RouterOS version 6.48.7 has been released in the “v6 long-term” channel!
Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.48.7 (2023-May-23 08:27):
!) ipv6 - fixed DNS server processing by IPv6/ND services (CVE-2023-32154);
*) capsman - improved stability when running background scan on CAP;
*) console - updated copyright notice;
*) firewall - fixed IRC NAT helper (CVE-2022-2663);
*) hotspot - improved stability when receiving bogus packets;
*) smb - fixed SMB2 file list reporting;
*) snmp - fixed IPsec-SA byte and packet counter reporting;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
