*) certificate - improved stability when sending bogus SCEP message;
*) conntrack - limit total connection tracking table size based on installed RAM size;
*) crs3xx - fixed interface linking for some optical QSFP+ modules on CRS354 devices;
*) dhcpv6-server - fixed DUID generation with timestamp;
*) health - improved temperature reporting;
*) led - added "dark-mode" functionality control with Mode button for cAP XL ac;
*) leds - fixed LTE LED default mapping for LHGG;
*) lte - improved RSSI reporting on R11e-LTE6;
*) routerboot - enabling "protected-routerboot" feature requires a press of a button;
*) snmp - fixed IPsec-SA byte and packet counter reporting;
*) sstp - fixed client stuck in "nonce matching" state;
*) system - improved system stability if device is upgraded from RouterOS and/or RouterBOOT v6.41.4 or older;
*) traffic-flow - added systematic count-based packet sampling support;
*) upgrade - added new "upgrade" channel for upgrades between major versions;
*) winbox - added "Modbus" menu support;
*) wireless - added U-NII-2 support for US and Canada country profiles for cAP ac XL and QRT 5 ac;
*) wireless - fixed frequency range information on IPQ4019;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
which button in rb2011? and which button in hap ac2?
and what if i am the admin and i want to enable protected routerboot to my routers remotely? not possible anymore?
Yes, that is the goal of this change. protected routerboot is abused by criminals asking ransom money to unlock compromised routers, so it requires physical presence to enable protected routerboot from now on…
As a test, I tried to upgrade my hAP ac2 that now has just 5 separate packages 6.49 installed (advanced-tools,dhcp,security,system,wireless) to the manually uploaded bundle package for 6.49.1 and it fails with “not enough space for upgrade”.
It looks like upgrading from separate packages to bundle package does not work on 16MB flash devices, I did the same on a RB2011 and a RB4011 without problem.
Earlier I tried to upgrade the hAP ac2 to v7.1rc6 encountering the same issue, which apparently is not a v6-to-v7 issue but just a “separate packages to bundle package on 16MB flash devices” issue. (SUP-66267)
When the protected-routerboot=enabled setting is done and then a print is done to display the current setting, it shows the message about the button in red.
This is in fact the same as in winbox, the message is shown in the “current status” of that menu.
