RouterOS version 6.49.11 has been released in the “v6 stable” channel!
Before an upgrade:
Remember to make backup/export files before an upgrade and save them on another storage device;
Make sure the device will not lose power during upgrade process;
Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.49.11 (2023-Dec-08 16:37):
*) console - display “End-User License Agreement” prompt after configuration reset;
*) defconf - use “WISP Bridge” default configuration mode for RBGrooveGA-52HPacn device;
*) poe-out - improved “auto-on” mode for devices with single PoE-out port;
*) pppoe-server - fixed connection count limit per license level;
*) wireless - fixed “wlan1” default name for RBSXTsqG-5acD and RBLDFG-5acD;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
Installed 6.49.11 and its boot firmware on RB 3011, 2011, hAP ac and multiple RB750’s - Everything works fine. Curious about what exactly improved about the poe-out port. Does it specifically address the problem related to low voltage passthrough that can blow the port out ?
Yes, that is what I see now, but I have not seen any announcement that long-term has been actually dismissed or merged with stable or anything similar.
Up until now, long-term was always separate from stable branch and when V6 stable had a new release, latest long-term version thread was still kept open, but not this time, that is why I was confused.
So in other words, it is ok to switch from “V6 long-term” branch to “V6 stable” branch, there will not be any V6 long-term released anymore, if I get it right
Yes, I know this, I have no need for V7 right now, so I’ll be staying on V6 for the time being.
I’m still rather new to Mikrotik. Can someone please tell me how “stable” and “long term” relate to versions 6 and version 7? Is “stable” version 7 less reliable than “long term” version 6?
