v6 rc8 released
What’s new in 6.0rc8 (2013-Feb-04 13:25):
*) ppp,pppoe,pptp,l2tp,sstp - only 2 change mss mangle rules are created for all ppp interfaces;
*) wireless - fixed AES encryption speed issues (upgrade suggested);
*) dhcpv6 server - handle info requests;
*) webfig - compressed all html resource files, speeds up opening of webfig page;
*) console - reduced width of address column in ‘/user print’;
*) simple queues requires target arg to be specified when adding;
*) do not count packets for unknown protocols as rx_dropped;
*) snmp - provide POE info;
*) improved cpu usage reporting on CCR boards;
*) improved interface reading performance;
*) changed CLI interface order - first are ethernets, second wireless, third everything else.
Within group interfaces are ordered by name;
*) interfaces are deleted much faster, could be bottleneck on systems with many ppp sessions;
*) pptp,l2tp,6to4 tunnel encapsulation/decapsulation now resets packet marks to
have consistent behavior across tunnels;
*) fix simple queue interface matching when doing encapsulation in some tunnel,
could result in double accounted packets;
*) ip/ipv6 firewall has all-ether,all-wireless,all-vlan,all-ppp interface matchers
*) queue limits could be inaccurate for large limits (100M or more);
*) added initial OpenFlow support
and I have an idea and proposal development, by means of the rc9 version will not be able to develop a graphical interface to the DDoS attack against protection?
Not able to update via “System/Packages” yet.. still thinks 6.0rc7 is current.
“Interface window” in winbox stops sending data. When making
a new connection the windows is empty.
Also no SNMP - CPU, DISK
RB433AH ROS6.0RC8 4feb13
This was not the case with the friday 1feb13 release where SNMP shot to 100%
Jörgen
still getting
System rebooted because of ping watchdog timeout
all rbs with ros6.0rc8
happens every couple of hours
watchdog disabled(off) and what is new ?
Dear Normis!
Multicast routing (PIM-SM) same source (IPTV channel) with different client IP (Set Top Box) not working in CCR1036 (RC6,RC7,RC8). Same ROS version (RC6,RC7,RC8) and same configuration (1. RP, 3. Interface) working correctly in RB2011.
Please investigate this problem…
Thx.
Attila
20:39:03 route,bgp,error tcp-md5-key currently cannot be enabled on CCR devices
Why wasn’t this mentioned in the Changelog? When will it be fixed and when it is please include it in the Changelog!! My router is pretty much useless without this.
edit: found post where it will be fixed in rc9, thanks.
with watchdog off the rb411 runs out of memory and hangs
and connection tracking off with 1 filter rule connection tracking is still on
post there:
/system resource print
/system routerboard print
I found firewall problem in rc8 - CCR1036
 /ip fire nat pri
 0   chain=srcnat action=src-nat to-addresses=185.15.0.3 src-address=192.168.24.0/22
 1   chain=srcnat action=src-nat to-addresses=185.15.0.4 src-address=192.168.14.0/23
 /ip fire fil pri
 0  chain=output action=log protocol=icmp log-prefix=""
and I get on output:
22:45:22 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.72.22->10.10.72.1, len 56
22:45:23 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.70.8->10.10.70.3, NAT (10.10.70.8->185.15.0.5)->10.10.70.3, len 50
22:45:23 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.72.22->10.10.72.1, len 50
22:45:24 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.70.8->10.10.70.3, NAT (10.10.70.8->185.15.0.5)->10.10.70.3, len 50
22:45:24 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.72.22->10.10.72.1, len 50
22:45:25 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.70.8->10.10.70.3, NAT (10.10.70.8->185.15.0.5)->10.10.70.3, len 50
22:45:25 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.72.22->10.10.72.1, len 50
I had a rule that NAT 10.10.0.0/16 to 185.15.0.5 but it was deleted.
I have to disable all nat rules to switch off nat this packets. After switching on I still have NAt 10.10.0.0/16 to 185.15.0.5
THANK YOU, THANK YOU, THANK YOU Mikrotik :slight_smile:
in the download page there was RC08 few minutes back , now its RC07 only ??
RC8 has a critical issue with Certificates. We temporarily pulled it off the website. If you don’t use certificates, you can keep using RC8
The “All packages” link for 6.x is missing completly after your pull back operation. I`ve just bricked a testboard with partitions on it and there is no 6.x (all packages) to download and use netinstall… Lucky that that was a test board…
ALL files from RC9 with fixed certificates:
http://www.mikrotik.com/download/share/all_files_6.0rc9.zip
ema
Please make sure you have not deleted firewall rule by yourself accidentally. We have upgraded many routers to rc8, and NAT rules were untouched on every of them.
For disabled NAT and logging wrong behavior, if you think that v6.0rc8 does not work properly with NAT or not NAT packets, please make support output file and send it to support department (support@mikrotik.com), thank you very much for help.
Where did they move the Beta downloads to?
I am not able to find them… weird.
what beta downloads ?
All the RC downloads are gone from the download website.
