V6.37 and CCR1009-8G issues
Good evening!
Got new CCR1009 and installed in my network. Before upgrade soft to V6.37. Now is comming out issues - each second day randomly one port decide to not pass traffic till moment when i disable and enable this port. On statistic page for port there are tonn of FCS errors etc. After disabling and enabling port all works ok. First i was thinking that this is connected device or cable problem but next day same situation happend with another port. Before had Cisco switch and not had such problems. Its software problem? Will try to dowgrade to 6.33 as for another my router this is stable version but want to know what wrong now with 6.37
Write to support[at]mikrotik.com or your reseller, i have a ccr1009-8g without any issues on 6.37.1
And? What they will see? Think is that now this happens only with one port - port6. Usualy this happens once per day. To this port was connected Ubiquiti Powerbeam, but yesteday i decide to put between MT and Ubiquiti Cisco Catalyst 2950. Today morning was same. Port6 no traffic and fcs errors between MT and Cisco. Disable/Enagle solve it, but i dont want it. Im not sitting on internet every minute.
Ok. What i just notice - when i check in winbox switch menu i see switch2 in red color and sign unknown. Switch1 is ok - Atheros8327.
All switch2 ports have this trouble what i descibe before.
Question - why is like that and how to solve it?
Looks like this is bug of firmware 3.33. Tried downgrade upgrade RouterOS, but without luck as firmware isnt possible to downgrade or upgrade. Now what? Need to wait till will come out new firmware? Mikrotik support???
