RouterOS version 6.44.3 has been released in public “stable” channel!
Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.44.3 (2019-Apr-23 12:37):
Changes in this release:
*) certificate - fixed SAN being duplicated on status change (introduced in v6.44);
*) conntrack - fixed “loose-tcp-tracking” parameter not taken in action (introduced in v6.44);
*) dhcpv4-server - fixed commenting option for alerts;
*) dhcpv6-server - fixed binding setting update from RADIUS;
*) ike1 - improved stability for transport mode policies on initiator side;
*) ipsec - fixed freshly created identity not taken in action (introduced in v6.44);
*) ipsec - fixed possible configuration corruption after import (introduced in v6.44);
*) ipv6 - adjusted IPv6 route cache max size;
*) ipv6 - improved IPv6 neighbor table updating process;
*) lte - reset LTE modem only when SIM slot is changed on dual SIM slot devices;
*) rb2011 - removed “sfp-led” from “System/LEDs” menu;
*) smb - fixed possible buffer overflow;
*) snmp - added “radio-name” (mtxrWlRtabRadioName) OID support;
*) ssh - added “both”, “local” and “remote” options for “forwarding-enabled” parameter;
*) ssh - do not generate host key on configuration export;
*) ssh - fixed multiline non-interactive command execution;
*) switch - fixed possible crash when interface state changes and DHCP Snooping is enabled;
*) userman - updated authorize.net gateway DNS name;
*) wireless - added support for US FCC UNII-2 and Canada country profiles for LHG-5HPnD-US, RBLHG-5HPnD-XL-US and SXTsq5HPnD-US devices;
*) wireless - improved wireless country settings for EU countries;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
