v6.38rc [release candidate] is released
No!
6.37.1 and 6.37.2 have separate changelogs. Please read carefully.
Hello i think maybe is better talk about 6.37.1/6.37.2 on the 6.37.x Topic
Version 6.38rc34 has been released.
Changes since 6.38rc31:
!) ipsec - added IKEv1 xauth user authentication with RADIUS “/ip ipsec user settings set xauth-use-radius=yes” (cli only);
!) ipsec - added IKEv2 EAP RADIUS passthrough authentication for responder (cli only);
!) ipsec - added IKEv2 experimental support with pre-shared-key and rsa-signature authentication methods (cli only);
!) ipsec - added support unique policy generation (cli only);
!) tr069-client - initial implementation (as separate package);
*) bonding - added “forced-mac-address” option;
*) certificates - added support for PKCS#12 export;
*) chr - fixed crash on “/interface print” (introduced in 6.36.4);
*) chr - fixed crash on “/system shutdown” and “/system shutdown”;
*) dude - (changes discussed here: http://forum.mikrotik.com/t/the-dude-v6-38rc-test-builds/101859/1);
*) firewall - new faster “connection-limit” option implementation;
*) ospf - fixed route crash caused by memory corruption when there are multiple active interfaces;
*) smb - fixed crash on connect (introduced in 6.38rc1);
*) tile - fixed rare kernel failure when IPv6 neighbor discovery packet is received;
*) traceroute - fixed crash when too many sessions are active;
*) winbox - recognize properly tcp in traffic-generator packet-template header type;
*) winbox - show HT MCS tab if 2GHz-G/N band is used;
*) wireless - added CRL checking for eap-tls;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
This will make deployment so much easier! Thanks :slight_smile:
I think this may have solved my issues with my CHR in Hyper-V. :slight_smile:
I can boot a fresh copy now without issues. Will try to upgrade my CHR asap to verify.
Yepp this have solved my issues with CHR on Hyper-V (2012 R2). Upgrade went just fine from 6.36.3 and tested several reboots without any hickup.
So good work Mikrotik :slight_smile:
Version 6.38rc35 has been released.
Changes since previous version:
*) disk - fixed issue when disk was renamed after reboot on devices with flash disks;
*) tunnel - allow to force mtu value when actual-mtu is already the same;
*) tunnel - fixed transmit packets occasionally not going through fastpath;
Hi All,
I’ve just updated to rc35 and would like to report that the ipsec multi session behind a single NAT seems a bit buggy. While both sessions work for a few moments, as soon as traffic is passed, the session that connected first eventually becomes unuseable. I’m new to Mikrotik reporting, so if you’d like me to collect client side, and server side pcaps or anything, let me know.
/ppp profile
set *0 address-list="" !bridge !bridge-path-cost !bridge-port-priority \
    change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter \
    !insert-queue-before !local-address name=default on-down="" on-up="" \
    only-one=default !outgoing-filter !parent-queue !queue-type !rate-limit \
    !remote-address remote-ipv6-prefix-pool=none !session-timeout \
    use-compression=default use-encryption=default use-ipv6=yes use-mpls=\
    default use-upnp=default !wins-server
/ppp profile
add address-list="" bridge=bridge-local !bridge-path-cost \
    !bridge-port-priority change-tcp-mss=yes dns-server=\
    192.168.88.2,192.168.88.20 !idle-timeout !incoming-filter \
    !insert-queue-before local-address=192.168.99.1 name=\
    L2TP-IPSec-VPN-Mobile on-down="" on-up="" only-one=default \
    !outgoing-filter !parent-queue !queue-type !rate-limit remote-address=\
    vpnClients !session-timeout use-compression=no use-encryption=required \
    use-ipv6=yes use-mpls=no use-upnp=yes wins-server=\
    192.168.88.20,192.168.88.5
/interface l2tp-server server
set allow-fast-path=no authentication=mschap2 default-profile=\
    L2TP-IPSec-VPN-Mobile enabled=yes keepalive-timeout=30 max-mru=1460 \
    max-mtu=1460 max-sessions=unlimited mrru=disabled use-ipsec=yes
/interface ovpn-server server
set auth=sha1 certificate=1_vpn.photosphere.net_bundle.crt_0 cipher=aes256 \
    default-profile=L2TP-IPSec-VPN-Mobile enabled=yes keepalive-timeout=60 \
    mac-address=x:x:x:x:x:x max-mtu=1500 mode=ip netmask=24 port=1194 \
    require-client-certificate=no
add address=0.0.0.0/0 auth-method=pre-shared-key comment=\
    "L2TP/IPSEC Dial-in Mobile Clients" dh-group=modp1024 disabled=no \
    dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=aes-128,3des \
    exchange-mode=main-l2tp generate-policy=port-strict hash-algorithm=sha1 \
    lifetime=1d local-address=:: mode-config=pdn-vpn-split nat-traversal=yes \
    passive=no policy-template-group=default proposal-check=obey \
    send-initial-contact=yes
    "L2TP/IPSEC Dial-in Laptop Clients" dh-group=modp1024 disabled=no \
    passive=no policy-template-group=pdn-vpn proposal-check=obey \
/ip ipsec peer
/ip ipsec policy
set 0 disabled=no dst-address=0.0.0.0/0 group=default level=require proposal=\
    L2TP-VPN-IPsec protocol=all src-address=0.0.0.0/0 template=yes
add disabled=no dst-address=0.0.0.0/0 group=pdn-vpn level=require proposal=\
    "L2TP/IPSEC Dial-in Laptop Clients" protocol=all src-address=0.0.0.0/0 \
    template=yes
add action=encrypt comment=MARS-PDN<->ADMS-DUB disabled=yes dst-address=\
    0.0.0.0/0 dst-port=any ipsec-protocols=esp level=require priority=0 \
    proposal="L2TP/IPSEC Dial-in Laptop Clients" protocol=all sa-dst-address=\
    185.58.18.243 sa-src-address=x.x.x.x src-address=0.0.0.0/0 src-port=\
    any tunnel=yes
Version 6.38rc36 has been released.
Changes since 6.38rc35:
*) file - fixed file manager crash when file transfer gets cancelled;
*) mipsbe - improved memory allocation on devices with nand when file transfer and tcp traffic processing is on progress;
*) ppp - significantly improved shutdown speed on servers with many active tunnels;
bug:
Reset TR-069 data? [y/N]:
y
/pckg/tr069-client/home/TR069-reset.sh: 3: pkill: not found
done
I have a problem with latest 6.38rc build when I try to update Mikrotik hAP lite (RB941-2nD).When the upgrade is finish and router reboot I can’t connect to the router anymore.
No wireles signal and no neighbors mac address.The only way is netinstall.Does anyone have the same problems because I never before have the same problem?
+1 with two RouterBoards hAP lite (RB941-2nD) on v6.38rc35. On v6.38rc36 all OK.
Attempting to upgrade a CHR install of 6.38rc31 to 6.38rc36 results in the following log entries:
licence does not permit to upgrade routeros-x86-6.38rc36
licence does not permit to upgrade dude-6.38rc36
open /dev/panics failed
I have the dude package installed as well (this is my dude test install).
This is a system running a P1 level licence as its a test system.
Next Renewal is listed as November 25th 2016, Deadline is listed as November 18th 2016.
Limited upgrades is checked.
I just tried renewing the licence and there was no change to the next renewal date or the deadline date.
So the upgrade seams to be limited by my licence, though looking at the dates shown in the licence dialog it would seem to me that things are still ok…
Just curious for some clarification to my understanding, or if this is a bug.
chris.
CRS125-24G-1S upgraded from 6.38rc34 (or 6.38rc35) to 6.38rc36 went in ‘dead state’ (probable kernel panic, I had no possibility to check with console cable). After manually power cycling two times it came back alive correctly on 6.38rc36 and now seems to work normally. Probably this is an isolated/local issue but maybe someone has the same problem and go directly to netinstall; try to power cycle the device a couple of time before netinstall.
No problem noticed instead on upgrading a hEX (gr3) and a hAP lite (lab devices). Conversely, from rc34 on, the new hEX (gr3) seems has definitely more stable ethernet interfaces ..they sometimes were flapping in a strange way > links down counters increasing without notices in log , Gbit links flapping and going 100M after half dozen negotiation tries (linked to CRS125)
Fix included in next built, but in general, this command should not be used. We will remove it. It was meant to completely reset the TR069 program, if it is completely crashed. Not needed in normal use.
After upgrading to rc36 from the previous rc, my RB2011UAS-2HnD went to 100% CPU usage. It used to be under 15%.
It doesn’t crash, just runs at 100%. Routing is noticeably slow, so it’s not a CPU usage reading error, but a real 100% usage.
I haven’t seen this problem with any of the previous RCs (I upgrade this router as soon as there’s an RC update).
I’m not seeing any problems on x86_64, so I’m guessing it might be related to the latest memory allocation update for mipsbe :slight_smile:
Here’s a screenshot: https://dl.horza.org/routeros/routeros-mipsbe-638rc36-cpu-usage.png
Update: I’ve rebooted it and it’s fine now. Will keep monitoring.
Version 6.38rc37 has been released.
Changes since 6.38rc36:
*) firewall - fixed filter rule “limit” parameter by making it visible again;
*) hAP lite - fixed bootup (broken in v6.38rc35);
Please report to support; i’ve had similar issue with RB2011 which could not be reproduced.
In my case the router spiked to 100% cpu after upgrade from 6.38rc25 to 6.38rc31 with a certificate bundle present.
Ticket#2016110822001251
I have installed this version as I already want to connect Vodafone K4201-Z LTE USB Modem in RB2011UAS-IN router.
I have tried to configure it, but without any success.
Could someone help me?
Thank you in advance.
IPSEC IKEv2 not working in latest RCs.
In version 6.38rc31 was working fine. Updated to 6.38rc35 IPsec cannot establish tunnel. Update to 6.38rc37 same problem.
This is a test environment.
R1:
Logs:
Nov/25/2016 14:08:39 ipsec,debug ==========
Nov/25/2016 14:08:39 ipsec,debug 268 bytes message received from 10.1.0.1[500] to 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet e58e1a2e bdaa3dc0 00000000 00000000 29202208 00000000 0000010c 28000008
Nov/25/2016 14:08:39 ipsec,debug,packet 00004000 2200001c 2f303127 c4ca221f 0a3f66de 303a3904 ce77e2d8 14c1b8e9
Nov/25/2016 14:08:39 ipsec,debug,packet 21000088 00020000 be28d5e3 63b9b4f1 0270204c 3a25fe10 ce529482 d2a42f81
Nov/25/2016 14:08:39 ipsec,debug,packet 4bd1caf9 1dbecd12 6afcbf51 71b11f3b 02152329 6e15a0e2 c9d743f9 893b2835
Nov/25/2016 14:08:39 ipsec,debug,packet 250741df ad128056 b3d4c9e1 4d38d551 8a5993e5 75eb4eec cae195d3 7c36470c
Nov/25/2016 14:08:39 ipsec,debug,packet 7c27a5ea 40fe6f87 0add9e36 839bf114 42ba3794 470df073 0b24263f ec96e130
Nov/25/2016 14:08:39 ipsec,debug,packet b4e8c55e 7412a936 00000044 00000040 01010006 0300000c 0100000c 800e0100
Nov/25/2016 14:08:39 ipsec,debug,packet 0300000c 0100000c 800e0080 03000008 01000003 03000008 02000005 03000008
Nov/25/2016 14:08:39 ipsec,debug,packet 03000003 00000008 04000002
Nov/25/2016 14:08:39 ipsec,debug ike2 request exchange: SA_INIT id: 0
Nov/25/2016 14:08:39 ipsec,debug ike2 respond
Nov/25/2016 14:08:39 ipsec,debug payload seen: NOTIFY
Nov/25/2016 14:08:39 ipsec,debug payload seen: NONCE
Nov/25/2016 14:08:39 ipsec,debug payload seen: KE
Nov/25/2016 14:08:39 ipsec,debug payload seen: SA
Nov/25/2016 14:08:39 ipsec,debug processing payload: NONCE
Nov/25/2016 14:08:39 ipsec,debug processing payload: SA
Nov/25/2016 14:08:39 ipsec,debug IKE Protocol: IKE
Nov/25/2016 14:08:39 ipsec,debug  proposal #1
Nov/25/2016 14:08:39 ipsec,debug   enc: aes256-cbc
Nov/25/2016 14:08:39 ipsec,debug   enc: aes128-cbc
Nov/25/2016 14:08:39 ipsec,debug   enc: 3des-cbc
Nov/25/2016 14:08:39 ipsec,debug   prf: hmac-sha256
Nov/25/2016 14:08:39 ipsec,debug   auth: sha256
Nov/25/2016 14:08:39 ipsec,debug   dh: modp1024
Nov/25/2016 14:08:39 ipsec,debug matched proposal:
Nov/25/2016 14:08:39 ipsec,debug processing payload: KE
Nov/25/2016 14:08:39 ipsec,debug => shared secret (size 0x80)
Nov/25/2016 14:08:39 ipsec,debug ea813706 7c9cb1c4 b6cdaf4c 73158754 df387020 4d154f95 7bbd26e7 4c14159e
Nov/25/2016 14:08:39 ipsec,debug ac2a98eb 6fbc5eb0 6c78b12b a784e89b d7f59b31 9b9f8bcb b6cd9b84 4a1d6e1e
Nov/25/2016 14:08:39 ipsec,debug 707023d1 45d7b35f 78b6c342 f967894d 784ea3ea 7d9ced9d ceb909f8 67e1c99a
Nov/25/2016 14:08:39 ipsec,debug fe2bdd3d 80bfb5a2 f69f8f1a 6d0fa025 08571c3c 0d197aa9 72fc6f96 7b674e68
Nov/25/2016 14:08:39 ipsec,debug adding payload: SA
Nov/25/2016 14:08:39 ipsec,debug => (size 0x30)
Nov/25/2016 14:08:39 ipsec,debug 00000030 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005
Nov/25/2016 14:08:39 ipsec,debug 03000008 03000003 00000008 04000002
Nov/25/2016 14:08:39 ipsec,debug adding payload: KE
Nov/25/2016 14:08:39 ipsec,debug => (size 0x88)
Nov/25/2016 14:08:39 ipsec,debug 00000088 00020000 414aaee4 22891380 c2743b6e f2441419 d8bcf44b c88ce7f0
Nov/25/2016 14:08:39 ipsec,debug 09481773 cff0e6ca f69867bc 724fab65 d8aea6a7 88e5febe 05c2079e 9b319632
Nov/25/2016 14:08:39 ipsec,debug 4ca94d42 63a8811f 4a21e1d9 cdeb9d31 b9176be7 c390ceee 057db503 d81f9055
Nov/25/2016 14:08:39 ipsec,debug 4164b805 0e5afa77 e9ed3f91 9e047fee 64e2acc1 c9f28a5b b8e63853 15b1ca07
Nov/25/2016 14:08:39 ipsec,debug 63a442df b4d8da49
Nov/25/2016 14:08:39 ipsec,debug adding payload: NONCE
Nov/25/2016 14:08:39 ipsec,debug => (size 0x1c)
Nov/25/2016 14:08:39 ipsec,debug 0000001c 8b24f42f aada2a63 b1d521de 55c5e635 450f145c 1e79b6cc
Nov/25/2016 14:08:39 ipsec,debug adding payload: NOTIFY
Nov/25/2016 14:08:39 ipsec,debug => (size 0x8)
Nov/25/2016 14:08:39 ipsec,debug 00000008 00004000
Nov/25/2016 14:08:39 ipsec,debug sending 248 bytes from 10.0.0.1[500] to 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet sockname 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet send packet from 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet send packet to 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet src4 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet dst4 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet 1 times of 248 bytes message will be sent to 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet e58e1a2e bdaa3dc0 b26151ae a98a503f 21202220 00000000 000000f8 22000030
Nov/25/2016 14:08:39 ipsec,debug,packet 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005 03000008
Nov/25/2016 14:08:39 ipsec,debug,packet 03000003 00000008 04000002 28000088 00020000 414aaee4 22891380 c2743b6e
Nov/25/2016 14:08:39 ipsec,debug,packet f2441419 d8bcf44b c88ce7f0 09481773 cff0e6ca f69867bc 724fab65 d8aea6a7
Nov/25/2016 14:08:39 ipsec,debug,packet 88e5febe 05c2079e 9b319632 4ca94d42 63a8811f 4a21e1d9 cdeb9d31 b9176be7
Nov/25/2016 14:08:39 ipsec,debug,packet c390ceee 057db503 d81f9055 4164b805 0e5afa77 e9ed3f91 9e047fee 64e2acc1
Nov/25/2016 14:08:39 ipsec,debug,packet c9f28a5b b8e63853 15b1ca07 63a442df b4d8da49 2900001c 8b24f42f aada2a63
Nov/25/2016 14:08:39 ipsec,debug,packet b1d521de 55c5e635 450f145c 1e79b6cc 00000008 00004000
Nov/25/2016 14:08:39 ipsec,debug => skeyseed (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug e4140415 f6c44305 b00e772f 2466e965 bd5a5c9f f88cc90f a8e2e020 f978fffb
Nov/25/2016 14:08:39 ipsec,debug => keymat (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 42bcaf55 017ee579 f0cf1406 ae2804f2 2053defe 36bac9b5 8c047b64 8c8b26c1
Nov/25/2016 14:08:39 ipsec,debug => SK_ai (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 5b6ba7eb 373defbd 5833af59 d361276d 0540c19f 32e71f1c b9e26b21 435e2a06
Nov/25/2016 14:08:39 ipsec,debug => SK_ar (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug a094c725 7da338e8 ce4c92fd e9121181 8545e8fd 5a669f98 cd3d06ac 5fad4592
Nov/25/2016 14:08:39 ipsec,debug => SK_ei (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 3394c436 817ff745 0222fd60 ef8fe617 afb60465 56be2644 237d496e c63274ff
Nov/25/2016 14:08:39 ipsec,debug => SK_er (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 22038ce2 fe68beaa db466833 42d47dd7 79cf05ea e761d595 f5f8b33b 57790d5f
Nov/25/2016 14:08:39 ipsec,debug => SK_pi (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 495a755b 48b30049 bf76c375 b1e01717 69f17677 1f995bf9 4ab7ab04 e89fe417
Nov/25/2016 14:08:39 ipsec,debug => SK_pr (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 83695fe0 bf978030 63483518 38c7b456 1546dfbc 17f56c56 c31ba125 2035315f
Nov/25/2016 14:08:39 ipsec,debug processing payloads: NOTIFY
Nov/25/2016 14:08:39 ipsec,debug new ph1 responder connection established
Nov/25/2016 14:08:39 ipsec,info new ike2 responder connection: 10.0.0.1[4500]<->10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug child negitiation timeout in state 0
Nov/25/2016 14:09:09 ipsec,info killing connection: 10.0.0.1[4500]<->10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug ==========
Nov/25/2016 14:09:09 ipsec,debug 260 bytes message received from 10.1.0.1[500] to 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet 08533b26 8e569ae1 00000000 00000000 28202208 00000000 00000104 2200001c
Nov/25/2016 14:09:09 ipsec,debug,packet e9fcdb31 8ef511b8 4e5cf796 a155c900 8f4bbc9d 0e584fde 21000088 00020000
Nov/25/2016 14:09:09 ipsec,debug,packet 3535e12f bb56e239 39d369f0 e6766003 afdfa3f2 c71523d1 919bf021 02226348
Nov/25/2016 14:09:09 ipsec,debug,packet c18f9279 ef1d1c31 0a94b87a 9ad02c67 2034e9c8 8c9605e6 14af48f7 e215c8fd
Nov/25/2016 14:09:09 ipsec,debug,packet 2626d63e 32a5f288 8cc3897d 6cdf73e2 6bb9bed6 b5e161a7 2d7d5d15 d5d48abd
Nov/25/2016 14:09:09 ipsec,debug,packet 946cf3bd 2b5ee323 ca76cc4c 9c8fb360 f3d226ad 2d68cee9 f9852e1a e044d755
Nov/25/2016 14:09:09 ipsec,debug,packet 00000044 00000040 01010006 0300000c 0100000c 800e0100 0300000c 0100000c
Nov/25/2016 14:09:09 ipsec,debug,packet 800e0080 03000008 01000003 03000008 02000005 03000008 03000003 00000008
Nov/25/2016 14:09:09 ipsec,debug,packet 04000002
Nov/25/2016 14:09:09 ipsec,debug ike2 request exchange: SA_INIT id: 0
Nov/25/2016 14:09:09 ipsec,debug ike2 respond
Nov/25/2016 14:09:09 ipsec,debug payload seen: NONCE
Nov/25/2016 14:09:09 ipsec,debug payload seen: KE
Nov/25/2016 14:09:09 ipsec,debug payload seen: SA
Nov/25/2016 14:09:09 ipsec,debug processing payload: NONCE
Nov/25/2016 14:09:09 ipsec,debug processing payload: SA
Nov/25/2016 14:09:09 ipsec,debug IKE Protocol: IKE
Nov/25/2016 14:09:09 ipsec,debug  proposal #1
Nov/25/2016 14:09:09 ipsec,debug   enc: aes256-cbc
Nov/25/2016 14:09:09 ipsec,debug   enc: aes128-cbc
Nov/25/2016 14:09:09 ipsec,debug   enc: 3des-cbc
Nov/25/2016 14:09:09 ipsec,debug   prf: hmac-sha256
Nov/25/2016 14:09:09 ipsec,debug   auth: sha256
Nov/25/2016 14:09:09 ipsec,debug   dh: modp1024
Nov/25/2016 14:09:09 ipsec,debug matched proposal:
Nov/25/2016 14:09:09 ipsec,debug processing payload: KE
Nov/25/2016 14:09:09 ipsec,debug => shared secret (size 0x80)
Nov/25/2016 14:09:09 ipsec,debug 9afb5527 4cafbb2e d54bceb4 8f6c0456 2622a823 febd9a56 27d12929 e0b10668
Nov/25/2016 14:09:09 ipsec,debug d0b9e0fa 149f33c6 9e27a0c0 27370b9f 5628f91c 485c6969 039a3dfd 210e72f2
Nov/25/2016 14:09:09 ipsec,debug 156393e0 da565391 bf7a93ea 17eed1a3 e0cb643c f57638a8 b6034a6c 726c60a3
Nov/25/2016 14:09:09 ipsec,debug 97cb47d5 2376dfbc e6b11b4e 9b42ca8b 2e7b1b3c 11f44b05 79d2e373 ef1e10c9
Nov/25/2016 14:09:09 ipsec,debug adding payload: SA
Nov/25/2016 14:09:09 ipsec,debug => (size 0x30)
Nov/25/2016 14:09:09 ipsec,debug 00000030 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005
Nov/25/2016 14:09:09 ipsec,debug 03000008 03000003 00000008 04000002
Nov/25/2016 14:09:09 ipsec,debug adding payload: KE
Nov/25/2016 14:09:09 ipsec,debug => (size 0x88)
Nov/25/2016 14:09:09 ipsec,debug 00000088 00020000 81d9a1a9 70eaef1f f42a0eb5 8040e55e 7733abf4 5ff4370c
Nov/25/2016 14:09:09 ipsec,debug c1554259 afef4c14 4eef9d9b 40ff484c 81418660 a56d311c a0c4e99a 5d52365e
Nov/25/2016 14:09:09 ipsec,debug f99e3492 efad4281 d441f7a9 4032ce8a 1b69f2f8 30a6573d cada7ada 9cedc372
Nov/25/2016 14:09:09 ipsec,debug 85dc22e9 519b2ede a5c000ee c932ca6e 8110e8c0 9fbe3edb e19d4a0d 52b861c3
Nov/25/2016 14:09:09 ipsec,debug e5f7b8b4 eb3215d2
Nov/25/2016 14:09:09 ipsec,debug adding payload: NONCE
Nov/25/2016 14:09:09 ipsec,debug => (size 0x1c)
Nov/25/2016 14:09:09 ipsec,debug 0000001c 649ccbf5 fc6dedcb ab685964 6981c266 640942fa 1e48d13a
Nov/25/2016 14:09:09 ipsec,debug sending 240 bytes from 10.0.0.1[500] to 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet sockname 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet send packet from 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet send packet to 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet src4 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet dst4 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet 1 times of 240 bytes message will be sent to 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet 08533b26 8e569ae1 2867bb59 b21566a3 21202220 00000000 000000f0 22000030
Nov/25/2016 14:09:09 ipsec,debug,packet 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005 03000008
Nov/25/2016 14:09:09 ipsec,debug,packet 03000003 00000008 04000002 28000088 00020000 81d9a1a9 70eaef1f f42a0eb5
Nov/25/2016 14:09:09 ipsec,debug,packet 8040e55e 7733abf4 5ff4370c c1554259 afef4c14 4eef9d9b 40ff484c 81418660
Nov/25/2016 14:09:09 ipsec,debug,packet a56d311c a0c4e99a 5d52365e f99e3492 efad4281 d441f7a9 4032ce8a 1b69f2f8
Nov/25/2016 14:09:09 ipsec,debug,packet 30a6573d cada7ada 9cedc372 85dc22e9 519b2ede a5c000ee c932ca6e 8110e8c0
Nov/25/2016 14:09:09 ipsec,debug,packet 9fbe3edb e19d4a0d 52b861c3 e5f7b8b4 eb3215d2 0000001c 649ccbf5 fc6dedcb
Nov/25/2016 14:09:09 ipsec,debug,packet ab685964 6981c266 640942fa 1e48d13a
Nov/25/2016 14:09:09 ipsec,debug => skeyseed (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 6fa0aa32 750b1ef1 8eb224c6 dd61cf88 6d387e37 3156c620 0a747f71 87ff6603
Nov/25/2016 14:09:09 ipsec,debug => keymat (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug d7d2ed58 f4df921d 752a7a7a 843c19ee c3f739bd 13f4b887 d4efc8fd 2be5fb07
Nov/25/2016 14:09:09 ipsec,debug => SK_ai (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug b14d5740 de4f8e9d 3ca9e169 e11f01a7 6ed882a3 58c2aede 50edf2de 3d9cefcf
Nov/25/2016 14:09:09 ipsec,debug => SK_ar (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 089c8f67 f8f6355a 82e3307b c0f71b52 c5af09fd 4ec0f978 4cfd8b83 aed91574
Nov/25/2016 14:09:09 ipsec,debug => SK_ei (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 5830aa26 cd8feaec c13e1e82 db08986e c74f66fa d9028500 9e6b7e09 96913fa7
Nov/25/2016 14:09:09 ipsec,debug => SK_er (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 908529fd 65bd352b 27077fba 1ff189a5 420f46cf 22e65764 ab1454ec c39c215d
Nov/25/2016 14:09:09 ipsec,debug => SK_pi (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 4a8407ff f9d596ae d280d852 f640c3fe e5dd4dda 09113595 fe702fa7 b98f1b4f
Nov/25/2016 14:09:09 ipsec,debug => SK_pr (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 108fd66f cce6c2f8 f1219c9a c1da7f0e 3fe9cba0 b8002026 42cbdd90 41ab0b61
Nov/25/2016 14:09:09 ipsec,debug processing payloads: NOTIFY
Nov/25/2016 14:09:09 ipsec,debug none payloads found!
Nov/25/2016 14:09:09 ipsec,debug new ph1 responder connection established
Nov/25/2016 14:09:09 ipsec,info new ike2 responder connection: 10.0.0.1[4500]<->10.1.0.1[500]
Nov/25/2016 14:09:29 ipsec,info killing connection: 10.0.0.1[4500]<->10.1.0.1[500]
IPsec export:
# nov/25/2016 14:22:17 by RouterOS 6.38rc37
# software id =
/ip ipsec proposal
add enc-algorithms=aes-256-cbc,aes-128-cbc,3des name=VPN pfs-group=none
/ip ipsec peer
add address=10.1.0.1/32 disabled=yes dpd-interval=disable-dpd enc-algorithm=aes-256,aes-128,3des exchange-mode=ike2 hash-algorithm=sha256 \
    nat-traversal=no passive=yes secret=TEST
/ip ipsec policy
add dst-address=192.168.170.0/24 proposal=VPN sa-dst-address=10.1.0.1 sa-src-address=10.0.0.1 src-address=192.168.160.0/24 tunnel=yes
R2:
Logs:
Nov/25/2016 14:08:39 ipsec,debug ike2 initialize send for: 10.0.0.1
Nov/25/2016 14:08:39 ipsec,debug 0000001c 2f303127 c4ca221f 0a3f66de 303a3904 ce77e2d8 14c1b8e9
Nov/25/2016 14:08:39 ipsec,debug 00000088 00020000 be28d5e3 63b9b4f1 0270204c 3a25fe10 ce529482 d2a42f81
Nov/25/2016 14:08:39 ipsec,debug 4bd1caf9 1dbecd12 6afcbf51 71b11f3b 02152329 6e15a0e2 c9d743f9 893b2835
Nov/25/2016 14:08:39 ipsec,debug 250741df ad128056 b3d4c9e1 4d38d551 8a5993e5 75eb4eec cae195d3 7c36470c
Nov/25/2016 14:08:39 ipsec,debug 7c27a5ea 40fe6f87 0add9e36 839bf114 42ba3794 470df073 0b24263f ec96e130
Nov/25/2016 14:08:39 ipsec,debug b4e8c55e 7412a936
Nov/25/2016 14:08:39 ipsec,debug => (size 0x44)
Nov/25/2016 14:08:39 ipsec,debug 00000044 00000040 01010006 0300000c 0100000c 800e0100 0300000c 0100000c
Nov/25/2016 14:08:39 ipsec,debug 800e0080 03000008 01000003 03000008 02000005 03000008 03000003 00000008
Nov/25/2016 14:08:39 ipsec,debug 04000002
Nov/25/2016 14:08:39 ipsec,debug sending 268 bytes from 10.1.0.1[500] to 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet sockname 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet send packet from 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet send packet to 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet src4 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet dst4 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet 1 times of 268 bytes message will be sent to 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug 248 bytes message received from 10.0.0.1[500] to 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug ike2 answer exchange: SA_INIT id: 0
Nov/25/2016 14:08:39 ipsec,debug ike2 initialize recv
Nov/25/2016 14:08:39 ipsec,debug new ph1 initiator connection established
Nov/25/2016 14:08:39 ipsec,info new ike2 initiator connection: 10.1.0.1[4500]<->10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug init child for policy: 192.168.170.0/24/24:0 <=> 192.168.160.0/24/24:0 ipproto:255
Nov/25/2016 14:08:39 ipsec,debug GETSPI sent: 10.0.0.1->10.1.0.1
Nov/25/2016 14:08:39 ipsec,debug ikev2 got spi 0xb7705da
Nov/25/2016 14:08:39 ipsec,debug init child continue
Nov/25/2016 14:08:39 ipsec,debug offering proto: 3
Nov/25/2016 14:08:39 ipsec,debug   auth: sha512
Nov/25/2016 14:08:39 ipsec,debug   auth: sha1
Nov/25/2016 14:08:39 ipsec,debug   auth: md5
Nov/25/2016 14:08:39 ipsec,debug   esn: off
Nov/25/2016 14:08:39 ipsec,debug initiator selector: 192.168.170.0/24/24 ipproto:0
Nov/25/2016 14:08:39 ipsec,debug => selector created (size 0x18)
Nov/25/2016 14:08:39 ipsec,debug 00000018 01000000 07000010 0000ffff c0a8aa00 c0a8aaff
Nov/25/2016 14:08:39 ipsec,debug responder selector: 192.168.160.0/24/24 ipproto:0
Nov/25/2016 14:08:39 ipsec,debug 00000018 01000000 07000010 0000ffff c0a8a000 c0a8a0ff
Nov/25/2016 14:08:39 ipsec,debug my ID (ADDR): 10.1.0.1
Nov/25/2016 14:08:39 ipsec,debug => auth nonce (size 0x18)
Nov/25/2016 14:08:39 ipsec,debug 8b24f42f aada2a63 b1d521de 55c5e635 450f145c 1e79b6cc
Nov/25/2016 14:08:39 ipsec,debug => SK_p (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug => idhash (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 210cb837 b8674af3 9816ad00 6507ff08 52ed8dac 178c368a 5ec94589 a8fcc964
Nov/25/2016 14:08:39 ipsec,debug => my auth (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 6b080158 8bbdd7ce 600b89dc 2bc0a967 a8bb4183 16d4c066 9bd42eb3 54a29d5b
Nov/25/2016 14:08:39 ipsec,debug adding payload: ID_I
Nov/25/2016 14:08:39 ipsec,debug => (size 0xc)
Nov/25/2016 14:08:39 ipsec,debug 0000000c 01000000 0a010001
Nov/25/2016 14:08:39 ipsec,debug adding payload: AUTH
Nov/25/2016 14:08:39 ipsec,debug => (size 0x28)
Nov/25/2016 14:08:39 ipsec,debug 00000028 02000000 6b080158 8bbdd7ce 600b89dc 2bc0a967 a8bb4183 16d4c066
Nov/25/2016 14:08:39 ipsec,debug 9bd42eb3 54a29d5b
Nov/25/2016 14:08:39 ipsec,debug => (size 0x58)
Nov/25/2016 14:08:39 ipsec,debug 00000058 00000054 01030408 0b7705da 0300000c 0100000c 800e0100 0300000c
Nov/25/2016 14:08:39 ipsec,debug 0100000c 800e0080 03000008 01000003 03000008 03000004 03000008 03000003
Nov/25/2016 14:08:39 ipsec,debug 03000008 03000002 03000008 03000001 00000008 05000000
Nov/25/2016 14:08:39 ipsec,debug adding payload: TS_I
Nov/25/2016 14:08:39 ipsec,debug => (size 0x18)
Nov/25/2016 14:08:39 ipsec,debug adding payload: TS_R
Nov/25/2016 14:08:39 ipsec,debug,packet => outgoing plain packet (size 0x200)
Nov/25/2016 14:08:39 ipsec,debug,packet e58e1a2e bdaa3dc0 b26151ae a98a503f 23202308 00000001 00000000 2700000c
Nov/25/2016 14:08:39 ipsec,debug,packet 01000000 0a010001 21000028 02000000 6b080158 8bbdd7ce 600b89dc 2bc0a967
Nov/25/2016 14:08:39 ipsec,debug,packet a8bb4183 16d4c066 9bd42eb3 54a29d5b 2c000058 00000054 01030408 0b7705da
Nov/25/2016 14:08:39 ipsec,debug,packet 0300000c 0100000c 800e0100 0300000c 0100000c 800e0080 03000008 01000003
Nov/25/2016 14:08:39 ipsec,debug,packet 03000008 03000004 03000008 03000003 03000008 03000002 03000008 03000001
Nov/25/2016 14:08:39 ipsec,debug,packet 00000008 05000000 2d000018 01000000 07000010 0000ffff c0a8aa00 c0a8aaff
Nov/25/2016 14:08:39 ipsec,debug,packet 00000018 01000000 07000010 0000ffff c0a8a000 c0a8a0ff dbf5102c 496786a6
Nov/25/2016 14:08:39 ipsec,debug,packet b7c9dcf0 051b324a 637d98b4 d1ef0e2e 3f516478 8da3bad2 eb05203c 597796b6
Nov/25/2016 14:08:39 ipsec,debug,packet c7d9ec00 152b425a 738da8c4 e1ff1e3e 4f617488 9db3cae2 fb15304c 6987a6c6
Nov/25/2016 14:08:39 ipsec,debug,packet d7e9fc10 253b526a 839db8d4 f10f2e4e 5f718498 adc3daf2 0b25405c 7997b6d6
Nov/25/2016 14:08:39 ipsec,debug,packet e7f90c20 354b627a 93adc8e4 011f3e5e 6f8194a8 bdd3ea02 1b35506c 89a7c6e6
Nov/25/2016 14:08:39 ipsec,debug,packet f7091c30 455b728a a3bdd8f4 112f4e6e 7f91a4b8 cde3fa12 2b45607c 99b7d6f6
Nov/25/2016 14:08:39 ipsec,debug,packet 07192c40 556b829a b3cde804 213f5e7e 8fa1b4c8 ddf30a22 3b55708c a9c7e606
Nov/25/2016 14:08:39 ipsec,debug,packet 17293c50 657b92aa c3ddf814 314f6e8e 9fb1c4d8 ed031a32 4b65809c b9d7f616
Nov/25/2016 14:08:39 ipsec,debug,packet 27394c60 758ba2ba d3ed0824 415f7e9e afc1d4e8 fd132a42 5b7590ac c9e70626
Nov/25/2016 14:08:39 ipsec,debug,packet 37495c70 859bb2ca e3fd1834 516f8eae bfd1e4f8 0d233a52 6b85a0bc d9f71636
Nov/25/2016 14:08:39 ipsec,debug adding payload: ENC
Nov/25/2016 14:08:39 ipsec,debug => (first 0x100 of 0x154)
Nov/25/2016 14:08:39 ipsec,debug 23000154 8716500b 1b9c3166 219dddfc 7bc4e2ac 81be62c3 6ff2529b 93f7350f
Nov/25/2016 14:08:39 ipsec,debug 842c8e51 f636b245 2859d1ac 1cf432e7 8bbcd520 a6bdd963 7e65b952 cba1cbbe
Nov/25/2016 14:08:39 ipsec,debug 25c21978 80e6d469 01a025d2 3e713b18 d9f3e9da 84e211f5 f3224ff2 5b50c32c
Nov/25/2016 14:08:39 ipsec,debug 5140dda4 47c96401 79066910 e9e0331b d3fb1edd 555c5e94 147a5662 e86d2560
Nov/25/2016 14:08:39 ipsec,debug 7d062cdc a9f43c03 29635238 8e91f410 58af94d5 6eddebf8 fb067e2a d61679e1
Nov/25/2016 14:08:39 ipsec,debug 540fb62f 04cde8de bb8de40b 39ccc1fa 4a7226bd 91578454 0bd5f5af d393c41d
Nov/25/2016 14:08:39 ipsec,debug c4c6545e 687f9ce0 3a079396 aa4e6ebf 7900b5f7 7e3c593d 41374cc4 3a42c60a
Nov/25/2016 14:08:39 ipsec,debug 9c86e189 7566385f ef610851 aa60afca 52e441ab 0cbcb744 6f830417 cd11bac7
Nov/25/2016 14:08:39 ipsec,debug unknown socket
Nov/25/2016 14:08:44 ipsec,debug retransmit
Nov/25/2016 14:08:44 ipsec,debug unknown socket
Nov/25/2016 14:08:49 ipsec,debug retransmit
Nov/25/2016 14:08:49 ipsec,debug unknown socket
Nov/25/2016 14:08:54 ipsec,debug retransmit
Nov/25/2016 14:08:54 ipsec,debug unknown socket
Nov/25/2016 14:08:59 ipsec,debug retransmit
Nov/25/2016 14:08:59 ipsec,debug unknown socket
Nov/25/2016 14:09:04 ipsec,debug retransmit
Nov/25/2016 14:09:04 ipsec,info killing connection: 10.1.0.1[4500]<->10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug ike2 initialize send for: 10.0.0.1
Nov/25/2016 14:09:09 ipsec,debug 0000001c e9fcdb31 8ef511b8 4e5cf796 a155c900 8f4bbc9d 0e584fde
Nov/25/2016 14:09:09 ipsec,debug 00000088 00020000 3535e12f bb56e239 39d369f0 e6766003 afdfa3f2 c71523d1
Nov/25/2016 14:09:09 ipsec,debug 919bf021 02226348 c18f9279 ef1d1c31 0a94b87a 9ad02c67 2034e9c8 8c9605e6
Nov/25/2016 14:09:09 ipsec,debug 14af48f7 e215c8fd 2626d63e 32a5f288 8cc3897d 6cdf73e2 6bb9bed6 b5e161a7
Nov/25/2016 14:09:09 ipsec,debug 2d7d5d15 d5d48abd 946cf3bd 2b5ee323 ca76cc4c 9c8fb360 f3d226ad 2d68cee9
Nov/25/2016 14:09:09 ipsec,debug f9852e1a e044d755
Nov/25/2016 14:09:09 ipsec,debug => (size 0x44)
Nov/25/2016 14:09:09 ipsec,debug 00000044 00000040 01010006 0300000c 0100000c 800e0100 0300000c 0100000c
Nov/25/2016 14:09:09 ipsec,debug 800e0080 03000008 01000003 03000008 02000005 03000008 03000003 00000008
Nov/25/2016 14:09:09 ipsec,debug 04000002
Nov/25/2016 14:09:09 ipsec,debug sending 260 bytes from 10.1.0.1[500] to 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet sockname 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet send packet from 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet send packet to 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet src4 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet dst4 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet 1 times of 260 bytes message will be sent to 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug 240 bytes message received from 10.0.0.1[500] to 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug ike2 answer exchange: SA_INIT id: 0
Nov/25/2016 14:09:09 ipsec,debug ike2 initialize recv
Nov/25/2016 14:09:09 ipsec,debug new ph1 initiator connection established
Nov/25/2016 14:09:09 ipsec,info new ike2 initiator connection: 10.1.0.1[4500]<->10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug init child for policy: 192.168.170.0/24/24:0 <=> 192.168.160.0/24/24:0 ipproto:255
Nov/25/2016 14:09:09 ipsec,debug GETSPI sent: 10.0.0.1->10.1.0.1
Nov/25/2016 14:09:09 ipsec,debug ikev2 got spi 0x1bdbd32
Nov/25/2016 14:09:09 ipsec,debug init child continue
Nov/25/2016 14:09:09 ipsec,debug offering proto: 3
Nov/25/2016 14:09:09 ipsec,debug   auth: sha512
Nov/25/2016 14:09:09 ipsec,debug   auth: sha1
Nov/25/2016 14:09:09 ipsec,debug   auth: md5
Nov/25/2016 14:09:09 ipsec,debug   esn: off
Nov/25/2016 14:09:09 ipsec,debug initiator selector: 192.168.170.0/24/24 ipproto:0
Nov/25/2016 14:09:09 ipsec,debug => selector created (size 0x18)
Nov/25/2016 14:09:09 ipsec,debug 00000018 01000000 07000010 0000ffff c0a8aa00 c0a8aaff
Nov/25/2016 14:09:09 ipsec,debug responder selector: 192.168.160.0/24/24 ipproto:0
Nov/25/2016 14:09:09 ipsec,debug 00000018 01000000 07000010 0000ffff c0a8a000 c0a8a0ff
Nov/25/2016 14:09:09 ipsec,debug my ID (ADDR): 10.1.0.1
Nov/25/2016 14:09:09 ipsec,debug => auth nonce (size 0x18)
Nov/25/2016 14:09:09 ipsec,debug 649ccbf5 fc6dedcb ab685964 6981c266 640942fa 1e48d13a
Nov/25/2016 14:09:09 ipsec,debug => SK_p (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug => idhash (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug cbb46cdb 333a3830 8a1918a0 eebe09c0 51d9a97c 84486288 85088b75 5284b9c3
Nov/25/2016 14:09:09 ipsec,debug => my auth (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug d8ba1466 584647a5 e4167ec2 8015b2e7 5a3ee807 2121d4d7 e1deb6f7 83676146
Nov/25/2016 14:09:09 ipsec,debug adding payload: ID_I
Nov/25/2016 14:09:09 ipsec,debug => (size 0xc)
Nov/25/2016 14:09:09 ipsec,debug 0000000c 01000000 0a010001
Nov/25/2016 14:09:09 ipsec,debug adding payload: AUTH
Nov/25/2016 14:09:09 ipsec,debug => (size 0x28)
Nov/25/2016 14:09:09 ipsec,debug 00000028 02000000 d8ba1466 584647a5 e4167ec2 8015b2e7 5a3ee807 2121d4d7
Nov/25/2016 14:09:09 ipsec,debug e1deb6f7 83676146
Nov/25/2016 14:09:09 ipsec,debug => (size 0x58)
Nov/25/2016 14:09:09 ipsec,debug 00000058 00000054 01030408 01bdbd32 0300000c 0100000c 800e0100 0300000c
Nov/25/2016 14:09:09 ipsec,debug 0100000c 800e0080 03000008 01000003 03000008 03000004 03000008 03000003
Nov/25/2016 14:09:09 ipsec,debug 03000008 03000002 03000008 03000001 00000008 05000000
Nov/25/2016 14:09:09 ipsec,debug adding payload: TS_I
Nov/25/2016 14:09:09 ipsec,debug => (size 0x18)
Nov/25/2016 14:09:09 ipsec,debug adding payload: TS_R
Nov/25/2016 14:09:09 ipsec,debug,packet => outgoing plain packet (size 0x200)
Nov/25/2016 14:09:09 ipsec,debug,packet 08533b26 8e569ae1 2867bb59 b21566a3 23202308 00000001 00000000 2700000c
Nov/25/2016 14:09:09 ipsec,debug,packet 01000000 0a010001 21000028 02000000 d8ba1466 584647a5 e4167ec2 8015b2e7
Nov/25/2016 14:09:09 ipsec,debug,packet 5a3ee807 2121d4d7 e1deb6f7 83676146 2c000058 00000054 01030408 01bdbd32
Nov/25/2016 14:09:09 ipsec,debug,packet 0300000c 0100000c 800e0100 0300000c 0100000c 800e0080 03000008 01000003
Nov/25/2016 14:09:09 ipsec,debug,packet 03000008 03000004 03000008 03000003 03000008 03000002 03000008 03000001
Nov/25/2016 14:09:09 ipsec,debug,packet 00000008 05000000 2d000018 01000000 07000010 0000ffff c0a8aa00 c0a8aaff
Nov/25/2016 14:09:09 ipsec,debug,packet 00000018 01000000 07000010 0000ffff c0a8a000 c0a8a0ff 859fbad6 f3113050
Nov/25/2016 14:09:09 ipsec,debug,packet 6173869a afc5dcf4 0d27425e 7b99b8d8 e9fb0e22 374d647c 95afcae6 03214060
Nov/25/2016 14:09:09 ipsec,debug,packet 718396aa bfd5ec04 1d37526e 8ba9c8e8 f90b1e32 475d748c a5bfdaf6 13315070
Nov/25/2016 14:09:09 ipsec,debug,packet 8193a6ba cfe5fc14 2d47627e 9bb9d8f8 091b2e42 576d849c b5cfea06 23416080
Nov/25/2016 14:09:09 ipsec,debug,packet 91a3b6ca dff50c24 3d57728e abc9e808 192b3e52 677d94ac c5dffa16 33517090
Nov/25/2016 14:09:09 ipsec,debug,packet a1b3c6da ef051c34 4d67829e bbd9f818 293b4e62 778da4bc d5ef0a26 436180a0
Nov/25/2016 14:09:09 ipsec,debug,packet b1c3d6ea ff152c44 5d7792ae cbe90828 394b5e72 879db4cc e5ff1a36 537190b0
Nov/25/2016 14:09:09 ipsec,debug,packet c1d3e6fa 0f253c54 6d87a2be dbf91838 495b6e82 97adc4dc f50f2a46 6381a0c0
Nov/25/2016 14:09:09 ipsec,debug,packet d1e3f60a 1f354c64 7d97b2ce eb092848 596b7e92 a7bdd4ec 051f3a56 7391b0d0
Nov/25/2016 14:09:09 ipsec,debug,packet e1f3061a 2f455c74 8da7c2de fb193858 697b8ea2 b7cde4fc 152f4a66 83a1c0e0
Nov/25/2016 14:09:09 ipsec,debug adding payload: ENC
Nov/25/2016 14:09:09 ipsec,debug => (first 0x100 of 0x134)
Nov/25/2016 14:09:09 ipsec,debug 23000134 e0412176 e401d02c fc492bf1 50ce4f78 205394f5 9842d44f d1bbb9a8
Nov/25/2016 14:09:09 ipsec,debug 5c448d6d d8e3a74e bd0cd642 9431d62c 9f0257ba c4d60b70 eee1e367 9c275630
Nov/25/2016 14:09:09 ipsec,debug eef2455a 801acd6f b6bd5e03 d1c7fcc9 f728be73 35f8aae3 8071ee82 8d86e708
Nov/25/2016 14:09:09 ipsec,debug 915245e3 4c8bf018 742e3383 6067ff61 eb3e4134 320ac273 e81eb7a0 9a188078
Nov/25/2016 14:09:09 ipsec,debug 9c0f22fb 4a8ebfbe 16fa42c6 66ebe0d6 ee33e38b e67c620c 9dd0a4aa ae3d5485
Nov/25/2016 14:09:09 ipsec,debug c1ad6ea5 a33a00dd ad7ada68 5dd515aa d60888ec 4a4942b3 928cc526 4a8216e9
Nov/25/2016 14:09:09 ipsec,debug fcf13c1f b4635757 7ad1b56b bffbb916 beb79170 e382692d 18b54be4 aaf29355
Nov/25/2016 14:09:09 ipsec,debug 946d7338 c3d72725 e93c697e 32442f7f 3fc4983c 9bb3e593 7984fb50 b2d93355
Nov/25/2016 14:09:09 ipsec,debug unknown socket
Nov/25/2016 14:09:14 ipsec,debug retransmit
Nov/25/2016 14:09:14 ipsec,debug unknown socket
Nov/25/2016 14:09:19 ipsec,debug retransmit
Nov/25/2016 14:09:19 ipsec,debug unknown socket
Nov/25/2016 14:09:24 ipsec,debug retransmit
Nov/25/2016 14:09:24 ipsec,debug unknown socket
Nov/25/2016 14:09:26 ipsec,info killing connection: 10.1.0.1[4500]<->10.0.0.1[500]
IPsec export:
# nov/25/2016 14:23:12 by RouterOS 6.38rc37
# software id =
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1,md5 enc-algorithms=aes-256-cbc,aes-128-cbc,3des name=VPN pfs-group=none
/ip ipsec peer
add address=10.0.0.1/32 disabled=yes dpd-interval=disable-dpd enc-algorithm=aes-256,aes-128,3des exchange-mode=ike2 hash-algorithm=
    nat-traversal=no secret=TEST
/ip ipsec policy
add dst-address=192.168.160.0/24 proposal=VPN sa-dst-address=10.0.0.1 sa-src-address=10.1.0.1 src-address=192.168.170.0/24 tunnel=y
