v6.38rc [release candidate] is released
What’s new in 6.38rc7 (2016-Sep-30 07:33):
!) ssl - fixed peer address/dns verification from certificate (affects sstp, fetch, capsman);
!) switch - added hardware stp functionality for CRS devices (http://wiki.mikrotik.com/wiki/Manual:CRS_examples#Spanning_Tree_Protocol);
!) winbox - now Winbox 3.6 is the minimum version that can connect to RouterOS;
*) arp - added local-proxy-arp feature;
*) capsman - added possibility to change arp, mtu, l2mtu values in datapath configuration (CLI only);
*) console - fixed typo in web-proxy (passthru to passhtrough);
*) discovery - added LLDP support;
*) dude - (changes discussed here: http://forum.mikrotik.com/t/the-dude-v6-38rc-test-builds/101859/1);
*) export - do not show mac-address in export when it is not necessary;
*) firewall - added creation-time to address list entries;
*) firewall - fixed dynamic dummy firewall rules appearance in raw tables;
*) hotspot - fixed nat rule dst-port by making it visible again;
*) interface - do not treat multiple zeros as single zero on name comparison;
*) interface - show link stats in “/interface print stats-detail” output;
*) ipsec - allow to specify explicit split dns address;
*) ipsec - changed logging topic from error to debug when empty pfkey messages are received;
*) led - fixed default led settings for wAP2nDr2;
*) lte - fixed init delay after power reset;
*) mobile - added support for more Vodafone K4201-Z and ZTE MF90 modems;
*) package - fixed wireless package status after upgrade to 6.37;
*) rb850Gx2 - fixed pcb temperature monitor if temperature was above 60C;
*) snmp - do not allow to execute script if user does not have write permission;
*) tile - do not reboot device after watchdog disable/enable;
*) usb - fixed kernel failure when Nexus 6P device is removed;
*) userman - always re-fetch table data when switching between different menus;
*) userman - fixed timezone adjustment in reports;
*) users - added TikApp policy;
*) winbox - added loop-protect settings;
*) winbox - added passthrough state to web-proxy;
*) winbox - allow to unset http-proxy field on sstp client;
*) winbox - do not show health menu on RB951-2n;
*) winbox - do not show hotspot user profile incoming and outgoing filters and marks as set if there is no value specified;
*) winbox - fixed typo in dhcpv6 relay (DCHP to DHCP);
*) winbox - show address expiration time in dhcp client list;
*) winbox - show primary and secondary ntp addresses as 0.0.0.0 if none are set;
*) wireless - added api command to report country-list (/interface/wireless/info/country-list);
*) wireless - fixed rare kernel failure when connecting to nv2 access point with legacy rate select;
*) wireless - show DFS flag in country-info command output;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
OMG … *) discovery - added LLDP support;
It’s time for the party :slight_smile:
It is not yet available via the “check for updates” button when selecting release candidate.
Will try again later.
STP… Great! What about other products with switching chip?
PARTY, PARTY, PARTY !!!
Thanks Mikrotik :slight_smile:
A very nonchalant post…not!! Great updates!!!
Where can I configure LLDP, I cant find anything related to it in “/ip neighbor” or anywhere else.
It seems like LLDP is enabled automatically when neighbour discovery is enabled for an interface.
Our switch sees the MikroTik in its LLDP table now, just no way to configure it on RouterOS yet I guess.
And no way to see LLDP peer table in Router OS yet.
And of course LLDP data it not in SNMP either…
I see my LLDP peers in the “/ip neighbour show” table on RouterOS. They don’t have any info other than mac-address and IP (Mikrotik devices show software-id, version, etc.)
Still missing in my opinion: rp_filter per interface. Should be a small thing to implement.
Neither of the 2 switches connected to my test MikroTik show up over LLDP in its “/ip neighbor print detail”.
Great news with STP on CRS. What I would like to see is hardware support for LACP on CRS, any chance/ time scale for that?
Any chance we’ll see increased wireless speeds with AC WLAN equipment like the wAP/hAP? 400-420 Mbit max with a MacBookPro seems about 100-300 Mbit slower than the competition…
STP and LLDP, look out !
when it will be in the manual? :slight_smile: need at least a short description…
Apparently only outgoing LLDP for now?
local proxy-arp normally means: router will reply to ARP for hosts it can directly reach, not for hosts it can route to.
in other words, it will search only interface/connected (by the way, which of two exactly? tech guys, we need your knowledge!) routes in routing table, not all routes? thanks
If after upgrade you still see another (unnecessary) wireless package under System/Package menu, then do not worry It will disappear after next reboot of device.
