V6.41 Addresses
I noticed in “ip> addresses” that the defconf has the router address interface as “ether2”. Should that be “bridge” in 6.41, or does it even matter?
If interface is a slave for other interface (in this case ether2 is slave of interface bridge), then IP address, DHCP client and other features should be configured on master interlace - bridge.
Thanks, strods.
You work Saturdays?
