v6.43.8 [stable] is released!
I launch the terminal, I create the rule.
In the parameters an intentional error, the rule applies.
I look through the winbox, I see a new error parameter perouting.
This is normal ?
[tik01] > ip firewall mangle add action=change-ttl chain=p
postrouting  prerouting
[tik01] > ip firewall mangle add action=change-ttl chain=perouting new-ttl=increment:1 passthrough=yes
[tik01] > ip firewall mangle ex co
# feb/01/2019 19:14:17 by RouterOS 6.43.8
# software id = BI8D-QNXG
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = **
/ip firewall mangle
add action=change-ttl chain=prerouting new-ttl=increment:1 passthrough=yes
[tik01] >
It is. Absolutely. You have simply added a rule to a custom (user-defined) chain named ‘perouting’ that you can now jump to using ‘action=jump’ rules.
And, by the say, this is in no way version-specific, so in the future please refrain from posting such questions to version-specific threads.
After contact with Mikrotik support I changed channel width to ‘20/40/80 MHz XXXX’. This does seem to improve stability, although it did happen once or twice again since changing it
LTE bell on any phone - kicks wifi on RB4011, any channel from 36-161!
Please see how shows “Bytes” in IP-mangle. There are non sense data.
Please fix it in next release.
This problem persists over many versions
Thank you
abrandecky please generate and send supout file to support.
Which one is next stable release? v6.44?
My 750Gr3s seem to show a memory leak in the proxy. With proxy disabled the memory usage is around 42mb. If you enable the proxy but don’t send any traffic the memory consumption stays at 42mb. As soon as you open the web proxy interface in winbox the memory consumption jumps to 64mb (still no traffic via proxy). As soon as any traffic flows via the proxy the memory consumption jumps to 102mb. At the same time, if you go and look at the proxy it says Total RAM Used: 996KiB. So something somewhere is leaking close to 60mb. This did not happen before on 6.42.7 which is the version I upgraded from.
Does anyone know how to rectify?
I’m afraid of upgrading my 941 and 952 devices as they don’t have the 60mb for the leak and most of them are remote (like 20 hour plane ride away)
“20 hour plane ride away”, my god Please don’t. Stay on bugfix or Long-term how it’s called now.
New version 6.43.11 has been released in stable RouterOS channel:
https://forum.mikrotik.com/viewtopic.php?f=21&t=144949
