For now everything runs smoothly and as expected. I still dont use it for wifi p2p or p2mp links, because of wifi “problems”, on other devices as I said - works great
Thanks for the explanation. Currently we use straight up RSTP, but I can see a day coming when we could benefit from using MSTP. Any plans to add that option?
model: RouterBOARD 962UiGS-5HacT2HnT
support output file contains pre-shared key in clear text format I will not send it
v 6.7.3
CPU load 85-90%
and after update
v 6.8
and CPU load 100%
vitaliyy, please provide the export file to support@mikrotik.com from both versions (you can replace the pre-shared keys in those files).
At least on my spare hAP AC router I got 500/700Mbps (download/upload), I hit ISP bandwidth limit.
I have just received another RB750Gr3 in the post today and I decided to update the firmware and rOS as the first things I do before configuring it. After doing the upgrade(s) I started to adjust the packages which are installed by default as there are a few which isn’t so useful to me like wireless and hotspot as it doesn’t have wireless in this model.
I then just found that there is a very small graphical bug with the icon that is used for disabled packages.
I am enclosing a screenshot below which shows the disabled missing graphic.
Every update new problems
When was 5.x no problems with updates
6.1x was last stable, future realese fix on fix
I have also hex r3 with vlan bridge and problems
5ghz sxt ap lvl4 update to 6,38 and die
Maybe config conflict?
But he is in bridge and no other config
Bad bad and bad
After updating RB2011 I got issues with flapping sfp-port. All worked fine before on 6.37.3 and now I reverted back to bugfix only and all is fine again.
It was not fixed for my situation, when the main site was 6.38 and the clients were still 6.37.3.
It was “fixed” by upgrading every router to 6.38 which was not planned this day.
This still means that IPsec with xAuth and a password longer than 31 Chars is treated differently in ROS 6.37.3 than in 6.38 which leads to problems when “old” clients try to connect.
