RouterOS version 6.43.14 has been released in public “long-term” channel!
Before an upgrade:
Remember to make backup/export files before an upgrade and save them on another storage device;
Make sure the device will not lose power during upgrade process;
Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.43.14 (2019-Apr-02 09:12):
MAJOR CHANGES IN v6.43.14:
!) ipv6 - fixed soft lockup when forwarding IPv6 packets;
!) ipv6 - fixed soft lockup when processing large IPv6 Neighbor table;
Changes in this release:
*) ipv6 - adjust IPv6 route cache max size based on total RAM memory;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Please keep this forum topic strictly related to this specific RouterOS release.
after upgrading to 6.43.14, our ipv6 on pppoe has stopped working on devices with more than 1000x pppoe online, equipment with less than 1000x pppoe online, it works.
when downgrading to version 6.42.12 back to normal operation.
yes, all above 6.42.12, presented problems in the delivery of ipv6 on pppoe.
especially when restarting the router, better after deleting all the bindings of the dhcpv6 server.
IPv4 DHCP server in winbox empty (and not working, of course), export from CLI empty too (and stuck terminal).
Every CPU about 20-30 % load.
In log: snmp, warning timeout while waiting for program 23
----edit:
problem is in leases. I use this configuration:
I had the same upgrading from 6.42.12 on a CCR1009.
Not only that, but IPv6 (pd-pool) on PPPoE not working either. It depends on DHCPv6.
Downgraded back to 6.42.12, remove DHCPv4 server and details, upgraded, created it again. That resolved the problem. Details in ticket #2019040522003959
An upgrade should not render the entire DHCP package useless.
The issue is the DHCP package. IPv6 in PPPoE depends on DHCPv6, which is affected, if you had anything DHCP set up in 6.42.x or before. As Ludvik pointed out. It might be as simple as removing the leases. But it’s definatly a bug.
I have 4 RouterBOARD DynaDish G-5HacD r3, and when I update to 6.43.14 I can’t run bandwidth test to this RouterBOARD.
I checked if Btest Server is enable and I have no firewall rules just bridge.
The error when try run a test is “Can’t connect”
