v6.46 [stable] is released!
Hi i’ve just upgrade to 6.46 stable to various mikrotik routers.I 've noticed that if i change some parameters in interface wireless configuration(mode,freq,sc-list etc)
it freezes for no reason (show initializing in bottom interface status menu) then i have to manually access the router,reset and
reconfigure the interface in order to work.This happened to me in 3 different routers (rb433,rb953,rb922) and its a serious issue
specialy for remote location installations.
Issue with many PPP (including PPPoE) sessions will be fixed in the next stable and testing builds. All issues with file accessing including Dude, skins, etc will also be fixed in stable and testing builds.
We are already working on 6.46.1 version and if all goes smoothly it will be released this year. Sorry for any inconvenience.
I have observed similar behavior on SXT 4G kit. If I change something in lte1 interface (for example APN, or add/remove SIM card) - ether1 stops responding, LED’s turns off. Interface looks like disabled. I connected to device via ether2 - interface ether1 was not disabled, no suspicious signs, but LED do not shine. Reboot do not helps. I have even uninstalled device from mounting on roof, was ready to send to RMA. It happens several times, each time after reset device started to work normally. And this is not a cable issues, I used several cables. Note - this happens on 6.44.6 long-term and only with ether1.
:arrow_right: confirm bug on ARM and CHR devices.
Temporary hint on RB3011UiAS where’s attached USB flash: move all /dude content to disk1/, after that all default content is accessible and works fine.
How to do that? I’m trying to drag dude dir to disk1 but Winbox says ‘Couldn’t change file … - action failed (6)’
After update to 6.46, problem of explain in below topic occuer. Please fix that.
http://forum.mikrotik.com/t/problems-after-updating-routeros-from-6-45-7-to-6-46/135192/1
RB850Gx2
Similar to a previous poster, I also ran into a “damaged” routeros package error when updating a RB850Gx2 from 6.45.7 stable to 6.46 stable. The update seems to work fine, but the installation check fails at around 55%. I was able to revert it to 6.45.7 without any issues. I downloaded 6.46 manually, verified the checksums, and tried the update again, but it failed in the same manner.
I upgraded my fleet last Monday night from 6.45.6 to 6.46 and we’ve had several instances of devices running hotspots fail to bring up a splash page. Redirect doesn’t work, manually accessing the splash page via IP/hostname doesn’t work. There’s just no way to authenticate outside of being bypassed. Disabling hotspot server allows access.
Reboot temporarily resolves it. Considering I’ve seen references to hotspot being broken on 6.45.7, 6.46, and also everything after 6.44.6 long-term, I am ad-hoc downgrading devices to 6.44.6 long-term channel as they come up.
I’ve submitted my supout.rif via email.
RB1100AHx2
Upgrade from 6.45.7->6.46
Upgrade via winbox, upgrade firmware went ok, rebooted fine.
But web proxy stoped working after a while. Do Disable\Enable proxy work again, after about 2 hours proxy stopped working again.
Downgrade back to 6.45.7 → web proxy working ok
Hi!
I have Dude on x86 and
After update from 6.45.7 to 6.46
in about 24-48h no more can access to port 80: Error 404: Not Found
but i can ping and can access with winbox
after reboot again everything working and again after 24-48h cant access port 80
2x WapR lte kit bricked after updates for 6.46 !!!
All people need atention with product and updates from Mikrotik !!!
It’s not stable it’s not solid !!! Never tested completly!!!
It’s an old and very clever rule for every software - never put in production new release before first bugfix subrelease, so in this case wait for 6.46.1 at least.
Any chance that SUP-3815 might get fixed in 6.46.1 ? It’s regarding this: http://forum.mikrotik.com/t/ikev2-behind-pppoe-windows-clients-and-split-tunneling-split-include-issue/135396/1
New version 6.46.1 has been released in stable RouterOS channel:
http://forum.mikrotik.com/t/v6-46-1-stable-is-released/135478/1
