v6.40.2 [current]
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
What’s new in 6.40.2 (2017-Aug-08 13:13):
*) dhcpv6-client - fixed IA evaluation order;
*) led - fixed “modem-signal” LEDs (introduced in 6.40);
*) pppoe-client - fixed wrong MRU detection over VLAN interfaces;
*) rb2011 - fixed possible LCD blinking along with ethernet LED (introduced in 6.40);
*) sfp - fixed invalid temperature readings when ambient temperature is below 0C;
*) winbox - added certificate settings;
*) winbox - added support for certificate CRL list;
*) winbox - do not show LCD menu for devices which does not have it;
*) winbox - hide “level” and “tunnel” parameters for IPSec policy templates;
*) winbox - hide FAN speed if it is 0RPM;
Thank you for the release.
6.40.1 to 6.40.2:
on 2011UAS-2HnD, 711UA-2HnD and 751U-2HnD export found an additional line:
#error exporting /system routerboard mode-button
on virtualized x86:
> ```text
/dude
set enabled=yes
became
#error exporting /dude
both RBs and dude are working properly..
Regards
ndbjorne - “/system routerboard” export is fixed in 6.41rc versions and will be fixed also in 6.40.3. As for Dude export - we have not seen such error previously. Please send supout file from your device to support@mikrotik.com. Can you run “/dude print” and see what happens?
Did you fix www unresponsive ?
Yes, WWW crash is fixed in 6.41rc version:
http://forum.mikrotik.com/t/problem-with-mount-point/94/1
This fix will be included also in 6.40.3 version. It was made too late when 6.40.2 was already built and being tested for release.
great!
It solved by itself (maybe dude was not fully running?)
[me@VM-ROS] > /dude print
         enabled: yes
  data-directory: dude
          status: running
[me@VM-ROS] > /dude export
# aug/24/2017 18:25:16 by RouterOS 6.40.2
/dude
set enabled=yes
[me@VM-ROS]
Do you still want me to send spout to support?
Regards
Please release 6.40.3 asap.
I can’t run hotspot server now.
what’s the problem with hotspot server in 6.38.7, for example?
Hello!
I have problem with multicast packade in 6.40.2 FW on hEX(RB750Gr3) router.
I can’t add packade. After drag and drop file to winbox and rebooting i not see multicast in packades list.
www and www-ssl unresponsive randomly from 6.40.1
Check Log - the reason is there
but 6.38.7 (actual bugfix version) should not be affected, that’s why I ask
I concern vlan and bridge error when downgrade.
My main router have alot vlan and bridge, filter.
I got you. Why not use 6.40 then until 6.40.3 release?
6.40 can not use torch on ppp.
Routeros so much bugs …
wait a minute… hw-bridges are in 6.41rc, not in 6.40, so you may freely downgrade to 6.38 :slight_smile:
Issue (also in 6.40.1) with some dhcp clients over nv2 link - request from client ok, response/offer from dhcp server not transfer.
client----rb----(nv2)----rb with 6.40.2-----server.
Downgrade to 6.38 ‘resolve’ issue..
Pozdrawiam
Z.K.
Mikrotik freeze on RB952Ui-5ac2nD when enabling a disabled lte1 interface using an Huawei-E3372.
after a power disconnect and reconnect, lte1 works. disabling it works as well, but enabling it again always let the
device freeze! As the device is enabled after the reboot, it seems so accept the “enable”-command.
Can you make the “list of lists” option in the firewall?
Sometimes it is necessary to block several different lists of addresses for users. In order not to write several rules, it would be simpler to create a list of lists and make a rule relative to it.
