Is anybody else having problems with Winbox (3.11 and below) disconnecting after a few minutes or did they implement some kind of default timeout somewhere that I’m not aware of?
No and no, respectively.
Hmm, maybe it’s just some sort of weird connectivity issue I’m having then. Thanks for the input!
Yes, I have experienced this with version 6.39.2 current on X86… It is very annoying. It has nothing to do with the connection. I did notice that this disappears if I close all windows inside the winbox before I close it. Next time I login it acts normal for more than if I have many windows opened (example… firewall, routes, interfaces, dhcp).
I hope so someone will come to an idea how to get rid of this problem.
Best Regards.
