RouterOS version 6.46.5 has been released in public "stable" channel!
Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.46.5 (2020-Apr-07 08:28):
Important note!!!
- The Dude server must be updated to monitor v6.46.4+ and v6.47beta30+ RouterOS type devices.
- The Dude client must be manually upgraded after upgrading The Dude server.
- The Dude requires "winbox" policy instead of "dude" to monitor v6.46.4+ and v6.47beta30+ RouterOS type devices.
**MAJOR CHANGES IN v6.46.5:
!) user - enable "winbox" policy for groups with "dude" policy;
Changes in this release:
*) capsman - fixed "certificate" parameter updating on CAP;
*) console - prevent incorrect type interfaces appearing in command hints;
*) crs3xx - fixed interface statistics for CRS354-48G-4S+2Q+ and CRS354-48P-4S+2Q+ devices;
*) crs3xx - fixed traffic forwarding after disabling/enabling bridge hardware offloading for CRS354-48G-4S+2Q+ and CRS354-48P-4S+2Q+ devices;
*) crs3xx - improved SFP+ DAC cable initialization for CRS326-24S+2Q+ device;
*) discovery - do not send CDP and LLDP packets on interfaces that does not have MAC address;
*) dude - fixed connection to other RouterOS type devices through The Dude agents (introduced in v6.46.4);
*) ike1 - rekey phase 1 rekeying as responder for Windows initiators;
*) ipsec - improved system stability when handling fragmented packets;
*) led - added "dark-mode" functionality for CRS105-5S-FB;
*) lora - added IPv6 support for LoRa packet forwarder;
*) lora - added UTC timestamp for RX events in "rxpk" json;
*) lora - added value limits for "freq-off" parameter;
*) lora - properly update source address for packets when routing table is changed;
*) lte - fixed IP type selection from APN on RBSXTLTE3-7;
*) sniffer - fixed minor typo in "host" menu;
*) supout - added "gps" section to supout files;
*) supout - improved PoE-out information reporting;
*) system - improved kernel panic reporting in logs after reboot;
*) system - improved system stability when forwarding traffic from switch chip to CPU (introduced in v6.43);
*) traceroute - improved stability when invalid packet is received;
*) traffic-generator - improved statistics reporting;
*) w60g - improved stability after multiple disconnections;
*) winbox - added "Options" parameter support for DHCPv6 client and server;
*) winbox - added 160Mhz extension channel support for CAPsMAN;
*) winbox - added support for "Tools->WoL" menu;
*) winbox - allow setting "20/40/80/160Mhz-eeeeeeCe" channel under "Channel Width" parameter;
*) winbox - do not show "Revision" parameter under "System/RouterBOARD" menu on devices that have only one revision;
*) winbox - fixed "ARP" parameter inheritance from "CAPs Configuration" configuration;
*) winbox - fixed "Bands" parameter display for LTE interfaces;
*) winbox - fixed "DSCP" parameter value setting;
*) winbox - fixed "Frequency" and "Secondary Frequency" parameter inheritance from "CAPs Channel" configuration;
*) winbox - fixed "Passthr. MAC Address" parameter display "LTE APNs" menu;
*) winbox - fixed "Switch" menu on CRS354-48P-4S+2Q+;
*) winbox - fixed "dst-port" unsetting in "IP->Hotspot->Walled Garden" menu;
*) winbox - fixed automatic "IPv6->Firewall->Address List" table update;
*) winbox - made "none" the default value for "Security Profile" parameter when creating a new "Wirelees->Connect list" entry;
*) winbox - properly show "Hw. Offload Group" value for each interface under "Bridge->Ports" menu;
*) winbox - renamed "Memory used" to "HDD used" for HDD type under "Tools->Graphing->Resource Graphs";
*) winbox - show "System/RouterBOARD/Mode Button" on devices that have such feature;
*) wireless - added "U-NII-2" support for hAP ac2 and RBwAPGR series devices;
*) wireless - added "skip-dfs-channels" parameter;
*) wireless - fixed default "antenna-gain" setting on SXT 2 and LtAP series devices;
*) wireless - updated "bangladesh" regulatory domain information;
*) wireless - updated "indonesia4" regulatory domain information;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
