v6.38.3 [current]
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
What’s new in 6.38.3 (2017-Feb-07 09:52):
*) bridge - do not add dynamic hardware STP ports if “master-port” is not capable of hardware STP;
*) bridge - fixed rare crash when hardware STP capable interface gets new “master-port” which already is in bridge;
*) bridge - fixed rare situation when port flapping occurs on bridge ports;
*) bridge - fixed STP/RSTP packet receive on all types of bridge ports;
*) bridge - minor improvements in performance when “master-port” is bridge port;
*) capsman - fixed SGI (Short Guard Interval) support;
*) dhcp - do not listen on IPv4/IPv6 client to IPv6 MLD packets;
*) dude - (changes discussed here: http://forum.mikrotik.com/t/the-dude-v6-38-current-release/104799/1);
*) firewall - added “fasttrack” dummy rule to “/ip firewall raw” table;
*) firewall - do not show IPv4 “fastpath” as active if “route-cache” is disabled;
*) firewall - fixed import of exported configuration that had updated “limit” setting;
*) graphing - fixed graphing crash when high amount of traffic is processed;
*) hotspot - fixed rare kernel crash on multicore systems;
*) ike1 - fixed responder xauth trailing null;
*) leds - fixed defaults for RBSXT5HacD2nr2;
*) mmips - improved general stability;
*) rb3011 - fixed noise from buzzer after silent boot;
*) switch - fixed crash when trying to configure second master port on the same chipset (RB3011, RB2011, CCR1009-8G-1S+);
*) usb - added missing USB ethernet drivers to arm & tile architecture;
*) winbox - added “add-relay-info” and “relay-info-remote-id” to DHCP relay;
*) winbox - added H flag to “/ip arp” ;
*) winbox - added missing “use-fan2” and “active-fan2” to “/system health”;
*) winbox - allow shorten bytes to k,M,G in bridge firewall just like in “/ip firewall”;
*) winbox - do not hide 00:00:00:00:00:00 MAC address in unpublished ARPs;
*) winbox - fixed matching “connection-state=untracked” connections;
*) winbox - fixed typo in “/system resources pci” list;
*) winbox - make “power-cycle-after” show correct value;
*) winbox - updated fan management menu;
*) wireless - added “station-roaming” setting;
*) wireless - update Thailand country frequency settings;
6.38.2 version was factory only release.
A quick question!
I see that the CHR fix for P1 license and error in Queue is not part of this release. Is there a plan when this fix, which is in RC, will be added to stable release?
i was going to put a post up today saying i was having this strange issue where our CHR is being used for VPN and its being capped at 10MB yet i have a P1 licence?
thank god its not just me having this issue!
About CHR issue. As you can see this 6.38.3 version was made on February 7th. Fix for this CHR issue was not ready back then. It will be included in next current/bugfix public release.
I know all that :slight_smile: I’m more interested on a time frame for next release? If you don’t know I’m fine with that just want to know If i should plan to use RC, which I want to avoid, or wait for next release if quick.
Have a look here. You’r not alone :slight_smile:
http://forum.mikrotik.com/t/mikrotik-chr-p1-licence-packet-loss-fixed/106069/1
We can not in any way name dates when next release will be available. We can not predict how development process will go, but as you can see in archive - usually it is around 1 month between releases:
https://mikrotik.com/download/archive
where is wireless - added “station-roaming” setting; ? I cant find this option
ErfanDL - available on “station” mode if “Advanced mode” in wireless settings is enabled and “Wireless” tab " is selected
Thanks. find it. is it possible to enable this feature in AP mode ? example for smartphone wifi roaming
I will settle with this. Big thanks for quick reply. :slight_smile:
What do you expect a station-only feature doing in AP mode?
I want to roaming my wifi clients. such as smartphones, laptop, etc…
Those should already roam to the strongest AP in range. Just give them the same SSID and security settings, and it should work.
Can you elaborate on “mmips - improved general stability”? Is this something I should look to install ASAP to prevent problems?
Also it seems the changelog contains unicode, which of course winbox does not like.
The station roaming setting controls how the Mikrotik device, when connecting to another wireless station, will roam - for example, as weather changes, or if the device moves. It has no relation to how devices that connect to the Mikrotik device choose to roam.
Quick question:
after upgrading I found out that the DST port in NAT RULE Chain/dstnat now disabled… and not editable… also if you want to create new rule
What to do now?
Dexlaine
LCD interfaces is broken, it does not switch between interfaces. In my case, LCD shows only pppoe-wan, other interfaces are not shown. What is the timeout then?
upgrade WinBox? :slight_smile:
Thanks for reply.
