After installing the problems started:
- Decreased the frequency to 100 MHz
- Constant rebooting and not revert back, if not to use RS232
RouterBOOT booter 3.02
RouterBoard 450G
CPU frequency: 100 MHz
Memory size: 256 MiB
NAND size: 512 MiB
RouterBoard 450G
CPU frequency: 680 MHz
NAND size: 512 MiB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Starting…
Starting services…
MikroTik 6.0rc7
MikroTik Login: Oops[#1]:
Cpu 0
$ 0 : 00000000 00000001 00000000 fffffffe
$ 4 : cec3d500 00000000 00000000 c02d2410
$ 8 : 0000003c c02391d4 0000cc34 cd0acb40
$12 : cdd7f42c 00000003 ffffffff 000086dd
$16 : cdc8f540 cec3d500 00000000 00000000
$20 : c0391fcc 00000001 00000000 00000000
$24 : 0000000c 134f4c7a
$28 : cf6d0000 cf6d1c58 cec3d500 c029cc50
Hi : 00000064
Lo : 000006ca
epc : cf59ca68 udpv6_queue_rcv_skb+0x5c/0x77c [ipv6@0xcf580000]
Not tainted
ra : c029cc50 release_sock+0x94/0x108
Status: 1000d203 KERNEL EXL IE
Cause : 00800008
BadVA : 00000030
PrId : 00019374 (MIPS 24Kc)
Process net (pid: 219, threadinfo=cf6d0000, task=cf5fde30, tls=7766d770)
Stack : cdc8f180 cd25c050 cd25c050 00000000 cec3d500 cdc8f540 c0420000 c029cc50
000000a4 ffffffff cec3d70c cec3d70c 00000000 cec3d70c 00000000 cf6d1ee0
cdfafea0 00000000 00000074 cf59df00 0000007c c02deb00 cf6d1efc cf6d1d30
00000008 00000001 00000000 00000000 cf6d1cd8 cdfafea0 00000000 00000000
0000000c 00000000 00000000 00001104 00000000 ff020000 00000000 00000000
Call Trace:
[] udpv6_queue_rcv_skb+0x5c/0x77c [ipv6@0xcf580000]
[] release_sock+0x94/0x108
[] udpv6_sendmsg+0x80c/0x980 [ipv6@0xcf580000]
[] sock_sendmsg+0x84/0x9c
[] sys_sendto+0xcc/0x10c
[] stack_done+0x20/0x44
Code: 8e020048 2403fffe 00621024 <8c420030> 30420004 14400008 32420004 02202021 00002821
—[ end trace df72217082fc4575 ]—
Kernel panic - not syncing: Fatal exception in interrupt
panicSaver: dumping panic to flash
flash: erase f
flash: prg f
spi_program_sector 0000000f
Rebooting in 1 seconds..
RouterBoard 450G
NAND size: 512 MiB
Starting…
Starting services…
MikroTik 6.0rc7
Cpu 0
$ 4 : ceca2fc0 00000000 00000000 c02d2410
$ 8 : 0000003c c02391d4 000037c2 cd6a7660
$12 : ffffffff 00000003 ffffffff 000086dd
$16 : cf7bf6c0 ceca2fc0 00000000 00000000
$24 : 00000000 00000000
$28 : cf6d2000 cf6d3c58 ceca2fc0 c029cc50
Hi : 00000020
Lo : 69a36992
Not tainted
Cause : 00800008
BadVA : 00000030
Process net (pid: 219, threadinfo=cf6d2000, task=cf5fa280, tls=770d7770)
Stack : cdfba3c0 cf7e9a50 cf7e9a50 00000000 ceca2fc0 cf7bf6c0 c0420000 c029cc50
0000009f ffffffff ceca31cc ceca31cc 00000000 ceca31cc 00000000 cf6d3ee0
cdfcd680 00000000 0000006f cf59df00 00000077 c02deb00 cf6d3efc cf6d3d30
00000008 00000001 00000000 00000000 cf6d3cd8 cdfcd680 00000000 00000000
00000004 00000000 00000000 00001104 00000000 ff020000 00000000 00000000
Call Trace:
—[ end trace 14a0ee4ef2829e9f ]—
flash: erase f
flash: prg f
RouterBoard 450G
NAND size: 512 MiB
Starting…
Starting services…
MikroTik 6.0rc7
MikroTik Login:
I had to return to rc6.
