v6.47.8 [stable] is released!
RouterOS version 6.47.8 has been released in public “stable” channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.47.8 (2020-Nov-25 10:10):
Changes in this release:
*) arm - improved system stability;
*) bgp - treat route target with AS 65535 as two byte AS;
*) branding - fixed imported skin presence;
*) bridge - fixed BPDU guard port disable/enable on HW offloaded interfaces;
*) disk - improved disk management service stability when receiving bogus packets;
*) dns - improved stability with large table of static records;
*) ike1 - allow using “my-id” parameter with XAuth;
*) leds - fixed LED type setting;
*) metarouter - fixed directory entry reporting;
*) profile - fixed process classification on x86 systems (introduced in v6.47);
*) quickset - fixed wireless client “uptime” counter in “Home Mesh” mode;
*) sstp - fixed “idle-timeout” on TILE and CHR devices;
*) system - replace “3” in superscript to “^3” on RBD53GR devices;
*) upgrade - do not try installing packages if download was not completed;
*) winbox - added “operator” parameter under “Interface/LTE” menu;
*) winbox - added “reformat-hold-button-max” parameter under “System/RouterBOARD/Settings” menu;
*) winbox - added “tls-mode” parameter under “CAPsMAN/Security Cfg.” menu;
*) winbox - added “tx-rx-1024-max” counter under “Interface/Overall-Stats” for CRS3xx devices;
*) winbox - do not allow MAC address changes on LTE interfaces;
*) winbox - show “System/Health” only on boards that have health monitoring;
*) winbox - show “System/RouterBOARD/Mode Button” on devices that have such feature;
*) winbox - show “usb-bus” option on all boards that have it;
*) winbox - show “usb-type” option on all boards that have it;
*) winbox - sort IPv6 firewall “chain” parameter entries alphabetically;
*) wireless - added support for U-NII-2 US and Canada country profiles for mANTBox series devices;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
On the version 6.47.8 command repartition still not working (e.g. “/partitions repartition partitions =2”) causes the router’s cyclic reboot (about every 10 seconds).
On the version 6.46.8 this command works correctly.
architecture-name: mipsbe; model: 951Ui-2HnD; firmware-type: ar9344; factory-firmware: 6.46.1; current-firmware: 6.47.8; upgrade-firmware: 6.47.8
Support ticket(SUP-32199) was clossed with resolution “Software failure.”
What exactly want to say here:
On the version 6.47.8 command “system telnet” does not work with parametr “routing-table”. Error “telnet: Unknown argument”
[admin@MikroTik] > system telnet 192.168.1.1 routing-table=main
Welcome back!
On the version 6.45.9 this command works correctly.
Trying 192.168.1.1…
Connected to 192.168.1.1.
Escape character is ‘^]’.
Password:
Support ticket: SUP-34794
Upgrade went smooth…really interested in the “arm - improved system stability”!
I'm also curious
Look in 6.48beta topic... there is some discussion about that.
Normally the text "improved system stability" means: fixed something that caused a hard crash/hang/reboot.
Similarly the text "improved stability when receiving bogus packets" means: fixed a DoS possibility or even a gaping security hole.
E.g. in this case the "improved stability with large table of static records" refers to a DoS possibility in the DNS resolver that is now fixed (although it still does not work correctly)
The same for 6.47.7, so it’s not a problem of 6.47.8.
Probably the only things interesting to me. Updated successfully LtAP. Thanks for add Slot selection and USB type selection on WinBox.
Regards.
System health does not work properly.
CCR 1036 nothing to see
CRS309 only CPU temp
CRS326 only CPU temp
CRS 328 nothing to see
@plisken, look into the 6.47 new gauges ?
.1.3.6.1.4.1.14988.1.1.3.100.1
on HAP AC 3 the health system is also not working properly
I can confirm, my CRS328-24P-4S+RM no longer displays health.
With 6.47.7 I could see temps, fan RPMs, wattages, voltages, amperage, etc.
With this version you click the option and nothing gets displayed / happens..
The update killed the wireless speed on a RB4011+ down to less than 8M. I couldn’t even log in with WinBox/WebFig. Wired, everything was OK. I don’t use the default channel width, so maybe I need to reset everything to default and start over. Since I spent many hours testing various devices to get good wireless speeds on this router, I’ll update a spare HAP ac2 when I have more time to play with this release.
I have been keeping away from recent updates to avoid issues. Back to 6.45.8 for now.
EDIT: As I thought, I solved the issue by resetting to defaults and starting over with all settings instead of just loading a backup.
RBD52G-5HacD2HnD (HAP AC2) does not even show “health” option under “System” in Winbox. This is what happens when I check from CLI:
[admin@name] > /system health print
[admin@name] >
But it works on RB4011iGS+:
[admin@surname] > /system health print
      voltage: 23.5V
  temperature: 36C
[admin@surname] >
EDIT: I mean I am retarded then? :smiley: It should show the section, but should not display temperatures if no sensor. Please be consistent, otherwise you have to hide lots of sections, like wireless if no wifi card present, or LTE if no modem present…
RBD52G-5HacD2HnD (HAP AC2) does not have health information. It just does not have hardware sensors.
Mikrotik has work to do
Back to RouterOS 6.47.7
On the RB1100 1100AHx4 dude edition everything looks good
*) arm - improved system stability;"
Can you explain this a little bit? Does it include an improvement regarding watchdog for arm ethernet routers? Arm routers (1100xr) frequently switch off and on under high load due to the watchdog.
Health works on all devices I checked, including these reported with issues before by others:
CCR1036-8G-2S+
CRS328-24P-4S+
in the CRS328-24P-4S+ winbox Health window doesn’t open
Please add board temperature to SNMP 1.3.6.1.4.1.1.14988.1.1.3.10.0 for this device.
