V6.45.9 long term
Hello all,
Bugg Fix: Design Skin > uncheck what I want to disappear > Log off / Log in > those are back!!!
Thank you & Best regards!
  1. save the changes with a specific skin name, then assign the skin to your user group in user settings
Thanks for answering.
There’s no ISATAP in RouterOS, I’m not sure with what you’re confusing it. And other than that, no tunnels exist by default.
I found an active ISATAP tunnel on version 6.45.9 by default, try it, search yourself and see.
Do you have any hints, where exactly in RouterOS I should look for such thing?
My mistake, i was connected to another network …
Best Regards!
