Not all Microtik devices are affected with this problem. As far I know problem was with LHG5 ac version. Issue was with data throughput speed which was around 100mbs even if link could do much better than that. (in my case around 180mbs). In data monitor you could see something like waves, data speed goes up and down … When you start test speed was almost ok but after a second or two speed decrease and those waves starts … This problem was present from all versions 6.46.x everything was fine with all versions 6.45.x
One more problem with SOCKS. Since requests to connect to hostname are now supported, I expected this to work:
/ip socks
set enabled=yes version=5
/ip socks access
add action=allow dst-address=mikrotik.com
add action=deny
But it doesn’t:
any new regarding system-auto-upgrade that has been broken since 6.46?
it’s working fine on long-term version 6.45.9
thx
New version 6.47 has been released in stable RouterOS channel:
http://forum.mikrotik.com/t/v6-47-stable-is-released/140100/1
