Good day forum!
Sorry for maybe newbie question but i need to know how some stuff works:
As documentation says : When a switch receives a broadcast, it forwards it to each port on the switch except the incoming port.
Does new Mikrotik bridge replacement for switch chips do the same or i need to write filter rule to prevent source MAC broadcast packet flooding back?
Cha0s
November 12, 2017, 2:55pm
2
I haven’t tested it myself, but I am pretty sure that it will work this way. These are pretty standard stuff for MikroTik to have overlooked.
Ok, i done some experiments and find that broadcast packet returned thru source interface and caused an loop in the neigbor device… Maybe i don’t understand new bridge well?
Any comments from MikroTik?
Jotne
November 13, 2017, 6:49am
5
It would help if you post your config. Or send a support request to Mikrotik.
Config is simple.
sfp1 - Goes to provider device.
ether2, ether3, ether4 - customer devices (routers).
add fast-forward=no name=main1 vlan-filtering=yes
add bridge=main1 interface=sfp1
add bridge=main1 interface=ether2 pvid=2
add bridge=main1 interface=ether4 pvid=3
add bridge=main1 interface=ether3 pvid=4
/interface bridge vlan
add bridge=main1 tagged=sfp1,ether2 vlan-ids=2
add bridge=main1 tagged=sfp1,ether4 vlan-ids=3
add bridge=main1 tagged=sfp1,ether3 vlan-ids=4
Problem is: broadcast packet from sfp1 with mac 12:34:56:78:9A:BC goes back in sfp1 causing loop in provider device…
What i’m missing?
Anumrak
November 13, 2017, 9:59am
7
covertops:
Config is simple.
What i’m missing?
It might be bad optical cable connection. What errors do you receive on sfp port in “Traffic” tab?
