v6.44.2 [stable] is released!
RouterOS version 6.44.2 has been released in public “stable” channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.44.2 (2019-Apr-01 12:47):
MAJOR CHANGES IN v6.44.2:
!) ipv6 - fixed soft lockup when forwarding IPv6 packets;
!) ipv6 - fixed soft lockup when processing large IPv6 Neighbor table;
Changes in this release:
*) ipv6 - adjust IPv6 route cache max size based on total RAM memory;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Hi Emils,
Is this fix related to recent vulnerability issue that were going to go public on 9 April?
yes, see http://forum.mikrotik.com/t/uknof-43-cve/128988/1
Nice attempt at being subtle there. Wouldn’t it have been better to email something like that to support rather than start a new vulnerability panic? ._.
Thanks, at least you gave a source so we can calm our nerves.
EDIT:
Just gonna leave a link to the MikroTik blog post here too.
Here: https://blog.mikrotik.com/software/cve-2018-19298-cve-2018-19299-ipv6-resource-exhaustion.html
The TCP connection tracking issue introduced in 6.44 is still present.
(TCP packets with ACK or ACK,PSH flags are not treated as NEW when loose TCP connection tracking is set, but they should be)
Update from 6.44.1 to 6.44.2 went smooth, no problems
still no progress for bgp and ospf bugs, :frowning:
thx
This version is exclusively IPv6 soft lockup bugfix. No progress in any other facilities at all.
unable to upgrade hap lite AC from 6.43.12, starting with 6.44 version…
what could be the problem..?
Check if there’s something at the very beginning of /log right after failed attempt to upgrade.
I’m not sure if it was there before, but after upgrading a WAP AC I see a “W60G Station” tab in the wireless menu in Webfig.
Makes no sense on this hardware and should maybe be hidden on non 60GHz hardware?
Literacy issue wrt release notes I guess. :wink:
Can you add a translated page (little brexit flag link) to english please :stuck_out_tongue_winking_eye:
I did have the same problem. Look in the logs. It may be too little space to upgrade.
Clean out not need file in flash, reboot and then try upgrade. Did work for me.
3 x HapAC 6.44.1 → 6.44.2 so far seems all is good
Thanks!
i got 2011UiAS-2HnD. After upgrading to 6.44.2 my RB is freezing. When im pinging the router from my computer it goes 1ms..10ms 600.ms..and timeout…over and over again
/log says it does not have enough space.
/log running out of disk space, when min 500kB is reached UM will be stopped!
however i don’t have any file in my File Lists except /flash and /flash/skins (empty)
I also have the same problem when upgrading into 6.44.2 on hap.
but i make it to do it, it work eventhough only around 500 kb left after routeros uploaded.
clear all the files on /files then upload the npk, stop and clear cache on webproxy, it will give you little space.
thx
Sorry, I’m out of politics, just use Google Translate xD
Are you REALLY running a webproxy on a hAP using the flash as the proxy cache???
:astonished: :astonished: :astonished:
haha yes,
i am implementing transparent proxy, for testing only.
i use hap for home ap.
thx
