v6.40.1 [current]
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
What’s new in 6.40.1 (2017-Aug-03 12:37):
*) bonding - improved reliability on bonding interface removal;
*) chr - fixed false warnings on upgrade reboots;
*) dhcpv6-client - do not run DHCPv6 client when IPv6 package is disabled;
*) export - fixed export for different parameters where numerical range or constant string is expected;
*) firewall - properly remove “address-list” entry after timeout ends;
*) interface - improved interface state change handling when multiple interfaces are affected at the same time;
*) lte - fixed LTE not passing any traffic while in running state;
*) ovpn-client - fixed incorrect netmask usage for pushed routes (introduced in 6.40);
*) pppoe-client - fixed incorrectly formed PADT packet;
*) rb2011 - fixed possible LCD blinking along with ethernet LED (introduced in 6.40);
*) rb922 - restored missing wireless interface on some boards;
*) torch - fixed Torch on PPP tunnels (introduced in 6.40);
*) trafficgen - fixed “lost-ratio” showing incorrect statistics after multiple sequences;
*) winbox - added “none-dynamic” and “none-static” options for “address-list-timeout” parameter under NAT, Mangle and RAW rules;
NOP
LCD still blinking after Upgrade
irghost - Are you talking about blinking LCD during Netinstall process? This fix solved problem when LCD was blinking while device is booted on RouterOS. Next rc release will fix also blinking LCD during Netinstall process (latest Netinstall will be required).
same as before
LCD blinking with ethernet LED after the RB2011 booted
Anyone have problem with ethernet link down and up? i see that after i upgrade 6.40 from 6.39.
Upgrade from v6.40 to v6.40.1
After reboot, new system forgot my PPPoE account and password setting.
Re-fill in QuickSet not working at all
Check /interfaces/pppoe-out1 manually, need specified the “interfaces” to ether1-gateway, and need set “add default route” manually to make it works again.
Same issue on the RB2011 with the led. I have to manually shut it off with set led command.
Somebody have problem with Google Email with Google Suite Sync over 6.39.2 / 6.40 / 6.40.1??
C:\Users\dgcapel\AppData\Local\Google\Google Apps Sync\Tracing\OUTLOOK
2017-08-04T15:52:43.042+02:00 38d0 W:Network gsync32!LogPotentialProxyNetworkFailure   [Reason: Warning:Potential proxy failure] @ 306 (**email_address**)> WinHttpGetProxyForUrl auto-detect failed with 0x80072f94  [color=#FF0000][Reason: Warning:Network timeouts][/color] . 0/(null). IsNetworkActive is 1, flags 1, IsNetworkActive GetLastError 0x80004005
2017-08-04T15:52:43.497+02:00 38d0 W:Sync gsync32!GLookSyncHelper::GetSyncPermit @ 513 (**email_address**)> SyncEngine '4'; SyncPermit is SYNC_PERMIT_UNKNOWN (0)
2017-08-04T15:52:43.499+02:00 38d0 W:Sync gsync32!GLookSyncHelper::GetSyncPermit @ 513 (**email_address**)> SyncEngine '4'; SyncPermit is SYNC_PERMIT_UNKNOWN (0)
2017-08-04T15:52:43.499+02:00 38d0 A:Sync gsync32!GLookSyncHelper::SetSyncPermit @ 537 (**email_address**)> SyncEngine '4'; SyncPermit is now: SYNC_PERMIT_GRANTED (2).
2017-08-04T15:52:43.499+02:00 38d0 A:Sync gsync32!GLookSyncer::GoOnline @ 1315 (**email_address**)> Going Online.
2017-08-04T15:52:43.500+02:00 38d0 A:Sync gsync32!GLookSyncer::ScheduleAllSyncTasks @ 1549 (**email_address**)> Scheduling calendar sync task: init delay 5 sec, interval 600 sec
2017-08-04T15:52:43.500+02:00 38d0 A:Sync gsync32!GLookSyncer::ScheduleAllSyncTasks @ 1566 (**email_address**)> Scheduling contacts sync task: init delay 5 sec, interval 1200 sec
2017-08-04T15:52:43.500+02:00 38d0 A:Sync gsync32!GLookSyncer::ScheduleAllSyncTasks @ 1583 (**email_address**)> Scheduling email  sync task: init delay 5 sec, interval 60 sec
2017-08-04T15:52:43.500+02:00 38d0 A:Sync gsync32!GLookSyncer::ScheduleAllSyncTasks @ 1604 (**email_address**)> Scheduling AB sync task: init delay 30 sec, interval 21600 sec
2017-08-04T15:52:43.500+02:00 38d0 A:Sync gsync32!GLookSyncer::ScheduleAllSyncTasks @ 1621 (**email_address**)> Scheduling notes sync task: init delay 5 sec, interval 3600 sec
2017-08-04T15:52:43.500+02:00 3618 W:Network gsync32!LogPotentialProxyNetworkFailure   [Reason: Warning:Potential proxy failure] @ 306 (**email_address**)> WinHttpGetProxyForUrl auto-detect failed with 0x80072f94 [Reason: Warning:Network timeouts]. 0/(null). IsNetworkActive is 1, flags 1, IsNetworkActive GetLastError 0x80004005
I have several devices that report error on export:
#error exporting /system routerboard mode-button
Tested on 750GL and mAP 2nD.
Fasttrack does not work in 6.40.1
SXT LTE
Bug in Web UI:
IP > IPsec > Policies:
  • No action if clicked on existing record. AFAIK I was able to edit them in past.
i noticed the same thing
Can you see if the connections are marked as fasttrack?
Having some OVPN problems having done an upgrade on clients from 6.38.5 to 6.40.1. Server is 6.37.5 still.
No VPN session stays up more than a minute:
11:53:40 ovpn,info,account XXXX logged in, A.B.C.D
11:53:40 ovpn,info : connected
11:54:20 ovpn,info : terminating… - nothing received for a while
11:54:21 ovpn,info,account XXXX logged out, 41 140 480 1 8
11:54:21 ovpn,info : disconnected
The profile is set to be quite long - 28 days for the session timeout, 1 hour idle timeout.
After the upgrade to version 6.40.1 from 6.39.2, problems with PoE ports:
00:10:11 poe-out,warning ether4 detected poe-out status: short_circuit
00:10:13 poe-out,info ether4 detected poe-out status: wait_for_load
00:10:14 poe-out,warning ether4 detected poe-out status: short_circuit
00:10:14 poe-out,info ether4 detected poe-out status: wait_for_load
RouterBoard 960PGS.
After returning to 6.39.2, the problem disappeared.
Not true. All my 4x RB2011 LCD’s are blinking constantly AFTER boot. I need to manually turn them off using WinBox - for example.
spectral-history not work
tested in SXT Lite5
Update from 6.39.2…aaand problem with dhcp:
Mikrotik(ap bridge,dhcp server)<----wireless—>ap_client[F8:D1:11:52:xx:xx](bridged wlan & eth, no other services)<----wired—>PC[B8:27:EB:8C:xx:xx]
aug/07 01:37:07 dhcp,warning dhcp1 offering lease 10.10.20.20 for B8:27:EB:8C:xx:xx to F8:D1:11:52:xx:xx without success
Reverted back to 6.39.2, problem disappears.
There is no fasttrack support for SXT LTE units yet!
What’s new in v6.40 (2017-Jul-21 08:45):
!) lte - added initial fastpath support (except SXT LTE and Sierra modems);
!) lte - added initial support for passthrough mode for lte modems that supports fastpath;
irghost, ksteink, lotnybartek - LCD and LED issue will be fully fixed in 6.41rc release
linux25, libyatik - Please after link down/up generate supout file on your router and send it to support@mikrotik.com
timonlio, dgcapel, maznu, jondavy, damiantrx - Please generate supout file on your router and send it to support@mikrotik.com
eworm - This problem will be fixed in upcoming 6.41rc releases
irghost - SXT LTE does not support FastPath/FastTrack yet
karnauskas - This problem will be fixed in upcoming 6.41rc releases. Sort table after “#” column and then you will be able to open this entry
Ocean - Please write to support. You do not see such errors in older versions because only in 6.40 PoE logging topic was added
