v6.44beta [testing] is released!
Be aware this overlaps with 64800: https://en.wikipedia.org/wiki/Wireless_Gigabit_Alliance#Channels
Also, it appears this isn’t in the default frequency list for station mode: https://wiki.mikrotik.com/wiki/Manual:Interface/W60G#General_interface_properties
Currently the RB3011 IPsec performance is comparable with any of the IPQ4018 routers (like 450Gx4, hAP ac2), it actually shares the same driver, however there are 4 total crypto modules on RB3011 and as of now only 1 is enabled, meaning it has the potential to achieve even higher throughput. Anyway, we will continue to develop this driver, but in the mean time, 400Mbps over the 100Mbps which you were able to achieve with software crypto is a valuable gain in my opinion.
Yes, thats true :slight_smile: Only that was strange, the smaller and cheaper 750Gr3 is stronger in it, but I got a deep explanation from you. Thank you!
RBM11G and R11e-5HacT looses the R11e-5HacT in this software revision and in 6.43 downgrading to 6.42.7 auto-magically makes the wireless card come back so it is a software issue and not a hardware issue. it is also repeatable during testing.
I reported the same problem to support. After upgrade to 6.43 rbM11 looses card. No answer yet.
good to know its not just me. i sent a supout to them and an email describing the issue but havent heard anything yet.
just out of curiosity are you also using an RBM11g also or something else with MPCIe?
RBM11G and R11e-5HacD
RBM33g+R11e-5HacT does seem to work. (design closely related to RBM11g)
But my connection issues still remain (http://forum.mikrotik.com/t/rbm33g-5hact-hw-defect-bug-or-feature/121480/1)
Support case is about that is also still open, although I haven’t received any feedback from MT about it for weeks now :frowning:
RBM33 still doesn’t seem to be a viable contender for a hap-ac replacement unfortunately.
(is design been given up???)
is not allowing to create qos scripts with parent queue with hotspot,
with pppoe works normal
Please consider some BGP fixes and improvements for 6.44:
  • make route matching via /ip route print where=.. with BGP full feeds faster
  • do not reset/re-establish a BGP session when it’s comment is changed
  • improve overall BGP convergence time on CCR/tile
  • introduce BGP4 SNMP MIBs
  • introduce priority/order feature for BGP sessions
Upgraded now, and I am not able to login anymore. Password appears to be changed. Same problem in Webfig as SSH. Known issue? Any idea how to restore?
http://forum.mikrotik.com/t/winbox-v3-18-released/123311/1
Well, I guess it should still be possible to login with Webfig or SSH?
Try to update winbox to 3.18 version.
From which version you upgraded RouterOS to v6.44beta?
Geo
Update the certificate in the browser. I had this problem too and it helped me.
I used Webfig on a MAC… Have winbox4mac on 3.17 - but that should not make any difference… As SSH does not work, it is not browser dependent, I guess…
ssh says “permission denied” all the time…
admin@192.168.88.6’s password:
Permission denied, please try again.
Does not work to login with blank password - so it seems something is corrupted…
The device is a RB751G-2HnD running as AP - I use it as a test device för new releases. So, no panic - but maybe alarming to others…
Winbox 3.18 - not working… When running it on a PC…
Try to clear cache:
Tools > Clear Cache
