14:32:D1:10:FE:CE/10.63.193.36 added, ip 10.63.193.36
10:10:07 dhcp,info dhcp1 deassigned 10.63.193.24 from E4:90:7E:50:12:B3
10:11:21 dhcp,info dhcp1 assigned 10.63.193.15 to F8:A9:D0:5E:6A:9F
10:11:22 hotspot,debug Hotspot: new host detected F8:A9:D0:5E:6A:9F/10.63.193.15 by UDP :51915 -> 10.63.192.1:53
10:11:22 hotspot,debug Hotspot: dhcp host F8:A9:D0:5E:6A:9F/10.63.193.15 added, ip 10.63.193.15
10:12:05 dhcp,info dhcp1 deassigned 10.63.194.136 from B4:30:52:B0:9E:72
10:13:00 hotspot,debug Hotspot: new host detected 18:22:7E:2A:5A:5E/10.63.193.13 by UDP :7573 -> 10.63.192.1:53
10:13:00 hotspot,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): trying to log in by mac-cookie
10:13:00 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): using profile <00>
10:13:00 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding ip->user binding
10:13:00 hotspot,debug Hotspot: dhcp host 18:22:7E:2A:5A:5E/10.63.193.13 added, ip 10.63.193.13
10:13:00 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding address-list rule <00>
10:13:00 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): adding queue <180k/180k 0/0 0/0 0/0 8 64k/64k>
10:13:00 hotspot,account,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): logged in
10:13:36 dhcp,info dhcp1 assigned 10.63.193.40 to 8C:3A:E3:6B:34:DD
10:13:40 hotspot,debug Hotspot: new host detected 8C:3A:E3:6B:34:DD/10.63.193.40 by UDP :57360 -> 10.63.192.1:53
10:13:40 hotspot,debug Hotspot: dhcp host 8C:3A:E3:6B:34:DD/10.63.193.40 added, ip 10.63.193.40
10:14:00 dhcp,info dhcp1 assigned 10.63.193.42 to B8:5A:73:A8:5B:84
10:14:01 hotspot,debug Hotspot: new host detected B8:5A:73:A8:5B:84/10.63.193.42 by UDP :50108 -> 10.63.192.1:53
10:14:01 hotspot,debug Hotspot: dhcp host B8:5A:73:A8:5B:84/10.63.193.42 added, ip 10.63.193.42
10:14:38 dhcp,info dhcp1 deassigned 10.63.193.40 from 8C:3A:E3:6B:34:DD
10:14:38 hotspot,debug Hotspot: dhcp host 10.63.193.40 changed type to dynamic (remove after 5s)
10:14:43 hotspot,debug Hotspot: dynamic host 10.63.193.40 removed: lost dhcp lease
10:15:22 hotspot,debug Hotspot: dhcp host 10.63.193.15 removed: keepalive timeout
10:15:44 dhcp,info dhcp1 deassigned 10.63.193.44 from 6C:2F:2C:1C:E4:DC
10:15:48 hotspot,debug Hotspot: new host detected 8C:3A:E3:6B:34:DD/10.63.193.40 by ICMP type<3> code<3> to 10.63.192.1
10:15:48 hotspot,debug Hotspot: dynamic host 8C:3A:E3:6B:34:DD/10.63.193.40 added, ip 10.63.193.43
10:15:48 dhcp,info dhcp1 assigned 10.63.193.40 to 8C:3A:E3:6B:34:DD
10:15:48 hotspot,debug Hotspot: dynamic host 10.63.193.43 removed: dhcp entry overrides dynamic one
10:15:48 hotspot,debug Hotspot: dhcp host 8C:3A:E3:6B:34:DD/10.63.193.40 added, ip 10.63.193.40
10:16:04 hotspot,debug Hotspot: dhcp host 10.63.193.42 removed: keepalive timeout
10:16:30 hotspot,info,debug T-18:22:7E:2A:5A:5E (10.63.193.13): logged out: session timeout
10:16:30 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing queue
10:16:30 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing address-list
10:16:30 hotspot,debug T-18:22:7E:2A:5A:5E (10.63.193.13): removing ip->user binding
10:16:44 dhcp,info dhcp1 deassigned 10.63.193.22 from 30:19:66:27:D9:9F
10:17:30 hotspot,debug Hotspot: new host detected F4:F1:E1:1E:3A:2C/10.63.194.35 by UDP :56768 -> 10.63.192.1:53
10:17:30 hotspot,debug Hotspot: dhcp host F4:F1:E1:1E:3A:2C/10.63.194.35 added, ip 10.63.194.35
10:18:39 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
10:18:39 hotspot,debug Hotspot: dhcp host 10.63.193.51 changed type to dynamic (remove after 5s)
10:18:44 hotspot,debug Hotspot: dynamic host 10.63.193.51 removed: lost dhcp lease
10:19:09 hotspot,debug Hotspot: new host detected 58:A2:B5:DA:FD:96/10.63.194.39 by UDP :63376 -> 10.63.192.1:53
10:19:09 hotspot,debug Hotspot: dhcp host 58:A2:B5:DA:FD:96/10.63.194.39 added, ip 10.63.194.39
10:19:13 dhcp,info dhcp1 deassigned 10.63.194.39 from 58:A2:B5:DA:FD:96
10:19:13 hotspot,debug Hotspot: dhcp host 10.63.194.39 changed type to dynamic (remove after 5s)
10:19:16 dhcp,info dhcp1 assigned 10.63.194.39 to 58:A2:B5:DA:FD:96
10:19:16 hotspot,debug Hotspot: dynamic host 10.63.194.39 changed type to dhcp (got back lease)
10:19:20 dhcp,info dhcp1 assigned 10.63.193.23 to 38:2D:D1:A5:04:39
10:19:21 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by UDP :19688 -> 10.63.192.1:53
10:19:21 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
10:19:34 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
10:19:35 hotspot,debug Hotspot: new host detected 60:D7:AE:C8:92:CC/10.63.193.51 by UDP :29971 -> 10.63.192.1:53
10:19:35 hotspot,debug Hotspot: dhcp host 60:D7:AE:C8:92:CC/10.63.193.51 added, ip 10.63.193.51
10:19:43 dhcp,info dhcp1 deassigned 10.63.193.59 from F8:A9:D0:5A:F4:85
10:19:54 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
10:21:21 dhcp,info dhcp1 assigned 10.63.193.45 to 9C:E6:E7:07:04:65
10:21:21 hotspot,debug Hotspot: new host detected 9C:E6:E7:07:04:65/10.63.193.45 by UDP :42299 -> 10.63.192.1:53
10:21:21 hotspot,debug Hotspot: dhcp host 9C:E6:E7:07:04:65/10.63.193.45 added, ip 10.63.193.45
10:22:05 hotspot,debug Hotspot: dhcp host 10.63.193.23 removed: keepalive timeout
10:22:11 hotspot,debug Hotspot: dhcp host 10.63.194.39 removed: keepalive timeout
10:23:29 system,info,account user ftp logged in from 10.63.192.255 via ftp
10:23:29 system,info,account user ftp logged out from 10.63.192.255 via ftp
10:23:50 hotspot,debug Hotspot: dhcp host 10.63.193.40 removed: keepalive timeout
10:24:07 system,info,account user ersitizastes logged out from 10.63.192.255 via winbox
10:24:21 dhcp,info dhcp1 deassigned 10.63.194.146 from C4:42:02:21:02:DC
10:27:03 hotspot,debug Hotspot: dhcp host 10.63.193.13 removed: keepalive timeout
10:27:27 dhcp,info dhcp1 assigned 10.63.194.120 to 48:59:29:E3:59:62
10:27:30 dhcp,info dhcp1 assigned 10.63.193.14 to 20:62:74:E9:92:B0
10:27:30 hotspot,debug Hotspot: new host detected 20:62:74:E9:92:B0/10.63.193.14 by UDP :54776 -> 10.63.192.1:53
10:27:30 hotspot,debug Hotspot: dhcp host 20:62:74:E9:92:B0/10.63.193.14 added, ip 10.63.193.14
10:27:36 hotspot,debug Hotspot: new host detected 38:2D:D1:A5:04:39/10.63.193.23 by UDP :65353 -> 10.63.192.1:53
10:27:36 hotspot,debug Hotspot: dhcp host 38:2D:D1:A5:04:39/10.63.193.23 added, ip 10.63.193.23
10:27:44 dhcp,info dhcp1 deassigned 10.63.193.14 from 20:62:74:E9:92:B0
10:27:44 hotspot,debug Hotspot: dhcp host 10.63.193.14 changed type to dynamic (remove after 5s)
10:27:44 dhcp,info dhcp1 assigned 10.63.193.14 to 20:62:74:E9:92:B0
10:27:44 hotspot,debug Hotspot: dynamic host 10.63.193.14 changed type to dhcp (got back lease)
10:28:11 hotspot,debug Hotspot: new host detected 48:59:29:E3:59:62/10.63.194.120 by UDP :15014 -> 10.63.192.1:53
10:28:11 hotspot,debug Hotspot: dhcp host 48:59:29:E3:59:62/10.63.194.120 added, ip 10.63.194.120
10:29:50 hotspot,debug Hotspot: dhcp host 10.63.193.14 removed: keepalive timeout
10:30:42 system,info,account user ersitizastes logged in from 10.63.192.255 via winbox
10:33:37 dhcp,info dhcp1 assigned 10.63.193.47 to 34:BE:00:95:74:65
10:33:39 hotspot,debug Hotspot: new host detected 34:BE:00:95:74:65/10.63.193.47 by UDP :5717 -> 10.63.192.1:53
10:33:39 hotspot,debug Hotspot: dhcp host 34:BE:00:95:74:65/10.63.193.47 added, ip 10.63.193.47
10:33:59 hotspot,debug Hotspot: new host detected 50:55:27:A0:E9:AF/10.63.193.133 by ICMP type<3> code<3> to 10.63.192.1
10:33:59 hotspot,debug Hotspot: dhcp host 50:55:27:A0:E9:AF/10.63.193.133 added, ip 10.63.193.133
10:34:03 script,error Google Down
10:35:00 script,warning Google Up
10:37:30 dhcp,info dhcp1 assigned 10.63.193.38 to 14:32:D1:1C:E1:6E
10:37:31 hotspot,debug Hotspot: new host detected 14:32:D1:1C:E1:6E/10.63.193.38 by UDP :44954 -> 10.63.192.1:53
10:37:31 hotspot,debug Hotspot: dhcp host 14:32:D1:1C:E1:6E/10.63.193.38 added, ip 10.63.193.38
10:39:41 hotspot,debug Hotspot: dhcp host 10.63.193.38 removed: keepalive timeout
10:40:10 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
10:40:10 hotspot,debug Hotspot: dhcp host 10.63.193.51 changed type to dynamic (remove after 5s)
10:40:13 hotspot,debug Hotspot: dynamic host 10.63.193.51 removed: keepalive timeout
10:40:14 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
10:41:29 dhcp,info dhcp1 deassigned 10.63.194.138 from 44:91:DB:51:5E:EB
10:41:33 dhcp,info dhcp1 assigned 10.63.194.138 to 44:91:DB:51:5E:EB
10:41:34 dhcp,info dhcp1 deassigned 10.63.193.51 from 60:D7:AE:C8:92:CC
10:41:34 dhcp,info dhcp1 assigned 10.63.193.51 to 60:D7:AE:C8:92:CC
10:41:43 system,info,account user ersitizastes logged in from 10.63.192.255 via telnet
10:41:53 hotspot,debug Hotspot: new host detected 60:D7:AE:C8:92:CC/10.63.193.51 by UDP :47478 -> 10.63.192.1:53
10:41:53 hotspot,debug Hotspot: dhcp host 60:D7:AE:C8:92:CC/10.63.193.51 added, ip 10.63.193.51
From outside AP
[ersitizastes@5g.net 2] > /interface wireless print
0 R ;;; AP Virtual
name="Ap Virtual" mtu=1500 l2mtu=1600 mac-address=4C:5
master-interface=Station WDS mode=ap-bridge ssid="5g.n
wds-default-bridge=bridge wds-ignore-ssid=yes bridge-m
default-forwarding=no default-ap-tx-limit=0 default-cl
1 R ;;; Station WDS
name="Station WDS" mtu=1500 l2mtu=1600 mac-address=4C:
mode=station-wds ssid="" frequency=auto band=2ghz-b/g/
wireless-protocol=nv2-nstreme-802.11 vlan-mode=no-tag
wds-ignore-ssid=yes bridge-mode=enabled default-authen
default-client-tx-limit=0 hide-ssid=no security-profil
Iám don't understand why ->
my first AP is in 2,4 ghz, b/g 802.11
but the connected Station always jumps to
b/g/n - nv2-nstreme-802.11
Jesus man! Didn’t you have anything longer to post?! :confused:
+1 :laughing:
Put there only separate system package, install it. Then put all other packages you need and install them. You will have more free space further.
Thanks, that did the trick!
For nothing. Enjoy it.
