V6.49.3 [stable] is released!
RouterOS version 6.49.3 has been released in public “stable” channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
New RouterOS 6.49.3 (Dec/22/2021 13:49:22):
*) bridge - improved system stability when initialising bridge interface
*) console - updated copyright notice;
*) defconf - fixed secondary-frequency configuration;
*) ethernet - improved system stability when receiving large packets on devices with 88F3720 CPU (nRAY, LHGG);
*) led - fixed default LED configuration for CubeG-5ac60ad;
*) netinstall - fixed x86 installation process;
*) socks - fixed SOCKS5 support;
*) upgrade - improved 404 error handling when checking for new versions;
*) winbox - show “System/Health” only on boards that have health monitoring;
*) wireless - added U-NII-2 support for US and Canada country profiles for OmniTik 5, Metal 52 ac, and GrooveA 52 devices;
*) x86 - fixed downgrade from RouterOS v7.1.2 and above;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Before an upgrade:
Please add this text to the text shown in “check for updates” on the device itself.
This is especially important in case the user selected a channel that will result in an upgrade to v7.
In that case it would be better when an additional warning is shown that an upgrade to v7 could cause additional issues not commonly experienced when doing an update within v6.xx.
Dec/22/2021 ?
Back to the future 4?
upss, something wrong in here ?
try again, it should work correctly now
Yes, Now it’s okay. :slight_smile:
Was 6.49.3 really compiled Des 22 2021?
The Christmas party simply took longer than expected…
It underwent 2 months of rigorous testing before release. :slight_smile:
No wonder with Eva in the company :slight_smile:
If this compile time is true, this is the far longest time between compile date and post date. Longest I did found other than this is the 19 day for 6.42.11.
http://forum.mikrotik.com/t/v6-42-11-long-term-is-released/126617/1
:slight_smile:
Yes, see above Strods response.
We :potato: you guys
Or some forgot that it was done :slight_smile:
Just another strange notice. I do always open this page with scripts and announcement: https://forum.mikrotik.com/viewforum.php?f=9 to look for new releases and scripts problem. But this time this page does not show the new 6.49.3 post??? But if you look at this page: https://forum.mikrotik.com/viewforum.php?f=21 you see it. All other post are equal. One with 11 post and the other with 12?? Bug in forum, or some other posting error?
Hi!
I decided to update the CHR, take a look. And tell me, is it still 2021 or is it already 2022? (joke/reality) ?
P.S.
If I’m wrong, or it should be, then sorry.
2021: Correct at time of compilation: http://forum.mikrotik.com/t/v6-49-3-stable-is-released/155840/14
Fixed post announcement placement. Not it shows in all forum sections.
I suspect the same thing - with all the excitement around v7, somebody possibly forgot that 6.49.3 stable was never actually posted.
Guys, have faith in Mikrotik … nobody forgot anything, they performed diligent testing and this takes time. :wink:
date in changelog is broekn!!!
When that is only problem then we have a winner and the first release EVER without bugs…oh bugger, something just bit me!!!
