nin - Detect Internet was just a guess. We will look into the problem through support ticket and let you know about the findings. Please provide supout files from both devices within an e-mail to support@mikrotik.com. squeeze - Currently there is no RouterBOARD with such built-in wireless functionality. zilf - We will look into this problem. Are you sure that 6.41.4 did not have such problem? yhfung,jrpaz - We are still working on improvements. Hopefully we will provide improvements as soon as possible within 6.43rc version. spitkia - Do you mean that there is no link on ether1 which was working fine on 6.41.4? Please generate supout file on your router while ether1 is connected to other device but link is not established. Send this file to support@mikrotik.com. kez - More improvements regarding this feature will be implemented within 6.43rc version. Redmor - In order to see improvements you must upgrade AP devices. Please note that in most cases you can see the difference only, if there are more than 10 stations connected (number can vary, it can be more and it can be less than 10).
After removing the client entry, no problems anymore.
Whether it was sitting there all the time or not I cannot say. However I have used many months ago the quickset for a switch configuration and I never had changed this very simply setup…
What do you mean with “upgrade”, isn’t 6.42 enough? I have to upgrade Routerboard’s firmware?
I also have to upgrade clients to 6.42 and also RB firmware?
VirtIO multI-queue does not actually work on 6.42rc56. I’ve sent an email to support and posted information in the 6.42rc56 discussion forum, hope this is easily fixed by RouterOS calling ethtool to actually enable multi-queue.
After upgrading from 6.41.3, RB850Gx2 started rebooting in a loop, reseting did help but only after 4th time, and still wasn’t able to restore from backup, restoring from backup it started rebooting again.
with 6.41.4 IPTV (multicast) traffic started glitching, I had to switch back to 6.41.3…
deividask - Please send supout file from your router to support@mikrotik.com. If you can reproduce the crash constantly, then we should be able to do the same and resolve issue quickly. Please also include description of your network traffic.
I face the same issue on hAP ac (RB962).
In my case Tx Rate is always zero for ethernet interfaces added to the bridge with hardware offloading enabled. Disabling hardware offloading for the bridge port fixes the issue, but you get another one - no hw offloading
it seems we lost packet fragmentation for EoIPs connecting bridges between two MTs we no longer can transport big pppoe-frames there; was working with 6.41.4
RouterOS 6.42 does appear to include the VirtIO multi-queue driver but I assume information may have purposefully been left out of the change logs due to it not actually working. We left RPS enabled to distribute the IRQ events on the first queue to the various cores:
WIFI on the cAP ac is WAY better, i dont need to update my hAP ac2 for now since the wifi on it only turn on when the hAP is down and that shouldn’t happen often or never
if you can tweak it more, that would be nice but for now this local speed is more than my internet which is all i can ask for now
(the hAP got very very basic config, mostly a bridge and just a dhcp-relay by lan to my cAP)
Please ignore the following post since I am able to get better reset after a hardware reset when the unit is no longer accessible by winbox. Now the unit is back to normal and I shall carry out the following tests.
Thank your reply for our problems encountered. In the past, we put our time on the ac, we did not put much time on 2.4GHz performance. In this morning, I would like to performance the complete test including 2.4GHz, I found that the performance was very very bad that I could not use it to edit post on MikroTik Forum.
For details, please take a look at other post that was written by within this Forum as follows:
