I have a problem with wireless.
I getting internet from ISP Access Point [ROS: 6.27]. This link is 7 year old.
My station is RB433 and after upgrade from 6.43.7 to 6.43.8 link is drop down.
After troubleshooting i see diffence in Wireless tab.
On old conf, Frequency is 5920, Frequence Mode is superchannel, Conutry romania.
On new conf, Frequency is auto, Frequence Mode is regulary-domain, Conutry romania.
I cannot change back Frequency to 5920.
Can anyone help me? (I downgrade to 6.43.7 and push backup and this is work, but I won’t use old ROS)
sindudas - We are sorry for any inconvenience caused. We will fix this problem in upcoming RouterOS releases. ErfanDL - You can change value by using “/interface wireless set installation=any/indoor/outdoor”. honzam - What kind of information about DFS are you looking for? kez - Sometimes router that was using “ac” did tend to reboot due to a Watchdog timer. This problem is now resolved. This does not mean that all “Watchdog reboots” are fixed in RouterOS. Usually such reboot happens on overloaded router. ErfanDL, nichky, amt, mistry7 - This setting (installation) makes your router to take into account parts from “/interface wireless info country-info ” that specify usage in indoors or outdoors. awacenter - What do you see when you run “/system logging export” command? hapi - Please send supout.rif file from your router to support@mikrotik.com. Name from which version you did upgrade your router. mikelaurense - Does interface actually gets disabled? Or it becomes inacessible? If it disabled, then someone has done that manually. Please provide supout.rif file tp support@mikrotik.com. Make sure that file is generated while interface is “disabled”. Redmor - Yes, but that is the whole point of country settings. You can still change settings in order to do so. Country settings are made in order to comply to regulatory domain. sff - Have you contacted support@mikrotik.com regarding this matter. We have fixed suh bug in RouterOS already, however, your problem might be little bit different. hapi - Please provide supout file from your router that would be generated while router is inaccessible either over another interface or over serial console. We will see why you can not access router at some point. I do not see any reason why you should jump tp consclusions right away and announce this as a “bug”. anav - Yes - "http://forum.mikrotik.com/t/6-43-8-update-alert-read-before-update/126150/1 ognjen - In Europe (country selected) you can not use any other settings besides regulatory domain.
These settings can be used only if any or indoor is selected on wireless interface. If you select outdoor, then you can not use this part. Same rules apply if info says “outdoor” - indoor configuration will not be able to use it:
strods I’m not saying that this change is wrong, it should work like that, but:
Write it in changelog
If you have to update and set regulatory domain for countries, why removing superchannel with country set instead of unsetting country with superchannel set?
You are right that there could have been two ways to adjust the inaccurate setting for some users.
We chose to adjust towards compliance, not towards incompliance. If user has set a country, he possibly wanted to be compliant already.
yottabit - To which IP address does your router resolve upgrade.mikrotik.com (:put [:resolve upgrade.mikrotik.com])? Upgrade should work on this router without any problems. There might be some proxy server between your router and upgrade server causing this.
Strange, right? It’s also worth noting that all but 2 of the other routers I mentioned above are behind this router that won’t upgrade, and are forced to use this router for DNS. There is no proxy.
Edit: switched to OpenDNS, and the resolve is the same, but still can’t connect.
Edit again, nevermind, figured it out. It was new firewall rule I had implemented a while back, since the last upgrade. I guess I need to add an “allow related, etc.” rule above the tarpit rule:
3 ;;; tarpit WAN
chain=input action=tarpit protocol=tcp in-interface-list=WAN log=no log-prefix="tarpit"
Sorry for the false alarm.
This fixed it, for anyone playing along:
3 ;;; Accept WAN established,related before tarpit
chain=input action=accept connection-state=established,related in-interface-list=WAN log=no log-prefix=""
4 ;;; tarpit WAN
Can you provide supout file to support@mikrotik.com? Honestly, I do not see how (if you did not play around with Photoshop ) you could get this information under country info.
I don’t think that a user using superchannel with a country set wants to be compliant and I think the second option (changing country on update) is the best option.
In the end, these are things that should be written in changelog, I think lots of users lost CPE connection for this update.
