when I press the red X on everywhere id doesn’t disabe the interface\rule or what ever
also when I press “D”
it only disable when I write it in the cli
why is it?
why is it?
There is definitely too little information in your post to provide any kind of answer ![]()
Are you logged in with a user that has the FULL Group? Are you connected via MAC address or IP address? Have you checked the LOG ?
Try in fresh open WinBox > Tools > Clear Cache and WinBox should be a 3.11
I’m connected as admin , group FULL ,try to enter MAC and also IP
doesn’t see anything in the log - didn’t say “disable\enable”
I have restart the router so all I have is: ether1 + wlan1
no other setting
Reset without defaults and make all settings you need from scratch.
David1234 - Most likely you are using Winbox 2. If that is correct, then upgrade to Winbox 3.11 in order to make it work.
OK
yes I’m using the old version - I will replace it
Thanks ,
